Question about Pioneer AVH-P5000D Car DVD Player
Avh-p5100 Caution screen may appear reversed
Every 5 seconds a black screen appears that says Caution Screen image may appear reversed, But the camera polority is turned off. How do I fix this
SOURCE: To fix the pitch black screen
just take the positive cable off your battery and that will reset in to the factory settings and that should fix it
Posted on May 13, 2009
SOURCE: caution screen image may appear reversed
hello, when i turn on the cd.player, in just few seconds this text comes: caution screen image may appear reversed(and the screen is black)....when i touch the screen with my finger, it disapperes for a few sec. what is this??
Posted on Dec 08, 2009
SOURCE: Hi, In my Pioneer Avh-P3100Dvd' s screens appear
hi boss my nokia 3230 do restsrt & hanging problam
Posted on Mar 01, 2010
SOURCE: pioneer avh-p5000 dvd'
try going to the menue screen. bottom left hit rearviewcamera. then just hit radio or dvd ect. this is a feature that is designed to view something you may be towing while driving.
Posted on Apr 08, 2010
gopakumarg43
  • 73740 Answers
SOURCE: hi. i have a pioneer avh-p3200bt and whenever it
Hello
So many manual settings done be the customer, will make the main system IC to be confused. Make a reset [Factory] to the set, and try.
The microprocessor of the set must be resetted to tis factory settings, if the unit fails to operate properly. To reset the set, turn the ignition switch OFF. Press the RESET at the front panel of the device with a ball pen tip of or other pointed instrument. The set must come to its factory alingment, and must work properly. If not, the memory IC of the device is faulty and should be replaced with same type and number. It is really a very skilled work, and must be done either by any well experienced technition or by the authorise service center for Pioneer at your town.
The memory IC is one with 8 solder terminals and won't cost more. Eventhough it is a very small component, it controls all the other functions and keep it in its memory locations, what awe do with front panel or remote control handset. it keeps the functions as we enter, and retains them in its memory locataions, and retrive it to the main system control IC to process, and keeps it in its memory locations, when we switch OFF the set. All the store memory will be retained to the amin system IC, as we switch the set ON each time. This is a general fault to most of the Pioneer sets. OK.
Posted on Sep 09, 2011
Pioneer avh p6300bt
You switched a memory/ display with a power wire
Jun 14, 2013 | Car Audio & Video
My Pioneer P5200 - The screen is black and the message reads 'Caution - Image may be reversed". Your/the suggested solution does not work for me because the screen is black and only the 'volume' and 'next...
hahahaha . sorry for laughing. pull up your menu that has the reverse cam button push it again. when you push this button it will show you a black screen your cam is not there this is why its black. it will keep going back to this screen until you push this button again(i laugh because i have a pioneer avhp4100 that does the same also contact e if needing e brake bypass).
Kieran
Aug 18, 2010 | Pioneer AVH-P5000DVD Car DVD Player
My pioneer double din screen says ''Caution, screen image may appear reversed''...how can i solve this problem?
As you know, you can use this DVD AV Receiver with a rear view camera. And also it can be installed to switch automatically from the video to rear view image when the gear shift of the car is moved to Reverse position.
But it is important to use a camera which outputs mirror reversed images.
Otherwise the screen image may appear reversed. And this means that you will see the rear view reversed in the monitor. And that may cause accicent and injury.
To solve this problem, first check your rear camera whether it has the capability to output mirror reversed images.
If it is, then check the wire connections of the rear camera using the operation manual or ask a technician.
Also check the settings of camera polarity if it is set properly or not in the system menu when connecting the rear view camera.
You can download the operation manual (pdf file) by clicking here.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | Pioneer AVH-P4000DVD Monitor
Pioneer avh-p5000 dvd'
Apr 03, 2010 | Pioneer AVH-P5000DVD Car DVD Player
Mar 01, 2010 | Pioneer AVIC-D3 Car DVD Player
Caution screen image may appear reversed
Sep 27, 2009 | Pioneer AVH-P5000DVD Car DVD Player
Mar 25, 2009 | Pioneer AVH-P5000D Car DVD Player
No video screen
If you can touch the screen and get the menu, then after 15 seconds or so, it goes back to the 'images may appear reversed' message, here is what you need to do....
1) Touch the screen to get menu
2) Touch the "Rear View" button (lower left of screen)
3) It should beep, but not change from menu view.
IF it changes instantly to the 'images may appear reversed' screen, repeat steps 1, 2, 3.
This should fix your issue.
Mar 12, 2009 | Pioneer AVH-P4000DVD Monitor
Pioneer AVH-P5000D Car DVD Player Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
