Question about Universal Remote Control GE174Universal Remote Control
I have a sony SA-32SE1 sound bar. I have tried every audio code but can't find right code
Is there a direct code or am I just out of luck
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
I have a Sony SA-VE815ED SYSTEM. I have not used it in ten years. Can I hook it up to a HD TV?? Do I need a receiver?? How do I use the HDMI connections on video games, TV, etc?
The SA-VE815ED is a set of speakers. You'll need an receiver (with an amplifier either built in or separate) to connect the speakers to the TV. Depending on the receiver, you may be able to connect the HDMI cables from any set top box to the receiver and then have an HDMI out cable to the TV. (In this configuration, the TV speakers will not get the audio track. So you will want to ensure that the TV's speakers are off and the receiver is on when you play games.)
Alternatively, plug the HDMI cables directly into the TV and then connect the TV's audio out to the receiver. (Depending on the TV, your may need to get a receiver with digital audio inputs.)
Retrevo has the manual for the SA-VE815ED here: http://www.retrevo.com/support/Sony-SA-VE815ED-Speaker-Systems-manual/id/23108ci362/t/2/ . You'll need to enter a code to download the PDF.
I hope this helps.
Jul 22, 2012 | Sony SA-VE815ED 5.1 Home Theater Speaker...
I need a remote for my RCA DVD player, model DRC282. I haven't had much luck with a couple of universal remotes. Any help would be appreciated.
Just try a code search process. Sometimes it might help you:
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
May 12, 2012 | Televison & Video
I have a sa-ak320 stereo that was left at my gf's
The 6 ohm speaker would make it slightly louder but won't solve the problem, you are right the stereo has bad audio output ic, and there is trouble with the cd player. I would use it until it goes, and get a brand new unit, not cost effective to repair.
Apr 15, 2012 | Panasonic Audio Players & Recorders
I have a Sony sound bar mod# sa-32se1 connected to my Sony 32 in bravos, sounds great but shuts down after a few minutes of use what might be the problem
I had the same problem. I found that my sound bar can't be too close to the TV. I have my samsung TV on a platform ( not mounted) and the sound bar in front of it. In this configuration, the sound bar kept shutting off. I returned it as a faulty unit and the second one did the same thing. By chance I happened to move the sound bar off of the tv platform and the problem ceased.
Dec 18, 2011 | Sony Televison & Video
How to hook up a sound bar to this tv
I don't see any audio outputs on this television. Without them it is not possible to connect a sound bar. However I am currently using a sound bar with a television with no audio outputs. I am connecting my devices to the television with the video cables only and connecting the audio cables directly from them to the sound bar. I am pleased with how doing this turned out.
Aug 14, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have an older Panasonic HDTV Viera and I am trying to hook up a Panasonic DVD/sound suround model SA-HT920 and am not having any luck getting it too work. I have the sound turned off on the tv speakers...
What does the TV really need from the receiver in all of this? Minimally, Component video for the DVD and managing the SA-HT920, not much else.
A TV is not normally an optimal source of audio.
Your broadcast TV-related sound would be higher quality and easier to obtain if you got it from the Cable or Sat box you probably have. Route ITS BEST (digital multichannel) audio directly to the SA and and its BEST (HI-DEF) VIDEO directly to the TV. You could also run vanilla analog audio to the TV so you can watch news in lo-fi audio on the TV.
The exact model of TV would be helpful to know as audio capabilities may vary.
Should you still feel the need to run TV-originated audio to the SA from the Viera through its headphone or audio output, connect that to any available analog RCA input.
Connection of a jack into the audio output will pass unmodified TV audio to the SA. That's a good thing as the REAL audio electronics needs an unmodifed source for best results.
Feb 13, 2011 | Panasonic Audio Players & Recorders
I can't get my direct tv remote to work with my Polaroid FLM-3201 tv. I've gone through all of the codes listed in Direct tv's set-up. Any ideas or suggestions?
went to direct tv online tv codes remote10765,10865,11262,11276,11314,11316,11326,
11327,11328,11341, http://2getdtv.com/directv/tv_codes.html
this web page is for direct tv remote codes hopefully
this is an updated list
http://2getdtv.com/directv/remote_codes.html
this page has programing instruction for remote
good luck ron
Nov 19, 2009 | Polaroid FLM-3201 Television
Trying to program the tv with the direct tv remote
Not out of luck, Dynex.com says to use codes from other model of televisions. The way I did it (I have a DirecTV remote as well) is just did a code search till I found which one turned it off. The only thing it won't do is change which input you use, but the menu, volume and channel controls all work fine.
Mar 27, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Televison & Video Logo
114 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
