Question about Kenmore Sewing Machines
Thread breaking all the time - Kenmore Sewing Machines
  • Kenmore Master
  • 7,365 Answers
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Posted on Dec 31, 2012
My thread keeps breaking, Ive checked and changed my needle, re-threaded bobbin and upper but every time I try to sew the upper thread breaks.
Have you tried loosening the upper tension? Remove the upper thread, RAISE the presser foot and rethread from the beginning (make sure it follows the correct thread pathway). Sometimes the upper thread jumps out of a thread guide or wraps around something. Or try a different brand of thread? Avoid old or bargain bin threads--use good quality thread. Could also be the incorrect needle for the thread/fabric, ie thread too large for the needle eye.
Sewing Machine Thread Keeps Breaking
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Apr 03, 2016 | Sewing Machines
Threading an overlocker
Many things can cause the thread to break on a serger. Timing, position of the thread guides, poor thread, and improper tension. One common error is the failure to thread it in the proper order. If the needle are threaded before the lower looper they will cut your looper thread.
Jan 31, 2014 | Sewing Machines
My thread keeps breaking every time I start sewing on my pfaff 4.0 sewing machine. O have changed the thread two times. re threaded the needle six times and ensured the needle was in the correct location....
The top thread breaks
8. Try a different spool or cone of thread
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
Kenmore serger thread keeps breaking
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Mar 26, 2013 | Sewing Machines
How do i fix my machine, it's breaking the top thread all the time
Nov 28, 2012 | Sewing Machines
Thread keeps breaking
check to see if there are any burrs in that area
May 24, 2012 | Husqvarna Sewing Machines
Breaking threads... you so about an inch and it
It sound like it is not threaded properly or the tension is too tight, You should be able to pull on the thread manually without breaking it
look for your manual here
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3
Jan 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
Thread breaks off
Where does it break? You change tension at the top via the tension discs the thread passed through, and at the bottom by adjusting the small screw on the bobbin case - the screw on the front part of the spring. Thread size matters as well as needle size. For everyday upholstery I use #69 nylon thread, and "G" bobbins.
If the thread's breaking at the hook you may need to adjust timing. But most commonly thread breaks because of improper tension, threading, needle or thread size.
Mar 22, 2009 | Consew 226R-1
Thread breaks when embroidering
Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
Jan 04, 2009 | Husqvarna Designer I
Thread breaka
First, make sure that you are threading the machine properly check your manual for right thread path.
Secondly, make sure you are using an embroidery needle.
Dec 13, 2007 | Baby Lock Esante
Sewing Machines Logo
26 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
