Question about Delta Saws
I have a Delta Unisaw 36-960 and i need to remove the motor. How do you remove the pin that holds the motor? Do i have to take the table top off the base?
The pin has a cotter pin on each end which i removed and then drove the pin towards the center of the saw. With about 1/4" to go before the pin dropped out - it comes in contact with the screw mechanism for raising and lowering the blade. What do i do now?
rowdy45176
  • 2176 Answers
SOURCE: Bosch 4000 table saw disassembly
turn the motor housing slightly until you can put a screwdriver between the housing and diaphragm, pull on the one side and push with the driver and it will come apart, I just did one yesterday. To get the armature out of the fan bearing you will need a dead blow hammer to tap on the diaphragm while pulling on the armature. The bearing is held in place with 2 screws, hope this helps.
Posted on Aug 18, 2009
Testimonial: "Hey thanks! It seems they really don't want you to work on the motor on this particular saw. Thanks again for your help. "
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
  • 384 Answers
SOURCE: How do I align the saw blade with the saw table
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Posted on Sep 15, 2009
  • 8404 Answers
SOURCE: my delta 36-650 table saw 1.5hp motor dims lights
If you didnt replace your switch ... do so now. If you did replace the switch, check your work
Posted on Oct 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: having trouble removing the motor from the bosch
tilt the saw head and then use a screwdriver to gently pry apart. the bearings in the housings are keeping it from coming apart or the armature and or field are melted causing this, either way the screwdriver trick will work.
Posted on Dec 08, 2009
Motor won't stay running
This maybe the Run capacitor. If not handy, remove and bring to a motor shop as some capictors are internal!
Mar 07, 2013 | Delta X5 3Hp Left Titl Unisaw with...
I have a biesemeyer 52inch fence on my delta unisaw I have had about ten yrs. The fence has always wOrked great. But now the fence will not lock, making using the saw next to impossible PLEASE HELP!!!!!!!
Prob needs the plastic pads that hold the position when locked. should be readily available at any Biesemeyer outlet as they are replaceable.
..or make your own.
Feb 12, 2013 | Delta 78-918B Biesemeyer Fence Table Board
TABLE IS PLUG MOTOR IS NOT RUNING
There may be an overload reset button on the motor (usually red). Check for a reset
Oct 23, 2012 | Delta 36L352 10" 3 HP 220V Single Phase...
Blade is not square to table of 10" cabnet saw is there an an adjustment somewhere
The adjustment for the Delta cabinet saw (Assuming you mean the Unisaw model) is made by loosening the four bolts that hold the cast iron table to the cabinet and adjusting the table to square it to the blade. Make sure you retighten them a little at a time and working on opposite corners as you go so that you tighten them all evenly.
The only adjustments for the blade are the stops associated with the tilt of the arbor. While you have the top loose, it's a good opportunity to clean up the inside of the saw.
Feb 07, 2011 | Delta Saws
Delta Planer MODEL Delta unisaw Model 34-761
sorry took so long, go to Dewaltservicenet.com and type in your model number with the dash and you can download a parts explosion and manual it is 28 pages long, if I have helped you with your request would you please rate this reply accordingly.
Oct 06, 2009 | Delta Saws
Delta unisaw W/LVC
I think this is what you're looking for:
http://media.ptg-online.com/media/dm/OwnersManuals/20040331153155_En438-01-655-0002-04-01-04.pdf
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 29, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Lost Owner's Manual
click this link to download your owners manual -->click here<--
Please take the time to give this solution a "Fix Ya" rating.
Thanks for using Fix Ya
Jan 31, 2009 | Delta X5 3Hp Left Titl Unisaw with...
Saws Logo
60 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
