Question about APC Conext 900VA (cnb900) UPS System
No indicator lights after replacing battery
I have a Context 9000 BU. I replaced the battery but now the battery backup part does not seem to work nor do I have any lights. Pressing the on/off button has no effect. I can feel the unit click on when plugged in. It worked perfect until I replaced the battery. I replaced it because it started to beep. I put the old battery in and it does the same thing. The unit is about two years old
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
I have one question, have you connect the battery terminal correctly the first time you install your new batteries? If not, it might be your battery fuse is blown during the process :) check your UPS battery fuse.
Posted on Feb 20, 2013
  • German Sarmiento
    German Sarmiento Feb 06, 2015
    I have the same issue as described above with my 2 year+ Conext 900 AVR UPS system. I checked that both, the AC overload breaker and the battery fuses have continuity. New battery and AC power are Ok but system's indicator lights remain off. What should I try next?
SOURCE: A smart ups 1400 stopped working
First cheack the supply if supply is present the then cheach the cable which is connected between power supply and the ups if this things are working properly then open the ups and then go to the power supply section by tracing the ip put from the power supply switch you will find the fuse over there
Posted on Dec 18, 2007
SOURCE: low battery alert on my apc - ups es350
Have your supply voltage and frequency checked under load.
/bz
Posted on Mar 11, 2008
gotgeek2
  • 565 Answers
SOURCE: APC Backup UPS Model # BK200C salvageable?
Yes, but the battery may not be any good, though, and trying to charge it may damage the charger. A new battery is about $20. The surge suppressor will still work without the battery as long as it is connected to a properly grounded 3-wire circuit. If you decide to take a chance and charge the old battery, take precautions like keeping a watch on it should it explode or catch fire. Not trying to scare you, just looking at worst case scenario.
Posted on Jan 27, 2009
  • 28 Answers
SOURCE: It's an older unit that i just tried. When i plug
Try installing the software that is included with the unit. If you didn't get the software, I believe you can download it for free from APC's website. The software will typically give you the status of the batteries and let you know if you need to replace them. If you can't get the software, take the batteries out (keep note of the wiring configuration) and test each battery using a DC voltmeter. The batteries should read around 13.5 volts DC. If they are around or below 11.5v DC, it's time for new batteries. This model, if its the black 110v version, requires the RBC32 which can be found at: http://www.batteryinternational.com/apc-rbc32--f2.html
Good luck and I hope I could help.
Posted on Jul 01, 2009
pravinbhavsa
  • 348 Answers
SOURCE: hace a APC XS 900 that said battery needs
disconnect one terminal of the battery then measure charging voltage betwen +ve and -ve it should be 13.8vdc for one 12v battery if charging voltage is not present then battery is ok then connect ammeter to measure the current in Ampere .take care it should be in series if current if no current then battery must ok opern the ups there is a charger transformer measure i/p voltage to transformer if not present then check i/p path if present then check diodes at o/p of charger if faulty replace it also check capacitor and regulator ic if faulty replace it your problem must be solved
Posted on Mar 14, 2010
Testimonial: "There is no way to check the water in the batteries as thry are sealed. I found out that after a load is applied it goes on battery for a few seconds "
My 2001 Pontiac Grand Am GT reverse light does not work on my driver's side. I need to get it fixed by the end of this week in order for me to pass the safety inspection. I need help fast!
Backup Lamps
Vehicles equipped with an automatic transmission, the BU LMP fuse in the IP fuse block supplies battery positive voltage to the park/neutral position switch. Vehicles equipped with a manual transmission, the BU LMP fuse in the IP fuse block supplies battery positive voltage to the backup lamps switch. When the driver places the gear selector lever in the REVERSE position, the current flow is from the park/neutral position switch or the backup lamps switch, to the back up lamps. The backup lamps are grounded at G401 and G402.
Do a voltage drop test ! This show which side of the circuit has the problem , power or ground ! Here is a video from youtube ! Buy a cheap DVOM .
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Jun 01, 2017 | Pontiac Cars & Trucks
Troubleshooting back-up malfunction after replacing battery. Checked main power supply breaker and battery power supply fuses for continuity. What should I try next?
Depending on the type of unit, you do not state any model. It may require 6-8 hours of being plugged in and turned off before the battery has enough charge that the ups will turn on.
Feb 08, 2015 | Power Computers & Internet
I just replace the battery in my APC RS 900 unit because the red indicating light was telling me to do so. I installed the new battery and the red indicating light is still telling me to replace the...
Sorry to read about your problem, I hope this helps you out.
let it charge 24 hours, and see if it works
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | APC Back-UPS RS 800VA UPS System
I can't tell if the battery needs to be replaced in our Belkin 900. Should the green indicator on the front be completely lit up? Only one seems to be.
Link to manual:
http://cache-www.belkin.com/support/dl/f6c900.1100unv.pdf
Turn on your UPS by pressing and holding the On/Off/Test
button for approximately 2 seconds until the “ON LINE” Green LED
comes on. Pushing the On button less than 2 seconds is a test function.
Simple test: plug a light into one of the battery backup outlets. Then unplug unit. If the light stays on then it's working and the battery is ok.
Mar 02, 2010 | IBM Belkin Enterprise 900VA (31P7076) UPS...
Battery charging
I assume that your charger work fain and suggest to change your battery cause its seem that its gone.
Jul 19, 2008 | Black & Decker 50 Watt Electromate with...
Indicator Lights
Hello kingfisher1
You can find the owner's manual for the Minuteman Pro 520 UPS HERE.
You can find support for Minuteman UPS' HERE.
Refer to page (4) of the owner's manual for a description of the UPS' front panel controls and indicators.
Looks like if the 4th LED from the right is on, you need to replace your battery.
Left to Right the LED's are:
(1) Online; Boost; or On Battery (depending upon the symbol that is illuminated)
(2) Fault
(3) Overload
(4) Replace Battery
Please, let us know if you have any more questions, observations, comments, etc. on this topic. We are happy to help.
Thank you
BJ @:)
Apr 15, 2008 | Minuteman Pro 520 Battery Backup...
APC Conext 900VA (cnb900) UPS System Logo
292 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
