Watching tv then the image disappears still have sound tho.. Is that a problem from the digi recorder?
Is it an HDTV? Try lowering the resolution. Maybe your tv doesn't support certain resulutions and its trying to reset itself to a lower one.
Posted on Jan 22, 2013
3 Suggested Answers
  • 98 Answers
SOURCE: how to get surround sound
Make Sure the correct sound filed is being used refer to owners manual and the program is true surround also the surround speakers will only give background noise not a full channel
Posted on Oct 04, 2008
altec1105
  • 68 Answers
SOURCE: audio problems with surround speaker system on
I have had the same problem on my home theater maybe you should try to wiggle the speaker cord it could be loosly hooked up to your home theater
Posted on Nov 22, 2008
Image disappear, loud, high pitch noise
It is likely that your Sansui TV has a power supply problem.
Jan 17, 2014 | Sansui 22"" HD LCD/DVD Combo TV
IMAGE STAYS ON FOR AN LONG TIME
Sounds possibly like image retention. If you watch the same channels often any recurring text, logos, or graphics, especially white colored, can ghost on the screen.(playing the same videogame for a long period can also have the same effect) Watching other programs or channels will cause the ghosting to disappear.
To prevent image retention you need to activate the TVs anti image retention mode(Called ISM Method). On Zenith and LG (the manufacturer of Zenith T
s) plasma TVs open the TVs menu, select the Option section (picture of a briefcase with a wrench). Select ISM Method and change it to Orbiter, this is reccomended if you watch programs or channels (or play videogames) that have still images for long periods of time. It moves the image a little every couple minutes.
If watching others channels or programs doesn't make the image disappear, change the ISM Method to either Color Wash or White Wash (don't use White Wash frequently, it over excites the plasma gas and can shorten the life of your TV if overused) for a few minutes and then return to Orbiter.
Oct 23, 2013 | Zenith Z60PV220 60-inch Plasma TV
Mouse/cursor works fine on PC but disappears when watching recorded TV using windows media center. model KB3800TPW
Usually when watching something on your computer in full screen the cursor will disappear. If it comes back when you move the mouse then you have nothing to worry about.
May 03, 2011 | Gear Head WIRELESS keyboard/Mouse
While watching an HD program live or recorded when paused picture goes dark after 10 seconds then comes back on after 30 seconds. Does not happen when watching SD programs. TV is new.
sounds like its simply just your tv's auto screen saver or another program along those lines its helps prevent burn in and other issues caused by leaving your tv with still images ok :) dont fret
Jan 23, 2011 | Vizio L37 Television
How do you set up digi box with VHS recorderand Tv. Digi box has two scart leads
Take one scart from the digi-box & connect the other end to the TV, & the second scart on the digi-box can connect to the VCR. To record from the digi-box, the VCR must be set to the AUX input (or AV ). The TV will also be set to the AV input, this set up will let you watch digital channels & to record a digital source. Be aware depending on your type of digi-box, you may not be able to record & watch two different digital channels at the same time.
Oct 14, 2009 | Electronics - Others
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Audio problems with surround speaker system on
Nov 22, 2008 | LG Televison & Video
How to get surround sound
Oct 04, 2008 | Televison & Video
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
