Question about Toshiba Satellite A305-S6853 Notebook
I cant play dvds on my laptop.
My CD/DVD drive is gone. The lighis not going on. It won't open up and is not listed in device manager nor in My Computer. Is there something I can do to get it back? Thank you!
  • 298 Answers
Reboot
Reinstall the last SP you installed
reboot
try again
Posted on Jan 18, 2009
2 Suggested Answers
praky16
  • 744 Answers
SOURCE: another question!
hi. you are saying that ur cd/dvd drive is not supporting in ur system. i think the only way is to go for a replacement of ur drive or else if u have another drive u can use it
Posted on Jan 19, 2009
I have a tsstcorp cdw/dvd ts-l462d combo drive in a laptop. I can read and play DVDs and CDs but I can't burn anything.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Feb 03, 2013 | Computers & Internet
My hp pavalion dv6910 dvd/cdw driver is missing
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope it helps
Apr 25, 2012 | HP Pavilion DV6910US Laptop
My cd won't play
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Apr 06, 2012 | Dell Computers & Internet
My LG DVD ROM Drive can play CDs but can't play DVDs anymore just recently
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Aug 06, 2011 | LG (DRD-8080BB) DVD Drive
HP Media Center m7250n will not play DVDs. It plays CDs just fine. It used to play DVDs but has not played them in quite a while.
that seems strange if it reads cd's it should read dvd's
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jul 22, 2011 | Computers & Internet
Does it Play DVDs
you will need a dvd rom to play any dvd's on a computer if you are having problems with your dvd player make sure all leads that are attached to your cd/dvd floppy drives have secure connections and are not faulty or just replace them they are probably old and faulty ?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 10, 2011 | Computers & Internet
My gateway laptop's dvd/cd drive stopped working, all of a sudden, but it plays music cds, it is just the DVDs that don't play them or even explore... what could it be the problem? how do i solve it? it...
Are you sure yours is a DVD player? It could only be a CD-CD writer, which will NOT play DVDs.
Open your control panel ->system->hardware->device manager and click on the DVD/CD-ROM drives icon. The listed devices will tell you if you really have a dvd player or not. If you do really have a dvd player, try a different dvd
Mar 19, 2010 | Gateway MX3228 Notebook
It doesn't recognize/read/play cds or dvds that
Hello there:
first off i would go to device manager and open it and look for the area that says disk drives and open it and look for your cd/dvd right click on it and select remove than confirm removal of the device now at the top of the page you will see view and click on it and where it says scan for hardware change select that and then windows will install the device again you will see new hardware found on the taskbar and it will tell you when the device has been installed and is ready to be used. ok?
i hope that this information is very helpfull for you
please rate this information i have provided for you ok?
best regards mike
(USN RETIRED)
Aug 04, 2009 | HP Disk drive - CD-RW / DVD-ROM combo -...
Another question!
Jan 18, 2009 | Toshiba Satellite A305-S6853 Notebook
My dvd drive in my computer won't play dvds
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A305-S6853 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
