Question about Maytag Dryers
Dryer works, then will not start for awhile. Then will work again.
Two days ago after doing a load of laundry the Dryer would not start. You would push to start and it would make a very short low hum and then do nothing. The next day when my father in law came over to help it started up. We proceeded to take apart the machine and cleaned everything. The front vent everything. We noticed that one of the front sliding pads slipped off and we placed it back. After a complete cleaning we placed it back and did a couple loads with nothing wrong. This morning same thing happened. Would not start made a low short hum. After a few minutes it started up again and is now working. Any help on what might be the problem to fix. I am thinking a sensor somewhere but which one and what it is no idea. Thanks
  • Maytag Master
  • 8,220 Answers
Probably a bad motor. Sometimes you can bring a motor back by lubing it with appliance oil. My phone video of an attempt
If you have the money get another motor. If not then try to lube it is what I would do.
Posted on Dec 30, 2012
  • 1153 Answers
SOURCE: My dryer doens't start up
Depends on if you can hear any noise when you hit the start button or turn the knob. If there is a hum or some sound then could be belt or motor problems. If there is no sound dead, then you are checking the right area, there are kill switches in different places on dryers. one is like you checked the door switch, and another may be in back when you open the cover to check. Maybe fallen out of place. These sw. are for your safety and sometimes they malfunction. Hope this help!
Posted on Aug 12, 2007
Washer_tech
  • 164 Answers
SOURCE: Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Posted on Nov 01, 2007
JR JR
  • 116 Answers
SOURCE: check lint screen light on and dryer not turning on
check belt might be broken,,,,
Posted on Nov 30, 2008
  • 61 Answers
SOURCE: Cabrio Dryer keeps blowing Air Flow fuse?
Hello, yes it is possible that the thermal fuse has gone again. Before attempting any repair yourself please unplug the dryer. The thermal fuse is located in the rear of the dryer the service panel would have to be removed. it is on the hot air duct has 2 wires going to it white in colour about 1 1\2 ' s long and 1\4 " wide. Also locate wear the vent is outside and make sure you have good air flow. good luck
Posted on Dec 20, 2008
canbruce75
  • 1776 Answers
SOURCE: Electric Maytag Neptune Dryer not heating up.
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
Posted on Jul 24, 2009
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
The dryer is hot but where it used to take 1 1/2 to dry jeans now takes 3 cycles. I did replace the vent 2 summers ago and cleaned out the back of the dryer. It takes me all day to do a load of laundry! ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 21, 2011 | Dryers
My dryer was running perfectly fine. I was doing my laundry all day and I had done at least 4 loads. When I went to start it again, it just hummed and would not do anything. What can it be?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 31, 2011 | Kenmore 62882 Electric Dryer
My Whirlpool dryer Model # WED5300SQO and it just stopped. I had used it about 5 hours ago and it worked perfectly fine. I returned home later in the day and tried to dry another load of laundry and when...
heatman101
Mar 19, 2011 | Whirlpool Dryers
Washer stopped working with clothes and water in it
If you try to wash too many items with the water level set to low it is hard on the drive sysem and will kick out the motor.
When the motor resets it should work again but its very bad for the motor so II would try not to do it again.
Good Luck
Quentin
Jun 04, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer takes hours to dry ever since I converted to propane.
check for obstuction such as lint build up in the exhaust tube all the way out the house. Sounds like poor air flow
Mar 01, 2009 | LG DLG7188 Gas Dryer
Wet towels & blankets stacked on working dryer
This won't affect drying time unless the load is so heavy it causes the cabinet to warp and disturb the door seal. If you haven't had any problem with this so far you can probably keep doing it. (The machine is designed to support the weight of a wet load in the drum, and should have some safety margin. But why not invest in a roll-around laundry cart like you find at laundromats and keep the wet load there until the dryer is clear?) You might need to be more concerned about rust starting on the top of the cabinet if the enamel is scratched, since it's not usually subjected to wet loads being piled there. You should also check your vent pipe frequently to make sure it stays clear with all the drying you do. Clogged lint screens and vent pipes will definitely lengthen drying time.
Feb 18, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Dryer won't Start
Oct 31, 2007 | Kenmore 84152 Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
