Question about Life Fitness Exercise & Fitness
95 ti life fitness display board not working - Life Fitness Exercise & Fitness
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Replace dispay pcb
Posted on Nov 05, 2013
4 Suggested Answers
  • 16 Answers
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Posted on Feb 20, 2010
  • 30 Answers
SOURCE: i have a life fitness
one of two possibilities
one unplug treadmill ,open up the hood and make sure the main power plug on the motor control box is inserted properly then power up treadmill and see if problem is solved
two , the motor control board (mcb) is burned up, the most common cause of this is lack of waxing causing too much friction between the belt and deck board . if you have an auto waxer they clog up if not cleaned at least once a month
if this is the issue a resistor on the mcb usually is burnt
you can check this by removing the mcb out of the steel box , you can usually see the damage and/or smell the burnt electrical odor
if this is the case you need to get the mcb repaired contact glide fitness product in santa ana california 1 866 637 4600 to get all details and options, they have repaired many for me . be sure if you do this that you remove the wax board and small electrical unit on the outside of the box and put them in a safe place as you will have to put them back on the new box the cost is $200 which is a deal considering a new one is $1000 note that glide has a non clogging wax available to resolve this friction issue
good luck
Posted on Jan 28, 2011
  • 30 Answers
SOURCE: One of our Life Fitness 95 Ti treadmills had smoke
remove the motor control box from under the hood, there is the motor control board (mcb) and capacitors inside the box remove the mcb and check for damage and /or burnt electrical smell also inspect condition of capacitors (4 round cylinders)
if this is the cause you need to get the board repaired
contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping details i have had many repaired by them .the cost is $200 which is a deal considering a new one is $1000
the most common reason for mcb's burn up is a resistor blows due to overload caused by too much friction between the belt and deck board ,and that could be the result if you have an auto waxer nozzle that is plugged up . these nozzle should be cleaned out once a month
note that glide has a non clogging wax to eliminate this issue you ask them about this as well
if you have to send out for repair , make sure you remove the wax board and small electrical component on outside of box and keep them in a safe place as you will need to reinstall them on the new box good luck
Display showing Motor comm bad
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 02, 2016 | Life Fitness 95Ti Treadmill 95 Ti
Motor disabled appears after a use of 4-5 minutes and machine stops
my Life Fitness 95 Ti can not go faster then 10 km/h.
Please advice
Jun 25, 2013 | Life Fitness 95Ti Treadmill 95 Ti
How to fix a 95t1 motor controller board
you will call to the company for better instruction. They are obligated to supply instruction for fix the control board. Do not waste your time Call them right now.
God bless you
Dec 11, 2012 | Life Fitness 95Ti Treadmill 95 Ti
Management disable
RUN the software calibration for diagnostic,, troubleshooting, and fix it.
God bless you
Oct 08, 2012 | Life Fitness 95Ti Treadmill 95 Ti
Display shows wait and don't start
Dear Sir:
Please adjust the reed switch, clean, and tigh the connector very well.
See the diagram attached. Run after you fix the software calibration.for diagnose, troubleshooting.
sincerely. God bless you.
May 02, 2012 | Life Fitness 95Ti Treadmill 95 Ti
Display in write luberieant
I can not understand you language. Would you please send you questions in english?
sincerely.
e.cuadra
managua, nicaragua.
Oct 19, 2011 | Life Fitness 95Ti Treadmill 95 Ti
I bought a used Life Fitness 95T from a fitness center, the display displayed "please replace safety switch to continue workout". The Magnetic switch is in place but the unit does bot recognize...
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console. 11_30_2011_11_41_39_am.gifThen tight the flexible cords from keypanel vs display board( clean the keypane with spray from contact cleaner. then tight the connector from display board vs main motor controller. Remember the main motor controller has aprox 90% of functions of any treadmills. See the block diagram that I did for people like you, And now you will get powerful strong resultant what is wrong. sincerely. Good luck.
finally 2 options: 1) display faulty 2) Main motor controller of course after you did the first step.
Oct 08, 2011 | Life Fitness 95Ti Treadmill 95 Ti
I have a life fitness 95 ti. when unit is turned on it cycles through it's diagnostics then displays communication error. at that point the unit stays on but does not start belt. this is an intermittent...
good luck
Jan 07, 2011 | Life Fitness 95Ti Treadmill 95 Ti
Display reads IMMOBILIZED....help?
This is because the function is activated Immobilized feature. "
now you must do the following: Press and hold the SPEED Down
Arrow Key and press the Pause Key to
toggle ON / OFF.
and go!
Sep 08, 2010 | Life Fitness 95Ti Treadmill 95 Ti
I work on Bagram AFB in Afghanistan and have a 95
Go To Gymparts.com click on Diagnostics and Repair scroll down you will get in on trouble shooting your problem.
Jun 03, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Exercise & Fitness Logo
82 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
