Question about Hilti Pd32
Hilti pd 32 wont stay on - Hilti Pd32
Hilti Pd 38 starts with an E 189
us.hilti.com/HiltiTools
Jun 11, 2014 | Hilti Pd32
Hilti TE 905 AVR wont hammer
sounds like it needs a rebuild kit. Hilti.com for parts or to contact Hilti to see if you can get parts. It will also have the parts breakdown.
Feb 21, 2014 | Drills
Hilti pd 42 E112
Hello All
  1. When press ON/OFF button to switch ON and you get E with error code.
  2. Switch OFF again.
  3. Press ON button and start pressing plus button repeatedly until you get battery symbol in left corner, that's it all done.
  4. You may have to repeat step 3 few time to be successful and probably every time you want to use it. Hope it works for you because it works for me.
Jul 29, 2013 | Drills
Hilti pd 30/hilti pd 40
If anyone know I need one too for my pd 32
Jul 02, 2013 | Hilti Drills
GUIDE D UTULUSATION PD30
Tiens, mais c'est en englais
ou bien ici pour la version francisee
Aug 09, 2012 | Hilti 202415 PD 4 Laser Range Meter
Hilti says they cannot fix my t14. does anybody work on t14?
If Hilti tells you that they can't repair it I don't know of any source. You might check your local phone book under tools/repair for a repair shop but not too many people work on Hilti products. Have you tried calling their technical service/customer service also, 1-800-879-8000. That would be the final disposition I would think. Good luck
Jan 25, 2012 | Drills
After inserting the bits into a Hilti TE76P, should the bits be able to move in and out about half an inch? The tool works fine, and the bit stays in place, but I noticed it moves like that.
Yes, the bit should have about 1/2" to 1" of free movement in and out when the gun is not running but should not be able to fall out of the gun when pulled on.
Jan 22, 2012 | Hilti Drills
How to mesure in feet instead of inches
Hold the POWER button down for a few seconds. Thats how you get into the settings. Cycle through options with the measure button. Use the power button to go to the next option (eg, beep on or off). Press and HOLD the power button to exit this mode.
Sep 16, 2009 | Hilti 202415 PD 4 Laser Range Meter
Hilti Pd32 Logo
100 people viewed this question
Top Hilti Measuring Tools & Sensors Experts
Tom Chichester
Reprep
Are you a Hilti Measuring Tool and Sensor Expert? Answer questions, earn points and help others
