Question about Traxxas Toys
Glow plug starter is draining the battery
Glow plug stater battery drain s in a few starts
    Master:
  • 482 Answers
Those glow plug batteries must charge for several hrs
Posted on Mar 07, 2013
What can drain the battery on suzuki bouevard s40 very quickly?
Hi,first of all to find out if the battery is faultyor if you have a drain on your bike when its switch off,get one of thoes electricle screwdrivers with the light inside it and the wire that comes out of the end of the screwdriver with a crockerdile clip,
leave the ignition turned off,undo the earth lead from the battery,connect the crockerdile clip to the earth lead then touch the screwdriver blade on to the battery earth if the screwdriver dosnt light up then you havent got a drain on the system,when you say it drains the battery dose that mean that the bike loses power and the lights dim,if it is this then the stater is faulty,but if the bike still runs propperly but wont start the bike on the starter then the battery is faulty,I hope this makes sense to you,all the best.
Aug 13, 2015 | 2008 Suzuki Boulevard S40
Starter will not engage, acts like not enough power from the battery
A test for a battery drain in the vehicle is to place a test light between the battery positive terminal and the battery positive cable,with the cable disconnected from the battery.If the test light glows bright you do in fact have a power drain.Pull one fuse at a time until the test light goes dim or off and then you will know which circuit is draining the battery.If no fuse removal dims the light,then disconnect the alternator output wire to check for a bad diode draining the battery in the alternator.Do not open doors or trunk etc and cause a accidental drain masking the real drain.DO NOT try to use any accessory or start the car with test light connected.
May 01, 2017 | Cars & Trucks
Remove stater from heritage softail
Hi Anonymous, here is the short version. Disconnect battery negative cable, drain and remove primary cover, remove starter jackshaft bolt while holding pinion gear, chrome starter end cap, all cables and wires, starter mounting bolts, remove starter. Good luck
Jan 28, 2014 | Harley Davidson FLSTC Heritage Softail...
Complete battery drain
Lets start at the beginning. You check the battery first to make sure a dead cell is not draining the battery. If the battery checks out ok, you disconnect all of the circuits on the truck and then check each one to find out what is "on" when everything should be off.
One thing to check is the relay for the glow plugs.
Jun 13, 2012 | Cars & Trucks
My 97 suburban doesnt start after sitting for a while or pvernight
This can be due to many reasons but I can list you few which you can check out.
1. Possible that the battery is down , if good the GLOW PLUGS can be faulty as it fails to heat to the required temperature.
2. The fuel pump calibration is faulty - low pressure or a fault in the injectors specially if you experience shudder and improper idling.
3. The fuel must be checked, if there is any impurities or water.
4.Low compression ratio on the cylinders thus reducing the perfect compression ignition.
5. finally if the cranking speed is bad , the starter motor or the drain on the battery when the glow plugs are used and the engine started.
Thank you for using fixya.
Aug 25, 2011 | 1997 Chevrolet Suburban
My 2003 Renault Megane Scenic 1.9dci expression won't start
The funny sound you mentioned must be identified, could it be the starter trying badly to turn. Here the fault of your battery drain is that the glow plugs take a lot of current and it must NOT come ON when the starter motor runs. Hence the fault could be your GLOW plug relay unit with the auto cut off timer that is faulty. If you keep draining the battery to a lower threshold level , there is every possiblity that the battery life will be lowered . I hope the present battery rating is the recommended Amp/hr rating to give the extra run for the morning start. Next area of suspicion is the starter motor itself , it could have a bad commutator or a bush. It will be good to have a clean up and service. Finally check for excessive drain on your battery with a current check in series for the drain current when the switch if off. If the current exceeds the limit disconnect each circuit to confirm. hope this advice helps. good day
Jul 22, 2010 | 2003 Renault Sportwagon
Stater replacement for 2001 4.0 Aurora? How many hours and is the starter under the Intake Manifold like the lexus? No click and poer drained when I turn the key. Wonder if the motor seized. Noted power...
If motor was seized, there would be a big power drained when trying to start it, check make sure battery is fully charge, and have good battery terminals connection's, starter labor flag time is 2.4 hrs.
Jul 21, 2010 | 2001 Oldsmobile Aurora
I have a 2002 dodge dakota 5.9 eng. the battery drains down in a few hrs. could it be my stater.i noticed several times before when the eng,got hot &if i shut it off for some reason then would try...
HI. I would start by isolating the actual drain.
Here is a procedure I use to isolate a battery drain. Remove the negative battery cable from the battery. Using a 12-volt test light, hook one end to the negative battery post the other end to the negative battery cable you have just disconnected. The test light will glow or "light" if there is a drain. If the "light or glow" is faint, that is probably normal draw for the clock or computer. If the "light or glow" is bright, this will indicate a large drain is present. That should be corrected,asap. Now start removing and replacing the fuses one by one until the light goes out; The one fuse that causes the light to shut off, will be the circuit with the drain. Remember to close the car doors, when testing. If not, the interior doom light will interfere with the results of the test.
Once you have isolated the drain, have it repaired, asap.
Dec 26, 2009 | 2002 Dodge Dakota Club Cab
1998 GP1200 Engine start problem?
your starter brushes are stuck you can try tapping the stater to unstick them but u will pobally need to replace the starter u can get it on ebay
Jun 17, 2009 | Yamaha 12V Air Pump
My battery light is showing on the dashboard.So I replace the battery,alternator and starter.But the battery still on.I've gone thru two new batteries.Because the battery keeps on draining until its no...
Here is a procedure to isolate a battery drain I found elsewhere and has already proved very useful several times.
Remove negative battery cable from the battery. Using a 12-volt test light, hook one end to the negative battery post the other end to the negative battery cable you just disconnected. The test light will glow or “light” if there is a drain. If the “light or glow” is faint, that is probably normal draw for the clock or computer. If the “light or glow” is bright, then there is a large drain. That should be corrected. Now start removing and replacing the fuses one by one until the light goes out; that one will be the circuit with the drain. ***Remember to hold in the button in the door jam for the interior lights.***
Jul 22, 2008 | Mercury Mystique Cars & Trucks
Toys Logo
61 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
