How to get grand total of the month on sharp cash register ER-2385
  • 159 Answers
I can't believe we still have a book for this one - the ER2385 began production in 1987!
Most business owners take their totals daily. You probably have, too, by turning the key to Z1 and touching
. CA/AT (I hope you can the decimal point in front of the CA/AT. It's essential.)
To take monthly totals, do exactly the same thing, but in the X2/Z2 position.
Note that these totals are monthly only because you print them monthly. If you do it every Saturday night, you'll get weekly totals. The register prints totals that have accumulated since the last time you took a Z2 reading. It's up to you to make them monthly by taking them monthly.
So, on January 31 take your usual nightly total, then the Z2 total. Taking the daily one first ensures that today is included in the month.
Skipping the decimal point before the CA/AT will give you an X2 total. The same numbers will be printed, but they won't be cleared back to zero. That's fine if you want to see your totals so far, without messing them up, but if you forget it at the end of January, then February's totals will include both months. The same rule applies to daily totals. Use the decimal point if you want the numbers cleared.
While the CA/AT key gives the familiar department totals, other readings are available.
PLU gives your PLU totals, if you use them. (X1 and Z1 only)
#/TM gives totals for each hour of the day (X1 and Z1 only)
SBTL gives a total for each day of the month (X2/Z2 only)
Posted on Jan 29, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
Posted on Jan 26, 2008
flexion1
  • 737 Answers
SOURCE: sharp cash register (er-a470) won't turn on.
If the machine is dead, then you probably have a bad battery. It should be changed every 3 to 5 years by the dealer. If it has been left too long, then this is a common symptom and the machine loses all programming. Otherwise, you may have a faulty power supply or mode lock unit. It sounds like you need to see a dealer about it. ------------------------------------------------------------------------
If anyone is looking for a Sharp ER-A470 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Many more available at
Posted on Mar 28, 2010
flexion1
  • 737 Answers
Hi. You may have a bad battery. This can cause lock ups. If it hasn't been replaced in the last 3 to 4 years, take it to a dealer to have the internal battery replaced. The battery will eventually leak all over the inside of the machine and damage it beyond repair. --------------------------------------------------------------------------------------------------
I've had many requests for the Sharp ER-A470 manual. Here is a link http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Posted on May 18, 2010
flamez_fu
  • 47 Answers
SOURCE: how do reset grand totals for sharp cash register ER-A330
Please refer to your owners manual.
Posted on May 22, 2012
I can't get the key to turn into the SM mode to clear the grand total history.. I would like to do this before I use the machine
Cash Register Help: SAM4s ER-650 Cash Register
cashregisterhelp.blogspot.com/2008/05/sam4s-er-650-cash-register.html
May 1, 2008 - I really like the SAM4s ER-650 Cash Register and ER-650R Cash Register. ... By the way the SAM4s ER-650 and ER-650R is the same as the Samsung ER-650 and ... I can't seem to figure out how to program it to track ticket/check #'s. .....also, neither the Reg Key or Mode Key will turn to SM mode. help?
Samsung Cash Registers ' ER650 Bar Code Scanner ...
www.maxperience.com > ... > Cash Registers
If not, you will need to go to the SM mode and configure either RS-232 port 1 or port 2... Press enter (cash key) through the rest of the options. ... I could not get the curserinto the plu numeric field once i entered the plu. .... There are manuals for the SAM4s ER-650 at http://www.cashregisterguys.com and if you are looking for ...
Samsung Cash Registers ' Samsung ER 650 Deleting PLUs ...
Dec 01, 2015 | Samsung SAM4s ER-650 Cash Register
I have a sharp er a320...when i do multiple salles ..it only prints the total and not each item,then the total. It is important for me to have a detailed bill of each item and then the total.
Receipt can be set to simple format or detailed format. All are depending on the setting by programming, like change job # 904, 905, 908, 909 ... some sale information may be omitted or added on.
Feb 18, 2015 | Sharp ER-A320 Cash Register
Sharp ER-A420 Casg Register
Turn your key to P and press cash/total button twice...goood luck
Dec 27, 2013 | Sharp XE-A402 Electronic Cash Register
How to grand total of the month on sharp cash register ER-2385
That is a very old machine. It might not have enough memory for two Z reports. if it has a Z2 position, turn the key to Z2 and press CASH (if it is marked X2/Z2, press decimal point before cash). Note: If you have never used the second report it will have a large total built up. you will need to reset it as above to clear it and then it will be correct from the next month onwards.
Dec 30, 2012 | Casio Parts Cash Register PC Desktop
My sharp ER_3100 wont operate it shows 00000000
The ER-3100 has a memory-protection battery soldered to the main board. It charges whenever the register is on, and when the register is off, it can hold the totals and programming for over a month.
But the ER-3100 is about 20 years old, and you battery has lost its ability to hold a charge. You need to have the battery replaced and the entire machine's memory cleared, then programmed. Don't do it. You need a new cash register. All the replacement machines are much cheaper, much faster, and much quieter than your old ER-3100.
Nov 25, 2011 | Sharp XE-A402 Electronic Cash Register
Software for Sharp XE-A201 Cash Register
You need the PC Link software for your model.
All of these manuals can be downloaded at:
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
I have sharp er-a420 it was in my garage for two years. I like to reprogram my register. I think I need to reset my register, I do not know how. Manager?s key does not do anything. When I plug it in on the...
Most Sharp register, including the ER-A420, have a rechargeable battery mounted inside to hold all memory when the power goes out. It should last a few months, but two years is a bit much. This might get it going:
  1. Unplug from AC POWER.
  2. Turn the key to PGM.
  3. Hold down both paper feed keys (at top-left of keyboard).
  4. While holding those two buttons down, plug the power back in.
  5. Turn the key back to REG.
  6. Enter 1 CASH # to sign on as Cashier 1.
  7. Try a sale.
There is a strong chance this won't do the job, because the memory has been randomized by total loss of power when the battery died. Worse yet, the battery may be too far gone to ever take a solid charge again. If so, you probably need the help of a Sharp register dealer to replace the battery, totally clear all memory and reprogram it. It's probably worth the money; the -420 is an excellent little register.
Dec 10, 2009 | Sharp XE-A402 Electronic Cash Register
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
