I need a 150uf 450vw capacitor where can i buy one online
  • joetaylor78
    joetaylor78 Jan 01, 2013
    i called digikey and the tec set me up with what i needed ty for the suggestion
    Sergeant:
  • 475 Answers
Look up the manufactor or company and you might be able to buy from that company you bought it from.Or radio shack?
Posted on Dec 30, 2012
Found start capasitor bad.Have ordered two cap. of like (250vac 150uf) and both have gotton hot & blown after about two minites of running. Any ideas?
The start capacitor should be, i think 370V or 480V . Measure the voltage across the capacitor while the motor is running and you'll see. The farads may be right but the voltage no, voltage should have been matched to that of the original capacitor, or higher voltage rating
Aug 25, 2015 | Air Tools & Compressors
Dell w3000 will not turn on at first try. Takes many attempts turning it off and on before video comes up. Audio always works and green light is on.
Faulty caps, if you take the back cover off of the monitor, there are 2 boards on the outside edges of the left and right of the monitor. these boards are covered by metal shields. remove the 3 screws on each board shield and slide them off.(careful this can be tricky) on the boards are 2 capacitors that need to be replaced. 4 total, 2 on each board. the capacitors are 150uf at 35 Volts. go to your local electronics repair shop to get the parts and tools needed to do this repair.
make sure to get the polarity of these caps right. stripe side on cap goes to the minus.
Dec 18, 2010 | Dell W3000 30 in. HD-Ready LCD Television
Our tv is about 12 years old..color is good.but we have waves throughout the tv with a hard to see bigger wave scrolling from top to down..worth fixing?
You have the classic signs of drying up electrolytic capacitors in the power supply section.
If the main smoothing capacitor is low value, then that will produce your described fault.
Assuming you are aware of the safety issues when repairing high voltage electronics, Find the large high voltage high capacitance capacitor, it will be near the main bridge rectifier after the mains fuse, remove it and fit an identical new one. Its value will be something like 150uF at 400Volts or higher about 1.5" diameter and 2.5" tall. Maybe blue in colour or black, possibly orange depending on manufacturer.
Check the other capacitors while you are there as if one has failed some others may also fail.
Hope that clears your fault for you and be carefull!
Nov 28, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Samsung lnt3242 has power but won.t turn on
Seems like you need to repair or replace the inverter boards you can get them here: CLICK if this helps please rate ;-)
for more information contact me here: http://tvtechwork.webs.com/
Oct 23, 2010 | Samsung Televison & Video
I get a green power button, no picture. I have to turn the Dell TV on 6-10 times beofre picture comes up. What is wrong with it?
I have this tv, and have had the EXACT problem. my solution was simple. if you take the back cover off of the monitor, there are 2 boards on the outside edges of the left and right of the monitor. these boards are covered by metal shields. remove the 3 screws on each board shield and slide them off.(careful this can be tricky) on the boards are 2 capacitors that need to be replaced. 4 total, 2 on each board. the capacitors are 150uf at 35 Volts. go to your local electronics repair shop to get the parts and tools needed to do this repair.
make sure to get the polarity of these caps right. stripe side on cap goes to the minus. 1
Mar 28, 2010 | Dell W3000 30 in. HD-Ready LCD Television
MODEL DLT37C3 KEEPS TURNING ITSELF TO STANDBY WHEN
Mine did this to. Opened up the back cover, the power circuit board is clearly visible, on it is a HUGE electrolytical capacitor 26mm in height x 35mm in diameter 150uF 450V. Changing this for a new was the cure for me. Might work for you as well! Please be careful, the capacitor can hold a high voltage even after power is off and cable removed, make sure to remove the powercord! If unsure ask someone that can solder to do it.
You will need a soldering iron (quite powerful) and some solder to change it.
Feb 28, 2010 | Daewoo Televison & Video
Green flashing light on but tv won't turn on
Check capacitors on the power board. Two 1000 uF 25V and one 150uF 400V.
Jul 15, 2009 | Apex Digital LD1919 19 in. LCD TV
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
