Question about Hayward 125000 HAYWARD EASYTEMP HEAT PUMP
What dose the lp code on a hayward electric heat pump mean?
A customer says there heat pump has an lp code and some one told them it means low presure
5 Suggested Answers
  • 990 Answers
SOURCE: My heat pump is displaying LP, what does this
Low water pressure through the unit, you just need to adjust your valves to supply the right pressure to the heat pump.
Posted on Jan 03, 2010
thepool
  • 78 Answers
SOURCE: Heat pump will not start
Could be a firmware issue and require a new mother board. Unfortunately, you probably have done all you can on your own. Time to call the local HVAC service person...
Posted on Apr 22, 2010
thepool
  • 78 Answers
SOURCE: Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
StepehnD
  • 78 Answers
SOURCE: panel reads lp error code
Loss of refrigerant, bad motor for the fan clean the coils and unit as described in the manual. Here is a manual from the Hayward website or here http://www.haywardnet.com/products/manuals/pdfs/Manual122.pdf.
Posted on Jun 06, 2010
What does the LP code mean?
low pressure ,MEAN low water pressure going to the unit or low pressure refrigerant is heat pump correct ?
Jun 09, 2013 | Hayward Pool Products Hayward Heat Pro -...
Hayward heat pump error code L P . what does this mean?
LP is an error message refering to the low pressure switch. For more information about it please refer to hayward-pool.com/pdf/manuals/Manual122
Aug 11, 2011 | Heating & Cooling
We have a hayward pool heater and where the temperature normally is, it is flashing LP. what does this mean
The flow sensor within the heat pump must be clogged. not sensing any flow. clean your filters, backwash your filter. usually means low pressure.
Jun 26, 2011 | Pool & Spa
Turned on my Heat Pump, kicked on for a few minutes, now it won't kick on and code said L5, now says LP. Left it alone all night, still says LP???
HOPEFULLY ITS STILL UNDER WARRANTY.
CALL HAYWARD OR GO TO HAYWARDPOOLS.COM.
THEY WILL SEND A LOCAL SERVICE REP TO COME ADJUST THE FREON LEVELS (LP).
Dec 27, 2010 | Hayward 116k HeatPro Heat Pump HP3100
My heat pump is displaying LP, what does this mean?
Dec 29, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
LP (low pressure fault) is on screen.
This could be something as simple as a dirty filter. Heat pumps are notoris for pressure problems as they are very fickel. Make sure your filters are clean, then their should be a by-pass assembly on your inlet, outlet pipes for water this valve needs to be set at just the right spot to keep the water flow high enough to collect heat but not so high as to not warm enough. Setting this flow is easy enough with the unit on restrict the flow till the unit starts and wait to see that it keeps running. use a gentel hand and do this very slowley as the unit takes time to respond. But first make sure your filters are very clean and your baskets also. These are usually the culpret's when it comes to low pressure and low flow. The switch usually just tell's you that is where the problem is. If their is no corrosition or leaking at the pre. sw. more often than not it's ok and just tell's you to start looking for the problem. Good luck.
May 30, 2009 | Water Warehouse Hayward HeatPro In-ground...
May 26, 2009 | Hayward 116k HeatPro Heat Pump HP3100
I have a rome Industries Pool heat pump model 105 showing error code LP???? what does that code mean and what do I do?
I happen to work for Rome Industries and can help you out. The "LP" code on your control board represents "Low Pressure". This is referring to the refrigerant pressure within the unit. The unit is equipped with a low pressure safety switch that when activated shuts the unit down. This could be caused by a refrigeration leak, a stuck thermal expansion valve, or even a faulty pressure switch. If you live within the state of Florida contact Rome Industries and you will receive a free of charge service call including parts and labor as long as your unit is under warranty. If your outside of the state please contact your dealer to handle the claim. Have a good day.
May 01, 2009 | Pool & Spa
Low pressure is usually a dirty filter ob basket. If you have a by-pass on the plumbing you can shut this down a little to get more flow through the heater. Or you may have a clog in your pump impeller. Hope this helps.
Mar 12, 2009 | Water Warehouse Hayward HeatPro In-ground...
Hayward 125000 HAYWARD EASYTEMP HEAT PUMP Logo
148 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
