Question about Belkin (F5D7230-4) Router (587009)
My computer cant find my router
I just bought a router used the setup disk went through all the steps of hooking it up to the computer, but when it starts to cheak my computer settings it says the router is dissconnected or conected wrong. Ive checked the hookups four times but it says the same thing every time, whats wrong?
  • sharaie1 Jan 18, 2009
    I have tried everything and cannot get this router to work on my laptop but works with my fiance's laptop. He has vista and i have xp. I don't know what to do . Router and modem are working properly but I keep getting the same message that I have a disconnected cable.
    Novelist:
  • 176 Answers
  1. Make sure your network cable from the modem to the router is good and connected to the uplink port
  2. If connecting directly try other port
  3. Check local area connection properties
  4. Double click "local area connection"
  5. On the middle box find and highlight "Internet Protocol ( TCP/IP) and click "Properties" button
  6. Make sure "Obtain an IP Address automatically" and "Obtain DNS server address automatically" are the only ones checked and click "ok" button
  7. Make sure "ethernet card" is NOT disabled
  8. Update ethernet card driver if necessary.
Wireless:
  1. Turn wireless switch on
  2. Check wireless connection properties and that Internet Protocol TCP/IP configuration is similar to the above
  3. On wireless properties select "Wireless Network" tab and Add your SSID (wireless network name) if not there and if there Move "Up"
  4. Update wireless card driver
Router:
  1. Double check to see that "Automatic Configuration" DHCP is selected
  2. Double check to see if "DHCP"server is enabled
  3. Check wireless network mode and select correct mode
  4. Check wireless channels and adjust as necessary
Posted on Jan 18, 2009
Well i had my router all setup n working fine for around 4 months, then our cable modem went out for like 4 days after which it has been giving me fits. I can get my pc connected but it seems like the...
1. you will have to contact your ISP
2. you will have to clear the router and use the setup CD and reconfigure the router
the Internet Service Provider probably has changed the IP address.
3.check with the router manufacture via their web site and see if there are and updates for your router.
4. you will need to check your firewall setting in the Windows Security settings.
5. you will need to setup your wireless devices again via the Wireless setup wizard provided in the router wireless settings. These instruction are on the CD that came with the router an or the manufacturers website will provide step by step instructions.
Feb 07, 2011 | Trendware TEW-432BRP Wireless Router...
I cant locate my disc to the Belkin G+ wireless router. I went to the default IP address and reset to default and now I cant get it to work as a wireless at all. Any suggestions?
setup manualy yuor router.
Symptoms
You need to restore the factory defaults using the web interface. This may be because the router is not performing as expected or you wish to remove all previously configured settings.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. after that you go to ssid and setup your network
  6. select your password us a 64bit wep
  7. disable WPS
  8. disable Firewall
and good luck finish.
Dec 07, 2010 | Belkin F5D7234-4 Router
Cant connect to d-link setup when my broadband D-l
I think you will need to reconfigure the router.
Reset the router for 30 seconds. unplug the power and plug it back in. wait for 1 minute and now try to reconfigure the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 10, 2010 | Computers & Internet
Router setup
Jan 28, 2010 | NetGear WGR614 Wireless Router
Lost setup disk for the router. Tried manual setup.
DSL's tend to have PPPoE signalling which means extra setup. Did you put your username and password in as assigned by the DSL provider?
Nov 22, 2009 | Linksys Wireless-G Broadband Router
I dont know how to set up my routers
Put the setup disk in your computer and it will step you through the process.
Typically, you will have to hook your computer directly to an internet connection (with ethernet cable), then unhook it and connect the internet cable to the router (usually in port 1), then connect an ethernet cable from the router to your computer and plug in the router.
The disk should download the appropriate software and walk you through setting up a password and stuff.
After all that, you can unhook your computer and use it wirelessly.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
My computer wont get past step one on the installation cd
what is the OS
it this is xp or vista you do not need to run setup
connect your pc or laptop using cable and
go to router home page using either 192.168.1.1 or look at the setup page it will give you what is the ip adddress for th home page
here you have to enable wireless and use this router
good luck
May 28, 2009 | Computers & Internet
I have lost my installation disk.
Yes its possible, we can configure the router via the setup page. can you tell me what is the brand and model of your modem and how is your internet service provider? So that i can givet the steps on how you can get the router setup for internet and wireless connection?
thank you.
Jun 16, 2008 | Linksys Wireless-G Broadband Router
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
939 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
