Question about Hello Kitty CD Karaoke System with Screen - Pink/ White 68109 one size
WHAT IS A CDG CD - Hello Kitty CD Karaoke System with Screen - Pink/ White 68109 one size
Read error
Your reader is probably going bad. You can try cleaning it with one of those home CD player cleaner kits and that might work for you.
Aug 23, 2014 | Akai Karaoke Akai KS808 CDG Karaoke System...
American idol karaoke machine has stuck drawer. There is no manual release hole to put a paper clip into. CDG trapped plays..
Take out the cd mech, look underneath for a wheel at the front which shoud have a small belt on, turn this with your finger til the disc becomes unclamped and the tray opens
Apr 02, 2014 | Audio Players & Recorders
Cdg not playing disk
Can you hear the disk spinning? If not, the motor may need replacement.
If it is spinning- is it on Pause? If it is spinning and not on pause, the laser my be burned out, or the flat ribbon connector may be dislodged.
Apr 01, 2012 | American Audio Cdg-350 Professional Dual...
I want to burn a karaeoke disc
The problem isn't the burner. You need karaoke software to burn and view cdg files. Below is a link to free karaoke software. Install the software (or a software package of your choosing) and re-burn your files.
Karaoke Builder
Dec 27, 2011 | LG GSA-H22N DVD±RW Dual Layer Burner
On my Yamaha CDC-625, I can push the open/close button or the playxchange button, but the changer door will not open. It sounds like a motor is trying to open it, but nothing. Pushing the button again...
The most common problem is a slipping belt.
You have to open-up the player to check it.
If you're not familiar with it, then please don't.
It's not such a big problem, look for a local repairshop.
HNY, Gerard
Jan 01, 2010 | Vocopro CDG-8000 Professional Dual CD/CDG...
How do I get NERO to burn a (cd+g)?
Nero won't burn a cd+g file as the burner does not recognize the file type.
You need a program called mp3+gToolz its free, get it here>>>
http://www.activeaspsoftware.net/default.aspx?p=downloads
You need microsoft.NET framework from windows update withmp3+gtoolz you can convert your mp3 and cdg files into a bin file youthen need a program called cdrwin you get it from www.goldenhawk.comits not expensive but its free to copy at 1X speed you then have to runcdrwin select everything to cdg then load you bin files and record yourtracks you must have a cdg compatible burner but it will let you knowif you haven't.
Good luck.
Sep 10, 2009 | Ahead Software Nero 6 Ultra Edition...
Will these burn CD+G Discs?
karaoke has a special encoding you know..
Mar 30, 2008 | Computers & Internet
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Cd tray doors won't open
Check mechanics on CD door for dirt, or any loosen screws.
Oct 01, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Hello Kitty CD Karaoke System with Screen - Pink/ White 68109 one size Logo
13 people viewed this question
Top Hello Kitty Video Cameras Experts
Are you a Hello Kitty Video Camera Expert? Answer questions, earn points and help others
