Question about Traxxas Slayer Pro 4x4 Nitro 2.4ghz Sc Truck Tra5907
The steering won't turn on my traxxas 5907 but i am hearing the motor spinning.....help
    Master:
  • 483 Answers
Maybe the turning servo has come loose from cam or bottom of chassis, check with the body off
Posted on Mar 07, 2013
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: My traxxas 3.3 monster steering is twitchy but is
I hate to say this but... the reversed steering problem could be in the remote or in the chassis. Reversing the 2 wires on the steering servo would most likely the quickest fix. However.... what you really have is a product defect.
If you have a receipt I would recommend exchanging it at the retailer or go through the nightmare of a product warranty before doing any repairs.
Traxxas offers a 30-day limited warranty on all their electronic components and a two-year, manufacturer-defect warranty. You have a manufacturers defect.
http://www.traxxas.com/support/Traxxas-Warranty-Service
1-888-872-9927
I hope this points you in the right direction. I personally would not mess with an under warranty unit. It would void the warranty.
Thanks for choosing FixYa,
"Seasons Greetings"
Kelly
Posted on Dec 26, 2010
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
Traxxas bandit vxl doesn't work i left my traxxas bandit vxl for 1 day and came back and drove and when i got outside and drove pass my sidewalk to go on the road the esc started flashing red slow
Are you running a lipo or nmhi? You could have the lipo cut off turned on and the battery is too low. Or it could have a bad motor. Try hooking up another motor an see what happens. Or try to turn off lipo mode.
Mar 13, 2012 | Traxxas Bandit Vxl Brushless Buggy
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
Nov 12, 2011 | Technics SL-BD20D Turntable
Truck has electrical power but won't turn over. I think I can hear the starter solenoid engaging. Not sure. where do I start trouble shooting?
Safety first!--Make sure you're in park & brake on-- Try shorting across the starter terminals with a screwdriver,if the bendix kicks in & nothing spins,remove the starter & put in bench vice ,(or hold down securely), & jump with cables.--REMEMBER POLARITY--If the starter spins you are in deep *******---something in the motor is probably locked up.(If the starter doesn't spin get a new one.)
Sep 24, 2011 | 2007 Nissan Xterra Off Road
I'm tryin to find out if my a/c compressor is out. So I know that the dealer said that I need it charged and I didn't get it done. So lately it has been makin a loud noise and rattlin on the...
You may be having AC problems but that is not what happened when the Steering locked unless the AC is on the same belt as the Power steering unit. That whining you are hearing when you turn is actually the power steering unit being low on fluid or the power steering pump going out. Based on what you have described my guess is that the unit has gone out and needs to be replaced. As far as the AC compressor is concerned, if the unit is low on Freon it will not engage once it gets too low unless the clutch goes out. When you look at the center of the AC compressor when the engine is running and the AC is off you should see the pulley free spinning and the very center of the pulley won't be spinning, that is the clutch Dis-engaged. When you turn the AC on the Clutch should engage and allow the compressor to work. You will hear it kick in and kick out repeatedly if it is low on Freon. If it is too low it will never kick in because the low pressure switch won't allow it.
Jun 16, 2011 | 1995 Oldsmobile Aurora
My RC Traxxas Stampede stop working. The steering
Spin the rear wheels and make sure nothing such as a small stone is binding something up in the driveline. Check to make sure the motor has not gotten disconnected from the ESC. If you still have problems with it post again and I will try to look further into it.
Dec 05, 2009 | Traxxas Stampede Monster Truck Rtrw/Xl 5
Traxxas Slayer Pro 4x4 Nitro 2.4ghz Sc Truck Tra5907 Logo
105 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
