Question about Maytag Neptune MAH5500B Front Load Washer
Door is locked and has a code of FL on panel
I had this happen a few months ago and had the owners manual and got the codes out of it and went ,got the part and fixed it.. my manual is now gone.. need help with the codes
    President:
  • 643 Answers
FL Failed to lock. Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Posted on Dec 31, 2012
  • 1073 Answers
SOURCE: Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Posted on Apr 13, 2008
  • 3 Answers
SOURCE: Maytag Neptune front load door is stuck
Pull cord under soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
Posted on Jun 08, 2008
  • 3 Answers
SOURCE: maytag neptune model# mah5500b
Unplug from the outlet and wait about 5-10 minutes. When you put the plug back into the outlet, the door should unlock.
Posted on Sep 17, 2008
  • 198 Answers
SOURCE: Maytag washer MAH 5500b FL code and door will not unlock.
Open the detergent dispenser door on top of mach. There you will find a small yellow nylon cord, pull on the cord and the door should open
Posted on Feb 19, 2009
aborcass
  • 2651 Answers
SOURCE: Door will not lock
Faulty Latch ,, i would order and replace the latch assy, you acess the latch by removingthe 4 screws in the dispensor assy, the n remove the door, andthe 2 screws opposit teh door hinge. then the front "u shaped" panel will come off and then just 2 5/16" screws on either side will release the main top assembly allowing you to tip it backwards and gaining acess to the latch assy
Posted on Feb 22, 2009
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
Aug 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
I am getting an FL code on my Samsung front-load washer. It happens as I am trying to start a new load. I have loaded the machine, added my soap, shut the door and push the start button. Then it makes this...
Hello Kelli Etienne,
You will need your model number.
"FL" is a lock error (failure)... DOOR LATCH.
Service folks at SEARS will tell you...
"you need a technician"...
I detest SEARS ... after being a faithful Craftsman dweeb
for years... I now find them pushy... distant... pricy
(not to mention incompetent (I had a FULL WARRANTY
but it didn't bother SEARS - Elite washer issue
(3 months @ laundromat... REALLY ANGRY (sorry)).
REGARDLESS their on-line LIBRARY is no-so-bad.
Samsung Front Load Washer Error Codes Sears PartsDirect
However... if you go to OTHER PARTS retailers
you will also find really great VIDEO GUIDES to help.
(same parts... EVERYWHERE... so shop PRICES)
I will only add: ALWAYS TAKE DETAILED PICTURES
BEFORE taking anything apart... (before).
Saves being PUZZLED later.
Go to these sites...
look up your model number & DOOR LATCH.
appliancepartspros
Search Over 2 1 Million Appliance Parts
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
partsselect
PartSelect Appliance Parts and Repair Help
Carnac the Magnificent
Mar 20, 2017 | Samsung Washing Machines
Acura CL 98 drivers door lock don't open from inside or key. can't open door. how to remove panel with door lock
HAD THE SAME PROBLEM THIS YEAR, PROBABLY 6 WKS AGO. WENT TO AN INDEPENDENT SHOP WHO SAID HE COULD FIX IT FOR 65 DOLLARS. HE DID JUST THAT. HAD TO SHOP FOR AT LEAST A MONTH BEFORE FINDING HIM IN LOS ANGELES. I ALSO WENT TO AN AUTO BODY SHOP WHERE THE OWNER SPENT AN HOUR BEFORE GIVING UP.
Mar 18, 2013 | 1998 Acura CL
Not locking
I had this problem also with my Maytag Neptune TL. The door lock would click multiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure either that or sandpaper will do. After that it went through the whole cycle without stopping or displaying the "FL" code.......hope this helps
Jan 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
Fl error code
The "FL" code indicates that the unit failed to lock the door, which would prevent the machine from running. If this happens again, close the door tightly and restart the cycle. If the code reappears, your washer may require service. What is the model number?
Nov 02, 2012 | Samsung 3.5 cu. ft. High Efficiency VRT...
Code reads FL Door will not open. Ran spin cycle on empty to get water out after well went dry.
FL code indicates that the machine failed to detect that the door was locked. Perhaps the controller became confused when the fill failed (due to well). Try unplugging the machine for 15 minutes, and then plug back in. You may get the PF (Power Fail) code, but that is normal. You should be able to start a new cycle from this code.
If the door still will not open, please post back.
Oct 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Door lock mechanism
I had this problem also with my Maytag Neptune TL. The door lock would click muptiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure eaither that or sandpaper will do. After that it went through the whole cylce without stopping or displaying the "FL" code.......hope this helps
Jun 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do i find what an error code means?
if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Sep 02, 2008 | Washing Machines
Error Code FL
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
