Burning rubber smell water leaks onto floor
It sounds like breaks squealing to the halt at the end of spin cycles. We had to replace the lid switch about 1 yr. ago. The washer was working fine, did a 2nd load, it sounded fine, but I noticed it wasn't making a squeal after what was about 30 mins. I checked on it, it sounded like the motor was running but it smelled like when a belt breaks on a vacuum. We tried changing the belt, and ran a "mini" load of 4 towels. It filled, agitated, acted like it would spin but wouldn't drain and began to leak into the floor.
  • Ange Jones Dec 30, 2012
    This is a Maytag Atlantis MAV7650AWW
  • Washing Mach... Master
  • 17,130 Answers
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Posted on Dec 31, 2012
  • Ange Jones Jan 03, 2013
    OK, we have made it so that we can actually watch where the water is coming from. My husband put the machine up on bed risers and brought in the new oil change pan we bought to catch the drips. It appears to be from the drain pump. We are going to take it apart, see if there is a clog, then replace the seal if not. Thanks for the input!
My calypsal washer smells like burning electrica or rubber in the spi mode
The motor could be leaking oil. Pull the machine out and look for stains or puddles on the floor.
Oct 07, 2012 | Whirlpool Calypso GVW9959K Top Load Washer
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
Washing Machine shuts off by itself during cycle
Not sure what you are saying.. if washer is off balance, it will shut off, check legs are secure to floor and unit is leveled. If washer lid isnt sealed or lid switch is bad it can shut off at spin or start cycle. Depends on unit model. The smell can be a burning belt from a heavy wet comforter or you have mildew from water not properly drained from unit.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Jan 26, 2010 | Maytag Dependable Care LAT9206
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
It made a quite hum during the spin cycle, instead of the normal (much louder) spinning sound. When I turned it off I noticed it had a rubber/electric burning smell.
If it's a squealing sound, your belt is probably bad. If it's a humming noise with those smells you listed, it might be your transmission going bad.
Nov 02, 2009 | GE WBSE2090A Top Load Washer
WILLNOT SPIN OR AGGITATE/IT WILL DRAIN
Just because the rubber part of the coupler isn't shreded doesn't mean that the plastic parts are not broke... There are three stems that protrude from the plastic parts of the drive coupler,and mesh with the rubber section of the coupler... the stems may be broke off... If you smell rubber burning then I would say almost 99% of the time it's a bad drive coupler...If the coupler is not broke and the rubber section is alright then you have a bad transmission... Most likely the main drive gear is bad... Since you said that you can spin the tub by hand, indicates that the brake system is alright, and nothing is caught between the inner and outer tubs... You can rule out a lid switch problem, cause the washer would agitate even with a broken lid switch, but it would not spin..since the machine make any kind of different sound when you run it Like a high pitch squeal or grinding noise?
check the lid switch see if it's not broke... wasn't the lid switch, but I got to thinking it will agitate at the first part of the wash cycle, but when it goes into the slower speed wash, if your lid switch is broke, then it won't agitate or spin...
Feb 10, 2009 | Kenmore Washing Machines
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
