Question about eMachines ET1641-02w (PT.NA60X.001) PC Desktop
What is the motherboard in a eMachine 1651-02w?
I have looked every where and can't find the answer to a simple question. What is the motherboard type in an eMachine-02w? Is it an ATX, an ATX mini, or is it a custom job done by the company. I had my eMachine 1641-02w die on me this week and I figured on using the tower to build a new computer but need to know the orginal board in it first.
    Guru:
  • 261 Answers
Ronald,
I was able to find some information about your e-machine. Please click on the link below and scroll down to motherboard section to find the motherboard type.
http://www.skyline-eng.com/index.cfm?fuseaction=category.display&category_id=7768
This was the only to get that info since i don't have this machine. I hope this helps!!!.
Regards,
Anish
Posted on Dec 30, 2012
4 Suggested Answers
SOURCE: an intel celeron D socket 775 ddr2 motherboard for w3560 desktop
yes a mid sized. and it is call mATX for the form factor.
-socket 775
-DDR2
-PCIE
-mATX
Posted on Jun 05, 2010
  • 26 Answers
SOURCE: i have emachine ET 1641-02w check the power supply
I will assume that you have not messed with anything and it just stopped working. So try these steps:
1) Check the power plug, make sure it is plugged into the wall and also into the back of the computer.
2) Check to see that the switch is "On" on the back of the power supply if there is one.
3) Take the case off and look at the power button, try to press it without the case on, perhaps the power button is broken. If that doesnt work try and see if the little wires on the back of the power button are connect and bot pushed off.
4) Check the cables to the power supply, ensure they are connected to the motherboard and not disconnnected.
5) If all of the above do not work, take a power supply from another system and plug it in to *********** board, see if the computer boots normaly then. If that works you can assume the power supply is shot.
Let me know if there is anything else.
-Paul
Posted on Jul 12, 2010
tonys_tiger
  • 791 Answers
SOURCE: I need a W2040 motherboard wiring diagram
must be easier to move the hd to a hd-caseing and start transfer to a another computer......to much time-consuming.
Posted on Mar 27, 2012
Which prongs on the motherboard are used for on/off switch & led?
Try this link http://www.quietpc.com/files/download/streacom/power-switch-FC5.pdf
Aug 09, 2014 | E-Machines eMachines Desktop PC
Emachines EL1352 motherboard
It\'s an Acer MA061L-3D (part number) according to this,
http://www.ebay.com/itm/Emachines-EL1352-01e-EL1352-23e-EL1352-43-EL1352G-41w-Motherboard-DA061L-3D-8120-/350653705586?pt=Motherboards&hash=item51a496ed72
I\'m guessing made by Foxconn
For additional questions please post in a Comment
Regards,
joecoolvette
Apr 18, 2013 | Computers & Internet
Emachine T5234 beeps 5 times and won't turn on
5 Short BeepsYour motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
Aug 15, 2012 | E-Machines eMachines Desktop PC
My emachine T2958 would not boot. the fans run but no bois nothing. i realise on the mother board alight is on by the letter F.Is it the motherboard ? help please
A good way to tell is disconnect your hard drive's, & CD/DVD ROM's power & data cable. Try to boot.
If you get the same results then you can try & remove any PCI cards from the board, remove your ram stick. Try to boot. If you get an error beep because you are missing ram than this is good.
Replace 1 ram stick back into your motherboard & try again. If it boots then you know the other stick is bad.
If removing all the non-essentials from your motherboard doesn't work then all you have left are the motherboard & power supply. A simply power supply tester or spare power supply will tell you if it is your board or not.
Jul 16, 2012 | eMachines T Computers & Internet
What's your problem?eMachines D440-1047 what processor have y which motherboard have plis
Here you can see the specs:
http://support.gateway.com/emachines/notebook/2010/emachines/emd/emd440/eMD440sp2.shtml
Processor = AMD V Series processor V120 (2.20 GHz, 512 KB L2 cache, DDR3 1066 MHz, 25 W)
Chipset = AMD M880G Chipset
Jun 25, 2012 | E-Machines Computers & Internet
Mar 27, 2012 | eMachines W Computers & Internet
T6216
There should be 2 rows of pins in parallel usually around the bottom edge of the motherboard. The markings for which is which should be next to them on the board. HDled+, HdLed-, PwrSw, PwrLed, or something similar.
If you do find them but the hard drive Led does'nt come on it's because the plug for it needs to be turned around the opposite way, Led's only work one way as they are diodes. Same for the Power Led.
If there are no letters near the pins then you would have to find the motherboard manual.
Jan 28, 2012 | E-Machines eMachines Desktop PC
I have an emachine T3828, I have recently reformated my hard drive, And now missing Audio Drivers. I have tried going through Device Manager and doing "Update Drivers", also have downloaded all I can from...
This isn't a sound issue this is a Virtual IRQ issue. Emachines are virtual machines. That means that all of the hardware is emulated by the software through the motherboard. The PCI Simple Controller is the Emulation IRQ. You need to install your motherboard's chipset drivers again. Since Emachines are emulated hardware nearly everything is tied into something else, often the time its things not related to each other. Download http://www.soft32.com/download_182376.html which is a driver for the PCI Simple Com and see if that helps.
Apr 20, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
eMachines ET1641-02w (PT.NA60X.001) PC Desktop Logo
100 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
