Question about Electrical Supplies
How to troubleshoot blackmax pm0497002 electric generator
The generator worked fine during last power outage about 6 months ago. This time motor runs fine but no power out of any of the 120v outlets or the 240v outlets. I pushed reset breaker buttons to no avail.
  • 18 Answers
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Posted on Sep 19, 2008
Bat1956
  • 585 Answers
SOURCE: Coleman Powermate 5000 reset problem
Yes, there must be a protection device on the unit somewhere. It should be indicated in the owners manual. It may be on the box the outlets are in, or built into the cover of the generation unit.
Posted on Dec 17, 2008
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
sal_kh_sab
  • 98 Answers
SOURCE: Coleman/Honda Generator - No Electricity
take a look at the fuse...if it seemed burnt then replace it.
if not.
then check the breaker...try connectting your voltmeter directly to the wire that goes into the breaker(directly to the +) and the other side to the regular (-).
if it read 220 volts then the breaker is down...so replace it...or you can use the outlet directly.
however if it didn't read any voltage,
then you should check the brushes...they are right next to the AVR module...(the two wires that come out of the AVR are connected to the brushes)
if the brushes are shattered or if there is no connection between each brush and it's connector then replace the brushes..
but if they seemed fine.then your problem is with the wires...trace every wire and check for continuity.
the problem has to be one of the things i mentioned.
Posted on Oct 30, 2009
  • 3 Answers
SOURCE: plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
Posted on Mar 14, 2010
Choosing a home generator to use in the event of outages
if you can afford a real standby genset id get one of those. reasoning is this way you do not have to store gasoline and rotate it every few months. and if you have a backup style genset you may not be able to get fuel for it when your supply runs out. that and you have to hook it up when the power goes out. safely hopefully. they are sized depending on the size of your power needs. most places that sell them will come to your house and tell you what youd need. easy stuff
Sep 17, 2017 | Electrical Supplies
Maytag MED5700TQ occasionally completely shuts down during cool down mode
Sure!
You may have a bad timer, that is turning off the electricity to the motor while the heater is still energized.
Long time ago, dryers had about 3 "automatic shut-off's" two on the heating element, and one on the motor.
Because of the lint that comes with drying clothes, fire is always a danger.
Today, the "thermostat shut-off's" are up to 5, 6, or 7 on some models!
Sounds like your dryer is getting hot enough to trip one of these. When the whole machine cools down, the thermostat resets, and the machine starts again.'
I had a dryer do the same thing. The problem with that one was nothing more than dust and lint in the motor, and all I had to do was vacuum out or blow out the motor about once or twice a year.
Be blessed
Jan 31, 2013 | Maytag MED5700TQ Electric Dryer
My Coleman powermate generator 6250 won't start. We used it last month when we had a power outage during the coldest of winter weather. We checked the oil, gas compartment and found that there was...
Make sure the sparkplug is clean and gapped. Unloosen the float bowl slightly and drain about a half cup of gas out of the bowl. It is possible a little condensation got in to the fuel. Tighten the bowl nut slightly and try to start the generator.
Mar 10, 2011 | Heating & Cooling
My timer has been working fine for the last 6 years. I replaced the fixtures about a month ago and a couple of days ago I noticed the timer was about two hours off...Does anyone know what the problem...
John, This came up under chain saws, but I assume this is an electrical timer and the fixtures you replaced were the light fixtures that this timer controlled. Maybe the timer is about 2 hours behind and the fixtures took about 2 hours to replace, during which time the power was off and the timer did not run. Sorry if this seems too simple and obvious and you already thought of it, but you haven't given me much to go on.
Aug 11, 2010 | Garden
Installed a generac 20kw about a year ago, ran fine untill 2 days ago. During a utility outage, generator ran for about 30 minutes and then stopped producing power while still running. All mains were still...
With the engine off, check the exciter brushes and slip rings which supply magnetic power for the alternator winding in the stator. Also, check the motor-to-alternator mechanical coupling. Check the breakers for tripping. To service beyond this point requires a schematic of the alternator, a voltmeter, plus knowledge of what the schematic is telling you. Good luck!
Jul 25, 2010 | Generac Power Systems Generac 5525 20 Kw...
My son purchased this generator about a year and half ago and has used it very little. during a power outage we got it out and used it for a day and the circut board went out. shouldnt it have lasted...
That sux! Thats NOT acceptable in any way... Take it back and demand it gets repaired.. With devices such as this it is not the simple passing of time that ages it, but the actual POWER ON time... & Yes if Overloaded it should simply have "Tripped" a breaker or the like.
Feb 02, 2010 | Coleman Powermate Premium Plus 6250W...
Generator won't start
Some of the generator has a control or tripping device like over speed, over voltage, overload or overcurrent or other trip device, try to find & reset it.
Mar 09, 2009 | Electrical Supplies
Coleman Powermate only puts out 110V
If you haven't seen it yet, here is a page that may help with a manual or parts list.
This problem sounds kind of bad, generators don't do well when the engine stops under load.
Start by checking the circuit breakers in the distribution box (outlet panel) - you need ot do this with an ohm meter. After that check the power windings of the stator with the ohm meter, be sure to check between the 2 windings (should be open), and from each one to ground with the winding isolated.
Whining, a burning varnish smell, and breakers that trip all the time are indicators of long term overload problems. This could happen if you had most of the load on one winding for a significant amount of time, or if the one winding mostly powered motor-like loads with high startup currents.
You may want to look at this answer I posted some time ago.
Regards,
Carl
Jan 06, 2009 | Coleman Powermate Powermate 5000W...
Coleman 6200 won't work
Hi Judy,
Generators DO last a good long time for the money, but they have to be both used and maintained in order to keep working properly. What has most likely happened is that you didn't use the generator at all for a year, after it sat on your dealers shelf for a few months not being used, and so the tiny bit of magnetism it uses to "kickstart" the process of making electricity has worn down. The good news is that this is easy for a generator shop to repair, no parts involved and the minimum labor that they charge. They need to do something called flashing the field of the generator. What they can't do is get Coleman to pay for it since they aren't around anymore, go ahead try the 800 number (waits patiently).
Be nice to the poor generator techs at the shop.
Nov 24, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
162 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
