No bootup when my usb hub is plugged in, the computer will not bootup . when i unplug the hub , it starts up fine. when it gets to the startup screen i reconnect the hub, and then everything seems to work fine. i did get a message some time ago saying that i have no hi speed usb host controller installed. previously, this setup worked fine.i am a little weary to fiddle in the BIOS. can someone please help. thanks.
  • scanman2
    scanman2 Jan 23, 2009
    i set it to boot from my main drive, but it does not keep the setting, even if i ''save and exit''. thanks
    Sergeant:
  • 238 Answers
I've seen systems that default to booting from the latest installed drive. I suspect that your BIOS has this set. Go into the setup and check. If it has this set, set it to the drive you want to boot to. This will probably keep happening if you like to boot the system without the drive connected unless their is a BIOS update.
Posted on Jan 23, 2009
  • Robert Graf Jan 23, 2009
    From what I've been able to find, there seems to be a problem with USB devices in general (keyboards, printers, flash drives) preventing systems from booting. Some thing that has supposedly worked:
    Browse the BIOS for legacy support.... disable it, turn it off then save your changes - reboot.
Can you help me fix my Dell Studio 1558 laptop? It doesn't boot?
Dropping a laptop is never good news. Have you tried to Cold-Start the laptop, unplug. remove battery, leave battery out for now, plug in try to start normally. If that fails, Did you remove the HDD and reseat? The damage from the drops may have jarred something loose. Do you get activity, light blinking, from the HDD? The DVD/CD?
Nov 14, 2012 | Computers & Internet
Need 'step-by-step' instruction to install a USB 2.0 4-PORT Hub. Please know that I am NOT computer 'savvy'! Thanx - Pat B
We all have to start somewhere! The simplest way is to see where your mouse is currently plug-in your computer: look for an identical 'USB' socket to the one the mouse is plug-in and plug the USB hub cable plug to this socket. You could also just unplug your mouse from the computer socket and plug the USB hub cable instead AND THEN plug the mouse in one of the socket on your Hub. The computer should automatically install the software require to drive your newly installed USB hub. Hope it helps!
Sep 26, 2010 | Dynex Computers & Internet
My USB Port stopped recognizing my Smart Disk
on my computer right click and select properties, then go to the device manager. Under the USB device locate this device and delete and unplug the cable from the computer. Let the computer reboot, and plug the cable into another port if ava. and see what happens.
Oct 10, 2009 | Targus PA050U 4-Port USB Hub
Usb hub unsafely unplugged from notebook. now
do one thing boot ur vista without usb hub then go to device manager remove your usb drivers of the hub disconnect the hub from computer, restart notebook, then connect the hub back when windows boot let vista to install the driver of that hub, after that connect your devices one by one ok let me know what happen? :-)
Aug 21, 2009 | Belkin (F5U237) 7-Port USB Hub
Blue screen when playing iTunes on Logitech Z-10 speakers
Before, you return it, can you unplug the Wireless USB Hub, and plug in your iPod and does it work just fine?  Also, the USB port that you're plugging it into - is it USB 2.0?
If both answers are YES to the above - then definitely return it.
It's not your speakers.
Mar 11, 2009 | Belkin Wireless USB Hub
Computer stalls during startup
How Old is your computer (depending on age, it may not have USB 2.0) that is what you may need to have a external HD now a days
or is it the drivers?
Feb 04, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Helpp! exceeded the power limits on its hub port?
try to change a new USB cord, and if it does not work the problem is a device then
Jun 21, 2008 | Vivitar MAGNACAM Binocular
When i connect my hard drive to my laptop the baloon comes up saying that usb device is unrecognized.
SYMPTOMS: loadTOCNode(1, 'symptoms'When you plug a USB device into a Windows XP-based computer immediately after the computer comes out of standby (S3) or hibernate (S4), the computer may not recognize the USB device. When this issue occurs, the USB device may be listed in Device Manager as an unknown device, and you may receive the following warning message:
To work around this issue, use one of the following methods:
Method 1 loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
Method 2 loadTOCNode(2, 'workaround');After the computer comes out of S3 or S4, unplug the USB device, and then plug the device back into the computer or hub.
Method 4 loadTOCNode(2, 'workaround'); Disable power management of the USB hub.
Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
To disable power management on the USB hub, follow these steps: 1. Click Start, click Run, type devmgmt.msc, and then click OK. 2. Expand the Universal Serial Bus controllers node, and then follow these steps for each USB Root Hub that is listed: a. Right-click the USB Root Hub, and then click Properties. b. Click the Power Management tab. c. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.-------------------------------------------
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 29, 2008 | Computers & Internet
DELL STARTUP
There was problem at one time with IOGear KVMs not working correctly with the USB chipset on the Dell motherboards. This problem was resolved by using a USB hub between the KVM cable and the computer. The user could take the USB portion of the KVM cable and plug it into a USB hub and then take the USB hub and plug it into the Dell computer. That should help with the problem.
Oct 16, 2007 | IOGear GCS632U 2-port KVM Switch
a simple solution is buy a powered usb hub ( which has an adapter which plugs into the mains) that should solve your problem
Dec 11, 2006 | Nikon Coolpix 5900 Digital Camera
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
