Question about Samsung 650W 5.1-Channel Home Theater System
"protect" on the screen
Reciever turns off after 5 .sec. with protect reading on the screen.
  • Samsung Master
  • 19,396 Answers
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Can not get surround sound to work
Your Protection System probaly come on for some reason,Sony Is Known for that problem, Check on your screen if a red lit warning Staying (protect) Is on.If there is, Try hiting the reciever on the sides or the top of the cover fairly hard when it is turned on, Some times this will work to turn the protect light back off, Sony is bad for there amps end recievers going into the protect mode,
Sep 19, 2012 | Sony STR-DG600 Receiver
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
I have a STR DE 485 reciever. When I try and turn
unplug,leet capacitors discharge, check back of unit where speaker wire clips are to make sure there are no wire strands touching each other,check same thing @ speakers, try turning unit back on.
Aug 13, 2009 | Audio Players & Recorders
Can send but busy when try to recieve intellifax 4100
unplug, hold down the "stop/clear" key, and while holding button down, plug in fax and hold button for 5 secs. release button and you should see the normal date/time screen. try receiving now.
hth,
razors
Mar 31, 2009 | Brother IntelliFAX 4100 Laser Fax
Auto adjastment locked
Samsung implements protection into their monitors, which allows to block all settings except brightness and contrast. This "Locked" mode turns on by pressing and holding 'Menu' button for 5 seconds, and turns off by pressing and holding 'Enter' button for 5 sec.
Mar 02, 2008 | Samsung SyncMaster 193V 19" Flat Panel LCD...
MY AMP KENWOOD VR-206
that is not a problem. i have the same reciever and it has done that since i bought it. i read up on it and it is a protection feature in case you had the volume cranked when you turned it off it gives you 3 seconds to reduce volume before the amp turns on. that is why you may hear a click when the mute turns off. it is also known as soft clip because if the amp would turn on at the same time as the reciever it could cause a surge to the speakers damaging them. it is a feature not a problem.
Dec 18, 2007 | NEC /5V 073-20674-14.5A Rev51 VXi VRM...
LC37GA8 RESET
You must unplug the unit, and while unplugged depress the volume up and channel down buttons at the same time (the buttons on the tv) and while buttons are depressed, plug the power cord in. Hold the buttons for 1 sec. then release. The unit should no be on in the service mode. A small k should appear on the screen. With the remote press the channel up button. There should now be a menu on the screen where you can see lamp error line. The lamp errors will most likely read 5 and 5 lamp errors in this unit will cause shut down. Use the channel down button on the remote until you highlight that line. Withe the curser right arrow button select the 5 and now with the channe up button you should be able to reset the 5 to a 0. Now unplug the unit and wait 30 sec. before powering the unit. That should return the unit to normal operation.
Oct 24, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Razr v3 bluetooth
all i can say by reading your issue is that , it would have to do with you being on the cycle and moving . but i will check on this for you.
Sep 19, 2007 | Motorola Mobility RAZR V3
Display screen says protected
By your description it looks like an internal protection has tripped. The reset will not work if the unit is fried. Did this happen when you were pushing the unit really hard or distorting it? You may have to have it repaired, or replace it. Repairs can sometimes take a couple of months so be wary of this.
Aug 16, 2007 | Samsung MM-DS80 System
Samsung 650W 5.1-Channel Home Theater System Logo
234 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
