Question about Lincoln Electric Ranger Gxt 250 Amp Generator/Welder 125 Volt, 250 Amp, Model# K2382 2
Have a lincoln 250 ranger arc welder, will start on starting fluid, but wont stay running. has full in carb.
5 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: lincoln ranger 250 voltage problem
Check the current control resistor with an ohm meter. The center terminal should have a smooth rise or fall of resistance when measured to one end or the other of the resistor. If the resistor and the wiring to it are OK, check the shunt in the output it'll be by the "electrode" terminal. If both are OK you probably have a bad control board.
Regards,
Carl
Posted on Feb 23, 2009
  • 518 Answers
SOURCE: my lincoln ranger 250 no weld output
sounds like the transformer winddings which generate the amperage for the arc are breaking down
Posted on Jul 07, 2010
ROMOAS
  • 97 Answers
SOURCE: where is the serial number stamped on a lincoln
their will be a K # ser# and code# at the top left of the face just the hour meter these are the numbers you will need for ordering parts if you need engine parts you will need to look as where the engine mounts to the lower caddy their will be a boss with engine ident their as well their can be a stamp on the block by the carb mount their wont be other #'s for the welder it self the numbers that will be stamped will be part #'s like on the gen unit it's self.
hope this helps
Posted on Sep 02, 2010
Testimonial: "You are awesome! Thank you so much fo;r your prompt professional response"
SOURCE: HAVE A LINCOLN ARC 5000
I know whats wrong licoln is a giant peice of **** i had this same thing happen to my ranger 8 look at your pc board 2 chips fell out ill bet on it
Posted on Nov 15, 2010
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
What is wrong with the idle on my welder? the switch works , it idles up when I switch it on high and it idles down when I switch it down but it wont go up when I strike an arc or use power tools, what...
There is something wrong with the auto load sensing switch which is part of the generator. That is the sensor that detects when current load from the generator drops as in when you strike an arc or turn on a power tool and cranks the throttle to full power. It is obviously working on manual because the manual switch is cranking the revs up so the solenoid that operates the throttle is ok. My advice is to take it to a service centre that deals in welder/generator sets as you are playing with dangerous voltages and may possibly damage the machine by tinkering with it or fry yourself (nasty)
Jun 27, 2014 | Lincoln Ranger 250 Gxt Welder Generator...
Lincoln ranger 250 will not shut off
Without more info I say it is a short in the switch. If not the switch trace out the wires and look for a bare spot.
Bryan
Mar 30, 2014 | Lincoln Ranger 250 Gxt Welder Generator...
HAVE A LINCOLN ARC 5000 WELDER MOTOR RUNS FINE BUT HAVE NO POWER TO WELD OR RUN ANY POWER EQUIPMENT
Oct 29, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Where is the serial number stamped on a lincoln ranger 250?
hope this helps
Sep 02, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
I have a kohler engine on my ranger 8 welder and i can get it to run for a few seconds then it quits or if i keep putting gas in the carb it will stay running .
sounds like filter/line blockage....check all lines and clear them of any contamination...maybe some dirty fuel or water in fuel has been added into the storage tank.
Jul 23, 2010 | Lincoln Electric Ranger 305D K1727-2...
My lincoln ranger 250 no weld output
Jul 03, 2010 | Lincoln Welding Tools
WHEN I TRY STRIKE AN ARC WITH A ROD YOU HAVE TO HIT IT 5 OR 6 TIMES TO GET IT TO WELD ITS HARD TO KEEP IT GOING BUT AFTER 4 OR 5 SECONDS IT WILL BURN LIKE NORMAL (USING PROPER AMPERAGE)
Is this on new rods as well as one's you'be been already welding with? Depending on rod types, some will "flux over" the end, after welding insulating the tip. When you're welding at a low setting, with a small rod, sometimes it is hard to start an arc. A 7018 rod is a good example of this. Strike the rod like a woodden match, or drag it on the metal, to expose the rod. It also depends on your welder. Some have settings to help start an arc and then control the current. Older transformer welders arn't that smart and are less forgiving on low current thin metal settings.
Jul 02, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been...
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
Apr 13, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Lincoln Electric Ranger Gxt 250 Amp Generator/Welder 125 Volt, 250 Amp, Model# K2382 2 Logo
89 people viewed this question
Top Lincoln Electrical Supplies Experts
 Kenneth
Kenneth
John Trevino
Jay Finke
Jay Finke
Are you a Lincoln Electrical Supply Expert? Answer questions, earn points and help others
