Question about LG Electronics LRM-519 Digital Media Recorder
ED14 on the powersupply of lrm-519 need replacing
Located on the power board of the lgm 519 media recorder under the small heat sink is a small component, ED14 do you know the name and voltage value?. I dont know if you are familiar with the LGM519 but the component is adjacent to capacitor C16 and resistor R16. The slot from which i remove the component is U1 WINSTON
  • gordon7738 Feb 03, 2009
    Hello Jwrich1 thank for the information, however Graema from www.justanswer.com gave me the same information in January .
This item is a MOSFET Power Switch. The part # FSDH0165D. Can be found below
www.mouser.com/Search/Refine.aspx?Keyword=512-FSDH0165D
Posted on Feb 03, 2009
I have two lg lrm-519 dvr's both power supply's went out about 4 months apart where can i get this fixed?
I have repaired two different LRM-519 that both had the same problem. The repair was a simple replacement of two capacitors on of the power supply board of each unit. You can search the web for repair instructions, or even search youtube for a video of the repair.
If you have the same problem I had then when you turn on your recorder it will only display the Hello message on the front of the unit (perhaps very dim) and the blue light on the power button will come on. Your next step is to open the device (about 7 screws) and slide the top off, then examine the tops of the capacitors on the power supply, if the tops of one or more are bulging up then this is a good candidate for attempting this repair.
For parts I found some on ebay and searching the web. If you don't want to do the repair yourself I have also seen people offer the power supply repair on ebay.
Jul 06, 2010 | LG Electronics LRM-519 Digital Media...
I have a LG LRM 519 and the power supply went out and the component is located at U1 with no part # on the component can you help?
Hello, the component that got faulty identify as U1 is a regulator and this is a 19V regulator as written on the number . do replace for a new one or an equivalent
May 19, 2010 | LG Electronics LRM-519 Digital Media...
Lg lrm-519 went into demo mode. Can't get it back
follow directions from the owners manual. while unit is powered up, unplug power cord from back of unit - wait 5-seconds. Depress the DVD open/close button while re-plugging the power supply cord to the unit. LG splash appears onscreen and unit goes into re-set. you do not loose any of you programing or settings.
Jul 18, 2009 | LG Electronics LRM-519 Digital Media...
LRM-519 bad picture after replacing capacitors
be sure to check and see if any of the capacitors get hot because once they reach a temperature beyond 105 degrees C. they are basically no good and don't work nearly as well as when they were first manufactured. Also you may want to make sure that you have soldered the capacitors with the long black line on the same position that is engraved on the circuit board where they are supposed to be mounted too.
LG Recorder C18 and C36
Check out this video for the solution:
Jan 21, 2009 | LG Electronics LRM-519 Digital Media...
LG media recorder LRM-519 locked up.
REPLACE C18&C36 0N THE POWER SUPPLY BOARD AND GET BACK TO ENJOYING YOUR UNIT!!
Jan 19, 2009 | LG Electronics LRM-519 Digital Media...
Possible heat sink (u1) burn, not sure of name located by(c16)
Winston,  without more exact details it would be difficult to give you suitable parts information.    Here is another option for your consideration.    http://cgi.ebay.com/LG-LRM-519-Digital-Media-Recorder-160-GB_W0QQitemZ160305698554QQcmdZViewItem
Best wishes,  Michael Mittelsdorf
Jan 15, 2009 | LG Electronics LRM-519 Digital Media...
Installation of LG LRM DVD Recorder Model 519
be more specific with the problems you're having. following the instructions should be straight-forward. if you are using composite cables from the unit to your tv, be sure the composite/480i/480p switch is et to "composite". it'sa small black switch on the back of the unit. make your selection while the unit is powere off. Finally, the composit cables are usually plugged in to the "AV" inputs on the TV -- make sure you set your TV's input to "AV"
Oct 02, 2008 | LG Electronics LRM-519 Digital Media...
LG LRM-519
There is a good chance that the capacitors detailed in this video need to be replaced:
May 21, 2008 | LG Electronics LRM-519 Digital Media...
Lrm 519
Had same problem. My fix was to repair power supply.
On power supply board replace capictors C18 & C36.
2200mf 10v rated 105C
Dec 25, 2007 | LG Electronics LRM-519 Digital Media...
LG Electronics LRM-519 Digital Media Recorder Logo
347 people viewed this question
Computer Repairing
Computer Repairing
