Question about Hitachi Ultravision P50S601 50 in. Plasma HDTV
How do you adjust color allignment
Blue is not centered majicfocas no help
    Sergeant:
  • 214 Answers
There is no adjustment for that like old CRT tv's convergence rings. The set needs repaired.
Posted on Dec 30, 2012
The colors are unalligned and the picture is blurry
hello,,the deffective part of your tv probably the convergience ic,it is a 2 pcs big ic with heatsink mounted on the mainboard you can replace it with a new one..or try to adjust first the allignment of your cathodes the RGB cathodes..on your front pannel there is a convergeance manual allignment button use this button to allign the convergeance..on your remote control there is also an allignment command consult your manual for the command .after the adjustment you must save the adjustments before exit the convergeance adjust..if thris adjustment do not work replace the convergeance ic ..mostly the ic is labeled STK XXXX..
GOODLUCK i hope i this helps you..
please rate my help tnx.
May 29, 2010 | Philips 51PW9303 51" Rear Projection...
The blue crosses are too far right of center to adjust
you will need to install a convergence repair kit. You can get the convergence repair kit for your model at www.tvrepairworld.com which also contains the CD with step by step instructions for the repair.
Mar 28, 2010 | JVC AV-48WP30 48" Rear Projection...
Picture bounces
Chances are the mirror is out of allignment or loose that projects the image on the screen from the lights below. This is a delicate adjustment that should be done by a professional service center. I hope this helps, good luck.
Sep 24, 2009 | Televison & Video
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
I am getting a double image on my 48 inch television how can i get rid of it? it is showing colors green and red on double image
Assuming that your TV is a rear-projection TV, then it sounds like the separate red, green & blue tubes aren't set correctly.
Each tube needs to be alligned exactly to produce the image on the screen. If any of the 3 are mis-alligned then the effect you describe is caused.
Somewhere in the menu settings, will be an option to set the Convergence. This option will allow you to set the allignment of all three tubes.
Older sets do not have this option, and need to be adjusted via controls on the main PCB.
Apr 22, 2009 | Televison & Video
Dominant blue
Can you post to the party who has too much green how to adjust the video adjustments? They need to know so they can see if
its just a simple adjustment.
In your case, first turn the color level clear down to where you
have a black and white picture. As in the case of too much green,
question is if the picture is black and white or if there is a color
on the screen so its blue and white? I suspect it will be which
is typical when the guns start to fail. Likely the green and red
guns are weak in output. There are screen adjustments in the set that a tech can set up that may help some, but the only real fix is to replace the guns which is expensive and requires a complete allignment. All 3 guns need changing to get it back to spec and it is a good idea to replace the flyback for reliability. Get an estimate and likely you can replace the set for the same money.
Jul 26, 2008 | Mitsubishi CS-27205 TV
Blue doesn't seem to line up
Blue convergence IC is bad....change both,,,original number
Stk392-110 replace with upgrade Stk394-160E Hitachi part
# CZ 01341 ....also check B+ feed resistors for over-heating
................................T.
Jan 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Jan 07, 2008 | Samsung PCL5415R TV
Center adjust on Red gun is not aligning with B&G vert.
frist set blue and green than set red itwill shoew yu single chakall will be focous in single line than than gun will be allign horizontal if it will correct if itisnot comming than cathode problem.
Oct 06, 2007 | Sony VPH D50HTU Multimedia Projector
Blue Convergence just went out?
High Voltage Capacitor? Leave the set unplugged for 1/2 hour most components will selfdischarge, as for your problem, being a Magnavox, you have one of two problems, the convergence I suspect is what is blown out, this unit probably uses STK392-110 Ic's, I would suggest replacing with STK394-160e chips as they are probably shorted, some of the big resistors (1 or 2) may be opened up also, usually they change color. The only other thing that would cause usually a yellow color in the corners is the CRT Fluid, it changes from clear to Orange in color and clamps off the blue color from the fringes, I suspect the chips need replacement, dont forget to put some heatsink dope behind them, they are usually on the left in the front of the set (from the back) Big long heatsink that is fairly tall (probably the biggest heatsink in the set.) Good luck, and the repair usually runs around $350.
Jul 13, 2007 | Philips Magnavox 51MP392H Rear Projection...
Hitachi Ultravision P50S601 50 in. Plasma HDTV Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
