Question about Toshiba Satellite A305-S6853 Notebook
Another question! My CD/DVD drive is gone. The lighis not going on. It won't open up and is not listed in device manager nor in My Computer. Is there something I can do to get it back? Thank you!
  • srodrguez123 Jan 19, 2009
    Oh its fixed i called the manufacturer...so yeah thanks for your help!
  • 744 Answers
Hi. you are saying that ur cd/dvd drive is not supporting in ur system. i think the only way is to go for a replacement of ur drive or else if u have another drive u can use it
Posted on Jan 19, 2009
My cd won't play
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 06, 2012 | Dell Computers & Internet
Nero burning rom7 won't accept dvd+r disc
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Feb 22, 2012 | Computers & Internet
Dell xps 400 dvd/cd drive door won't eject or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
or
hope this helps
Jan 26, 2012 | Dell Computers & Internet
CD/DVDW ROM drive won't start
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
or
or
hope this helps
Jan 25, 2012 | Gateway Computers & Internet
Won't play a dvd
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Oct 07, 2011 | Lite On LiteOn LH-20A1P - Disk drive -...
My hp1040lightscribe won't recognize the drive for burning. Help. It keeps telling me to put a blank disc in and when I do, it still doesn't recognize it and won't burn it.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | HP LightScribe dvd640i (DVD640I)...
Why won't DVD Player open?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.or
:you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver :or
hope this helps
Jul 05, 2011 | Computers & Internet
The DVD drive in my new Aspire 7741z-4433 won't read any discs - CD or DVD
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
Jun 04, 2011 | Acer (KV.16X04.007) DVD Drive
I cant play dvds on my laptop.
Reboot
Reinstall the last SP you installed
reboot
try again
Jan 18, 2009 | Toshiba Satellite A305-S6853 Notebook
Dvd / cd rom not recognized on my computer list
1) Go to Control Panel. Open the System Icon.
2( Click on Hardware Tab, then click on Device Manager.
3) The device manager will list all of your hardware that is on your computer.If you see a yellow? mark oryellow ! mark next to your DVD/CD rom drive,simply click on it then click Repair. It also may tell you that it is not recognozied. Follow the directions.
4) If you do not see this in your Device Manager go to Add Hardware in your Control Panel which is next to your Add/Remove Programs icon. Click on Add Hardware and it will scan for all hardware.
** This should take care of your problem.If not then somehow the actual connection in your tower has come loose. If so you must open your tower and look for a loose wire going to your DVD/CD rom drive.
*** Please let me know if this corrects your problem.Simply email me(Phil) at: philw19642002@yahoo.com
Jan 01, 2009 | Gateway GT5468 Desktop PC
Toshiba Satellite A305-S6853 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
