Question about Actron Obd Ii Autoscanner Scan Tool Actcp9175
Code po511 wheres the definition
Try to uderstand what is the problem
Replaced Cylinder Head "Gasket" and Now have PO511 Code. Disassembled and Reassembled in the same order. What did I miss? Could it be a Timing Issue.? I did notice a few degree change.
i bet its fix already , thanks for post back. that you did.
did you google this?
its a bad speed sensor.
511 is idle too high.
vacuum leak?
is idle too high......
lots of things can cause this.
but first is it too high, expecially hot.
or the ISC is unpluged or sticky , (air valves sticking idle air control valves)
Sep 23, 2013 | 2004 Honda Civic 1.7
Replaced Cylinder Head and Now I have a Code PO511?
google finds this 1 second, did you try?
idle controls failures.
idle controls fail for many reasons.
ISC unplugged, is my wild and useless guess.....
the ECU only knows what tests (monitors fail)
in this case IDLE speed is out of control
the scan tool shows you (freeze frame) when and how it failed.
1: ISC sat for 1 weak and the nasty gum in it went solid, causing t
the valve to stick, (very common)
and not connected? the wire connector to it?
2: you left off vacuum hoses or put them back wrong?
and now there is an air leak, making the ISC out of control/?
old post. doing 60day, zero posts
CODE PO511
P0511 is set when there is a circuit problem with the idle air control motor. There are 2 wires that go to the idle air control motor that
could have a open or the idle air control is bad itself.
Dec 06, 2012 | 2003 Ford Escape
I changed my IAC valve on my 2004 ford taurus dohc, and now the rpms sit between 2000 and 2500. I checked it with a scanner and it gave me the code p0511....How can i fix this?
CODE PO511 - IDLE AIR CONTROL VALVE CIRCUIT MALFUNCTION. TAKE VECHICLE TO FORD DEALERSHIP LET THEM RELEARN THE IDLE AIR CONTROL VALVE TO THE PCM. ITS GOING TO COST $35.00 TO RESET.BUT CAR NOT GOING TO IDLE CORRECT UNTIL NEW PART REPROGRAM TO THE PCM
Jul 27, 2011 | Ford Taurus Cars & Trucks
It wont turn at all!
cant uderstand wat u r trying to tell
Oct 21, 2009 | Philips SA3125\02 MP3 Player
Help!
I dont uderstand the question.
The camera uploads OK- Fine.
Now where are you inserting the memory card to get this other reading?
Oct 30, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Actron Obd Ii Autoscanner Scan Tool Actcp9175 Logo
20 people viewed this question
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
