The hinges on my dell latitude d820 broke.where can I find how to fix it?
The cover at the top of the keyboard poped off ,and the hinges are broken, is there any way Ican repair this myself?
  • 32,281 Answers
These WEB site shows how to replace hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Posted on Dec 31, 2012
Pyrhyc
  • 2028 Answers
SOURCE: replace broken usb port on dell latitude laptop
You will have to take the machine apart somewhat, or at least to the point of being able to disconnect and remove the usb port. Here's a link to the D600 service manual download. It will guide you through the breakdown process.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
Posted on Jul 27, 2008
Rebgagnon
  • 382 Answers
SOURCE: Need repair manual for Toshiba P105-s6024 Laptop
Here is just what you ordered. Hope this helps. Just take your time and have patience. Not very hard. Good luck and have a good day.
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
Posted on Feb 10, 2009
  • 164 Answers
SOURCE: Hinges and top cracked on my Dell Inspiron 1525
unlikely that its still under warranty, but you can check the warranty status at support.dell.com
you may also find parts lists on their website. The plastic bezels on laptops aren't very hard to replace.
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Posted on Jul 26, 2009
paulrelliott
  • 69 Answers
SOURCE: acer travelmate 2410 hinges broke on cover how to
Very carefully, 1-push the screen right back holing the hinges where tey should be, 2-you have to unclip the black panel (over the power button) using an old credit card so yo dont damage the plastic, as this panel loops over the hinges & can only be removed with the screen right back, BUT remember to be carefull as the cables run through the blak covers & you don't want to snag them!
I've done this before so don't be afraid to pull hard start at the edges & make sure when aclip releases not to carry on pulling (use your thumb on the base of the comuter whilst pulling, dont just rip em off as you'll crack the panel quite easy.
but first I'd see if you can get replacements they're only aluminium angle plates with 2 screws holding them to the base.
Hope tis helps!
Posted on Sep 22, 2009
Testimonial: "yes very helpful thanks alot"
SOURCE: SM Bus Controller (for Dell Latitude D820)
open link and download driver .....
driver name chipset .....
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&ServiceTag=&SystemID=LATITUDE%20D820&os=WW1&osl=en&catid=&impid=
Posted on Oct 17, 2009
I delet my sound on my dell latitute 820
Hello you can download the sound driver here at dell:
http://www.dell.com/support/drivers/us/en/ussoho1/Product/latitude-d820
Please select your windows system.
Select audio and download the file.
Unzip the file before you install it.
Hope this will help you
Nov 25, 2012 | Dell Latitude D820 Lcd Back Cover Lid...
Dell latitude c610 broken hinge
go www.dell.com give your service tag, model and download your instr. manula and service manual , parts and fix it.
God bless you
Sep 27, 2012 | Computers & Internet
Where dom i insert new memmory in a dell latitude d820 computer?
1. Remove the keyboard bezel with a flathead screwdriver.
2. Remove three screws securing the keyboard
3. Unplug the keyboard cable from the motherboard and remove the keyboard. The internal RAM (memory) slot is located under the keyboard, right above the touch pad buttons.
-How to remove keyboard ( with pictures ) -
http://blogs.microsoft.co.il/blogs/tamir/archive/2007/11/16/diy-how-to-replace-your-dell-latitude-d820-keyboard-for-only-13-99.aspx
Aug 21, 2011 | Computers & Internet
How do I get the "m" key back on my dell latitude d820?
You may try to push it harder to put it back on the keyboard.If theres a broken plastic at the back of the key then call Dell Technical Support and Dell will replace the whole keyboard if the system is still under warranty.
Feb 09, 2010 | Dell Latitude D620 Notebook
My screen doent dispaly at start-up.
Try connecting and external display screen to your laptop's external display port. If the external display is working, then try to access your laptop display connector (usually can access by removing the top power button access cover and/or the keyboard assembly) to the motherboard and disconnect and reconnect to motherboard. Power laptop back on, if still doesn't work, then could be the display invertor pcb or the actual display. If you have to order a display, make sure the display invertor board comes with it. Hope this helps, Ed.
Aug 25, 2009 | Dell Latitude D820 Notebook
Dell latitude D820 sound pops up and inteferes with keyboard
Try This:
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
Feb 15, 2009 | Dell Latitude D820 Notebook
Key fell off
Normally, the solution is to replace the keyboard, they run about $20 on ebay and takes about 15 minutes to change.
http://shop.ebay.com/?_from=R40&_trksid=m38.l1313&_nkw=d820+keyboard&_sacat=See-All-Categories
Jan 17, 2009 | Dell Latitude D820 Notebook
Right arrow key writes n- bbb n- n- etc.
Remove the keyboard and reseat it. There are three screws to remove and it is very easy.
Nov 14, 2008 | Dell Latitude D820 Notebook
Failing power switch on dell latitude cptv 466gt
hi,
its simple. replace the hinge cover. the hinge cover is the big plastic right above the keyboard.contact dell spare parts at 800-3573355 and order hinge cover. it'll cost you less than $20. then go to support.dell.com. click on manuals then choose your system type.
hope this helps.
thanks
Nov 18, 2007 | Dell Latitude C610 Notebook
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
