Question about Nextar MA99T MP3 Player
I've lost my mini disk for my matsui mat110mr can someone help
I've lost my mini disk for my matsui mat110mr and i want to upgrade my firmware can someone pleases help chears i dont have the mini disk and my mp3 player has a radio on but cant get it to work there is a errer
5 Suggested Answers
  • 3 Answers
SOURCE: SIGMATEL FIRMWARE
see
http://www.fatsquirrel.org/veghead/wot/matsui.php
Posted on Dec 18, 2007
mlake33
  • 427 Answers
SOURCE: want to upgrade firmware version 9.1.52
Once the firmware is uploaded onto your computer, there is no way to get rid of it unless you ran a system restore on your computer which is completely not worth it.
Posted on Apr 19, 2008
SOURCE: HOW WILL I RESTORE MY FIRMWARE
Hi, I have one of these ipod look alike players it's only a 1 gig version i bought for my daughter but she no longer uses it i can dump the Firmware for you and email it of to you if need be.
Other thing i can suggest is you try this site for help.
http://www.s1mp3.org/en/
Hope that helps.ttfn
Posted on May 11, 2008
  • 20 Answers
SOURCE: how to get firmware update for mp3.
The website doesn't have a firmware update, so there is none.
Posted on May 31, 2009
tamcross
  • 96 Answers
SOURCE: FQA Need to download firmware upgrade, for my MP3
PLUG INTO COMPUTER
Posted on Jul 02, 2010
I keep getting this message every time i switch on my meizu device " no resource please upgrade resource again" i ve tried switching it on and off but in vain. Please help ASAP.
Hi, you will need toupgrade the mp3player before you can be able to use it.why?, because the previous version has expired and can not be use again. So the only way you can use the mp3 player is to upgrade the firmware..
You can upgrade with the link below to download the Software to upgrade the firmware of the mp3player.
wareseeker.com/free-meizu-miniplayer-firmware/
Hope it helped
Feel free to pass your comment.
Thanks for using fixya....
Jan 13, 2011 | Meizu M6 Digital Media Player
Won't boot up and not recognised when connected to PC
MANUAL FIRMWARE UPGRADE PROCEDURE:
During the upgrading of the firmware, if you turn off the power of M800, either by manually switching off the power or removal of the battery, the file system of M800 will be damaged, which will lead to booting failure problem. When this happens, you will not be able to turn on M800. Booting failure problem can be easily repaired by “manual firmware upgrade”. The procedures for manual firmware upgrade are as follows:
1. After firmware upgrade, only the blue LED under LCD is on, but LCD display is not turned on, please proceed manual firmware upgrade.
2. Remove the battery.
3. Put the battery back into the player again.
* Notice ! : Do not turn on the power.
4. Connect the player to your PC.
5. While pressing the volume down button, power on the player.
6. Now PC should recognize M800 as one of its hard disks.
7. Download the latest firmware file into the root folder of the player.
8. Disconnect the player from your PC.
9. The blue light LED under the LCD display will flicker.
10. Wait for about one minute, blue LED is off. Turn on the player.
The manual firmware upgrade is now completed.
Jan 04, 2009 | Audio Players & Recorders
INSTRUCTION MANUAL.
I've spent 20 minutes googling matsui>mat110>user manuals>drivers and came up with nothing. I could not even find help at the Matsui web site. I did find several threads on different sites complaining about the lack of documentation. If you have a phone number for them I'd use it.
Sorry and good luck.
Sep 16, 2008 | iLO (2 GB) MP3 Player
Gogear sa5125/37 lost softwear got from site still dont work
Download the user's manual also from the website - it will let you know what to do next. I have written an article that you can see in the "Tips & Tricks" section on how to download songs to your Mp3 player using Windows Media Player 11.  Make sure you get the firmware update before using Windows Media Player 11, however: Philips issued a firmware upgrade for this model to correct the freezing issue.  You can't use the version of the Philips Device Manager that came on the installation CD.  You have to go to www.philips.com/support, enter your country, enter your model #, click on SA 6045/37 without the B, and click on the Software & Drivers link.  Within the software & drivers link, you must download the link underneath "Device/Firmware Manager" - this will give you the latest version of the Device Manager.  Using the new Device Manager, connect your mp3 player to the computer and click on the "Update" button within the Philips Device Manager.  This will upgrade your player's firmware, and fix the freezing issue.
-Tha Mp3 Doctor
Sep 13, 2008 | Philips GOGEAR SA6045 MP3 Player
It swithes on but it freezes when it says matsui i only got it one or two days ago so i can listen to it on the plane when i go on holiday tomorrow
Make sure you have upgraded the firmware - instructions for doing this are on p. 14 of manual - this is a POS player - return it if the store will allow you
Jun 09, 2008 | Audio Players & Recorders
On my matsui MP3 player
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Apr 12, 2008 | iLO (2 GB) MP3 Player
I lost the disk to my sansa and now i con't delete the music from my sansa
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 07, 2008 | Audio Players & Recorders
Matsui MP3 Player
no my player is not working condition ..randi makkalya nimma company band madari bhosadfi makkale
Feb 28, 2008 | iLO (2 GB) MP3 Player
SIGMATEL FIRMWARE
http://forums.cnet.com/5208-6035_102-0.html?forumID=71&threadID=268496&messageID=2624104
Nov 28, 2007 | iLO (2 GB) MP3 Player
MATSUI MP3 2GB MAT120MR
Try to reformat it. If that is not your solution then reflash your firmware from the small CD you recieved with your MP3 Player. If you don't have that software you will find it at the following link:
http://www2.evilshare.com/358645f6-1bfe-102a-847b-00a0c993e9d6
Download it and open the the " programs " (There is only one) Once you'e in that folder.... double click on this folder "stupdaterapp.exe" Just simply follow the instructions and you should be fixed.
Nov 03, 2007 | iLO (2 GB) MP3 Player
Nextar MA99T MP3 Player Logo
116 people viewed this question
Top Nextar Audio Players & Recorders Experts
Joseph Hoffmann
Matt Piilo
Matt Piilo
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
