Question about Watches
Just had battery changed on suunto t3d. Screen showing message SW 309. Have tried holding down all 4 borner buttons at once but didn't do anything. Anyone know how to reset? thanks
SOURCE: nike triax watch
sounds like the contact inside for the ligt button is stuck on. Remove the back again and take a look at the contact under the light button to see if it is stuck, if so, GENTLY pry it out a bit so it's not touching all the time...
GOOD LUCK
Posted on Feb 17, 2008
mcdevito75
  • 1970 Answers
SOURCE: how to change the battery to suunto d9
mcdevito75 here, With the tools and time needed, best bet is to look for a small watch repair shop in your area to change the battery.
Posted on Jul 07, 2010
  • 66 Answers
SOURCE: Changing metric to Imperial on Suunto Vector
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
It's in the manual. I did it on mine.
Posted on Aug 03, 2010
SOURCE: I have a suunto stinger
open watch again and press tiny reset 'button' with a pin. That's how I fixed the same problem
Posted on Mar 21, 2011
  • 24 Answers
SOURCE: My watch face shows many of the "screens" all at
it can be done by moisture so put it in the heat to remove the moistuere or put it the rice bag for 5 months so the moisture can be remove
Posted on Aug 11, 2011
Testimonial: "Thank you for this solution. I put the watch in rice and in a few days, it began working properly again. Thank you!"
Suunto core
On your Suunto Core press and hold the mode button for two seconds to get to the menu.
Select "Units."
Under "Units" select "Time."
Under "Time" you have the ability to select "12" or "24."
Dec 25, 2011 | Suunto CORE Wrist Watch
I received my suunto t3d black watch yesterday and accidentally set the contrast too high and it saved. I've tried everything but can't seem to find the setting to fix it. I've even removed the...
To reset contrast on the sunnuto t3d hold down all 4 corner buttons at once, this will place the watch in sleep mode. Wait a few seconds and press any button to wake the watch back up. This will allow you to run through the inital set up just like when you got your watch, alot of your info will be saved so you can just quickly confirm them with the mode button. I also set my contrast too high, I have reset it to 3 and found it much easier to read in all lighting.
Aug 13, 2011 | Watches
I replaced the battery as I have many times imy 2005 suunto s6 watch, but this time the display remains blacked out...none of the buttons work or make any noise. The battery is a 2032 and is brand new.
Tough one but here goes. 1 New battery does not necessarily mean good battery 2 Determine the battery is inserted with the correct side up. 3 Is there a reset. Possibly a small hole that you poke a paper clip into. 4 Try holding all the buttons in at the same time for a couple seconds 5 Go see a watchmaker,
good luck
Mar 10, 2011 | Suunto S6 Wrist Watch
The ascent reading seems to be very inaccurate and the battery shows low after only a couple rides after installing a new battery. Anyone have a solution for the acent issue?
You need to send the watch into Suunto for service. The watch is obviously having an issue if it will not hold charge with a new battery and the Altimeter is not working correctly.
The Altimeters are Barometric pressure related and occasionally something goes wrong.
My experience is that Suunto is very good about fixing and/ or replacing when this issue arises.
Jan 24, 2011 | Suunto T6c Heart Rate Monitor and Fitness...
I have a suunto stinger dive watch after i changed the battery the ACW stays on the screen .
Jan 11, 2011 | Suunto Replacement Strap - Stinger...
Just bought an Adidas Seoul Watch ADH2044 and can't set the time. I've looked in the manual that came with it and online and can't find anything to help. The Adidas website isn't any help either.
Figured it out - Press & hold 'A' then press 'D'. THEN press 'B' to toggle through the selections to set T1. T2 (for another time zone) is up or down in the offset. Good luck!
btw - A, B buttons are from top to bottom on left and C, D are top to bottom right
Jan 07, 2011 | Adidas ADH1572 Watch
How to change the battery to suunto d9
Jul 07, 2010 | Suunto D9 w/transmitter...
T6C failed after working OK for 1 day
Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
To re-pair the belt:
1. Remove the belt battery
2. Push the (new) battery into the compartment positive side down.
3. In your Suunto t6c, enter the settings menu and enter GENERAL.
4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
5. Scroll to HR BELT with [Lap +] and [Light -].
6. Activate pairing with [Mode].
7. Put the battery in with the positive side up and close the cover.
Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
Suunto watch keeps resetting itself. Changed battery a few weeks ago and now in the last week, it will reset itself. After you set it to the right time it could be fine for hours or minutes before it...
You wouldnt think a whole lot could go wrong with a Suunto battery change. If they had trouble getting the coin access back off and unscrewed the case then the button contacts might be out of line causing your problem. You might also check to be sure that they put the right battery in and that there are no pry marks as sometimes there are problems getting the battery out. If any excessive pressure was placed on the circuit board and it cracked it will need to be replaced.
Sep 22, 2009 | Suunto Vector Wristop Computer
Watches Logo
611 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
