Question about SanDisk Sansa e250 MP3 Player
Hey you just told me how to format my e250 so far so good but how do i make another folder to place in the removable disk section
  • 8,596 Answers
Open up the removable disk, right-click in the white space and select New --> Folder
Posted on Jan 18, 2009
My external hard disk has been infested with viruses and files and folders made shortcuts. how can i recover the files and folders?
I have faced same problem. Shortcuts everywhere.
Not once, many times.
I tried many solutions.
Shortcut Virus Remover is the best solution I found.
A 100% free simple application.
You can download it from this link -
Place it in your pen drive and double click to run. Press Enter to confirm its process. That is all. Shortcuts will remove and your data will be back in a second.
Mar 05, 2014 | Computers & Internet
Yes you can format the drive. Make sure you update the drivers if needed as well. I hope this helped.
Dec 14, 2007 | SanDisk Sansa e250 MP3 Player
Dare 2 Read
Sounds like some of your music may be corrupt.
You can use this to get it back to normal;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 12, 2007 | SanDisk Sansa e250 MP3 Player
Player doesn't display some files
where did you get the songs from? make sure the files are in mp3 file format not in another format and make sure they are playing properly before transferring them to the player. The player can support MP3 and WMA files. IF you are sure they are mp3 format the player using USB mode and then retransfer them to the player.
Oct 07, 2007 | SanDisk Sansa e250 MP3 Player
Two problems with my mp3 player
Hi Mina. An internal memory corruption might have occurred on your player, and would need to format your player through "Disk Management" (I'm assuming you have Windows XP or Vista). Here's how: (1) First, set your player to MSC mode by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MSC" (2) Open "Computer Management" by right-clicking on the "My Computer" icon, then selecting "Manage" (3) Your "Computer Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" (4) On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa E250. The lower section also contains the drive # pertaining to your E250. Right-click on either drive letters pertaining to the E250 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. In general, Disk Management is more the effective tool for formatting your E250 and assuming the format processing completed without any errors, you may now use your player as you would. You may want to set the mode of your MP3 player back to "MTP" (if you're going to download subscription songs -- otherwise, just leave it in MSC mode) by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MTP" In case you get the error "Unable to Complete Format" or the format process is unable to complete, you may want to call the SanDisk Tech Support guys for more advanced troubleshooting (I call `em when I'm at my wit's end lol) I hope it works :)
Jun 02, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs from Sandisk
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
SansaE250 Startup and intial setup problems
download the latest firmware from 7/?/2002
I had this problem too and tried all kinds suggested solutions. The main problem was that no computer would recognize the e250 in MTP mode--which is what you need to transfer songs with DRMs from Rhapsody or similar services. The latest firmware fixed the problem.
I gave up on the whole thing about about a year ago. What a waste of precious time that could have been spent in nerdy musical bliss.
Apr 04, 2007 | SanDisk Sansa e250 MP3 Player
Plug the camera into the computer using the usb cable supllied. When the removable disk appears in the "My Computer" section, right click it and click "format". Format at fat32 and then click start. This may take up to 1 minute to do depending on speed of computer and size of disk. If that fails, create a folder in the removable disk.
Feb 18, 2007 | Vivitar ViviCam 3785 Digital Camera
[Sansa e250] Deleted songs and now...
what you really have to do is: 1: Double click my computer 2:Double click Sansa e250 drive 3: Right click on the icon that looks like a disk drive and click format BE SURE TO HAVE BACKUP OF SONGS BEFORE YOU FORMAT!!!
Jan 06, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
