Question about Dmm Mansfield 107 Montclair SmartHeight Elongated Front Toilet Bowl
Our Mansfield high toilet bubbles up when flushed. It is not plugged- it bubbles up from center.
Water flushes in like all toilet but at the same time bubbles up from center.
  • Mark Levos Dec 30, 2012
    I have not had my problem answered
    This is a new toilet so what could be wrong to make it bubbleup,
bloues
  • 56 Answers
SOURCE: One of our EcoQuantum toilets really doesn't
Hello
Im Rossouw. qwalifide plumber
Ur problem most likely is ur arm conected to your flush handel.
If the arm is iron, try bending it down so that when u use the handel it has more leverage tolift up ur sistern flush rubber and create a flow facume as we call it.
if its plastick.... u must ajust the hight of ur flush meganisem by turning the head were the arm is conected left and pushing it down and turning it right to fasen it again. this will also work for iron arm bt is un nessesery for iron arm.
ajust hight until problem is solved.
Please rate my advice thanx :]
Posted on Jul 10, 2010
  • 182 Answers
SOURCE: water level sometime very low, sometimes very high
I would say the first thing you should do is, drain out your toilet using a cup and sponge, remove the toilet from the floor and inspect the base of the toilet for blockage. Also check the floor floor and gasket to be sure there are no restrictions. If all is clear then run a garden hose full pressure into the drain and see if it backs up. If the drain is blocked and you don't have access to a drain snake then you an go to a local hardware store and buy what is called a drain king that connects to the garden hose and pressurizes the drain to clear the blockage. If you dig up the septic lid make sure you have it pumped at the same time.And as always don't forget to use your rid-ex every other month. Hope this helps.
Posted on Feb 18, 2011
packrat1948
  • 528 Answers
SOURCE: MMy past and now New currant mansfield toilet
If you already have your answer to this disregard.
Are you saying that the old toilets and the new ones all did or are doing the same thing?
If yes are they installed on the same DWV (drainage waste and vent) plumbing system as the old ones?
How many toilets are we talking about?
Are any of the problem toilets set back to back in two bathrooms with a common wall?
Posted on Mar 12, 2011
SOURCE: Howdy, the tank on my
We have replied that it sounds as if your internal flush kit button is stuck in the down position. If you continue to have problems please contact us for a replacement flush kit for free. Thank you.
Posted on Aug 20, 2011
  • 126 Answers
SOURCE: Toilet is not flushing
sounds like you need to adjust water level in tank,take lid off and check if theres enough water to flush should be a water level line in tank.
Posted on Sep 25, 2011
I have a mansfield toilet and after flushing it keeps running, how can I fix that?
Not sure about your brand but many toilets have a flapper valve inside the tank which needs adjusting or replacing. Try this U tube link
How To Repair Mansfield Toilet
Apr 06, 2015 | Home
Poor draining toilet checklist
1. Is the toilet plugged or partially plugged. I have removqed toothbrushes, combs, toys etc. from toilet traps so check for any obstructions.
2. Rust and scale buildup. The buildup of rust , sediment and or scale in the internal passages of a toilet can greatly affect their performance.clean the small holes under the rim with a small piece of wire. Use Limeaway or CLR to remove rust and scale. put some in the tank and flush toilet. Let sit for a while and repeat.
3. Improper venting or plugged vent. A toilet needs a properly vented drain to work correctly. Check the vent to make sure it is not plugged or in the northern climates frosted shut.
4. Mechanical issues. Is the flapper lifting high enough when flush lever is flipped. Is water at correct height in tank. If it is a pressure assist is water pressure high enough. Is pressure tank waterlogged.
These are just afew of the many things that can cause a poor flushing toilet. Hope this helps.
Jun 28, 2012 | Mansfield Plumbing Products Mansfield...
Sep 24, 2011 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
My Mansfield toilet flushes but only 1/3 of the water in the tank flows out during a flush and the bowl does not get enough water to flush everything.
Check the water level int he tank for it coming up to fill line in tank. Make sure the 1/4 " fill line from the fill valve is connected and in the stand pipe tube to allow water to fill bowl. Fluid master makes a flapper that has adjustments on it to increase or decrease water used to flush. It has a dial to move on it this would be another option if the above tried doesn't help.
Thansk and I hope this will help you with this problem.
Mar 26, 2011 | Mansfield Plumbing Products Home
Toilet model 386 is spraying water through the top of the water valve when tank is refilling.The water then is coming out between the lid and the tank onto the floor. email Address: milemc@yahoo.ca
there is a black hose line that goes from the flush valve to the fill valve. that black hose needs to be attached to the fill valve the one in the center. Your clip may have broken or it could of just slipped out. the hose is called the refill tube. If its broke then you will have to replace the flush valve.
Mar 14, 2011 | Summit Appliances Division Mansfield 386...
When flushing the toilet, there is not a lot of "push" behind the flush. I'm having to flush two times, regardless of what is in the toilet.
It is normal for these useless new tanks to do that. Won't even flush a piece of paper. Pull off the lid and make sure the little hose is in the overflow pipe, and raise the water level as high as you can. take out all the bricks and water bottles, and bowl cleaners. Then give it a try. It might do a bit better. Hope this helps.
Jul 03, 2010 | Mansfield Plumbing Products Mansfield...
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
Have Mansfield #160 and hear a fog horn like sound when flushing toilet. What can I do to fix?
Are your wast water pipes in your house vented through the roof? If they are maybe the vent pipe is clogged. At my father in-laws house the pipes are not vented through the roof like their supposed to be to vent sewer gas. they are not vented at all. Every time you flush it sounds like someone is downs stairs screaming. Something to do with air/ suction in the pipes.
Sep 05, 2009 | Mansfield Plumbing Products Mansfield...
Mansfield 160 extremely difficult to make it flush
If this is the model am thinking it is, you need to replace the flapper. it goes down in open to far and gets bound.Or if you have hard water or calciaum buildup,it is making for a tighter opening. I hope this helps. :)
Jul 06, 2009 | Mansfield Plumbing Products Mansfield...
Dmm Mansfield 107 Montclair SmartHeight Elongated Front Toilet Bowl Logo
327 people viewed this question
Top Dmm Home Experts
Donni Steen
jdthefixer
john h
Are you a Dmm Home Expert? Answer questions, earn points and help others
