Question about Element Electronics Televison & Video
What screw size do I need for the tv stand base for my 40" Element Electronics TV Model No: eldft 404
I'm referring mainly to the 7 holes on the bottom of the tv stand base to sit on a table-top, or tv stand
SOURCE: Base Detachment
If you lay the TV down on something soft but firm (towel on the floor or counter) put the screen face down on the back you should see 4 screw holes with the an (S) next to them. They are located at the center near the bottom. If you remove these screws the stand should then slide out of the bottom of the TV. Good Luck
Posted on Jul 13, 2008
ldaala
  • 65 Answers
SOURCE: need screw size for 26" niko tv stand. to mount the tv to the stand
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
Posted on May 26, 2009
budmrtn
  • 11361 Answers
SOURCE: Need to know what size screws i need for my
Most of them use either metric M5 or M6 size, try local hardware store wih different length.
Posted on Nov 02, 2009
  • 8457 Answers
SOURCE: I LOST THE SCREWS OF MY TABLE TOP STAND OF MY
Read the informations of those screws to tighten the tv and the base stand together.Read it in ur owner manual for those exactly screws sizes.Standard screws tvs sizes for a 46" are screw (M4 X L16).
Posted on Feb 14, 2011
  • 302 Answers
SOURCE: vizio l32 tv stand screw size
The best thing to do is trial and error. Get some sample screws from home depot.
you can get parts for this tv at www.interliquidparts.com
Posted on Feb 25, 2012
I need a replacement base stand for this tv. Any help with this?
Shop for base stand for tv on Google
Television Stand Assemb...
$15.10
Sears Parts D... Sanus EFAB?B1 ? Modular Aud...
$79.99
Google Trusted StoreThe Simpl... Atlantic Furniture Tabl...
$32.78
Walmart Convenience Concepts Des...
$39.99
Google Trusted StoreWayfair Atlantic Table Top TV Mount...
$24.88
Jet.com Search Results
    Universal TV Stand / Base + Mount for 32" - 60" Flat-Screen...
    www.amazon.com/...Stand-Base...Flat.../B00DZVPFG...
    Amazon.com, Inc.
    Rating: 4.6 - ‎492 reviews
Jan 10, 2016 | Televison & Video
Need plastic base for AOC LCD TV
Try searching eBay first. You might be able to purchase a generic replacement stand that uses the wall mounting screw holes.
Jun 24, 2012 | AOC L19W898 19 in. LCD TV
I need the base table top stand for my Sharp Aquos LC32GP1u TV. I can't find anything under $135! Thats almost half what the TVs worth now
I just got one from a guy named Steve in Santa Barbara. He has at least one more. See eBay by searching for a similar model with a broken screen. FYI, all of the FC-20b... series seem to use the same stand. Good luck
Jan 07, 2012 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
I broke the table top base for my new Haier HL32XSL LED LCD tv and can not find a part number or place to order a new one.
If it is not practical to glue the base back together with metal-filled epoxy (e. g., J-B Weld), then consider whether you can adapt the hardware to a custom wood base. If you are not comfortable with your woodworking skills, any cabinet shop could probably make a base for you. Be sure to include space for the base weight in the bottom of the wood plate, and specify that it must be capable of supporting the set. (The entire weight of the set including the original stand is 50.7 pounds; subtract the weight of the stand to find the minimum support capacity.) If the vertical arm broke, it may be better to replace it with steel or aluminum channel or tubing.
If the original stand mount scheme is not amenable to a hardwood base, you can build a stand to use the wall mount holes in the back. Be sure to offset the base weight forward enough so the weight of the mounting bracket doesn't tend to tip the set backwards.
May 24, 2011 | Haier HLH326BB 32 in. LCD HDTV
How do I install the base stand?
Just put base stand into a hole of the main LCD tv unit at bottom base hole and make sure all the screws holes lines up.Put in those holes with 4 or more philips screws on those holes and now just used a philip screw driver turn it clockwises to tighten those philip screws for it to hold on to the base stand.
Feb 05, 2011 | Samsung LN46A530 46 in. LCD HDTV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Sony bravia pedestal stand is unstable
http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf This link will show what it looks like when removing base to wall mount.They always recomend a mounting strap that connects to the rear of the TV and then screws into the table it will be sitting on.Not sure what they expect you to do if you have a glass top table. http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf
This is a link to all the downloadable manuals and what not.Well hope this will help,and good luck.
Mar 13, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Setting up tv on stand
Installing the stand on Samsung LE40R73BD LCD Television
Note: Use 4 M4 X L16 screws only.
  • Slowly and carefully put the TV with the screen facing down on a table with soft cloth or cushion.
  • Insert the stand into the hole at the bottom of the TV. Refer to page 2 of the Owner's Manual.
76bfa5b.jpg From page 2 of the Owner's Manual
  • Secure the stand with the screws into the holes indicated. Refer to page 2 of the Owner's Manual.
Dec 10, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Unit tilted. Lower on right side.
check the screw alignments on the base, if the wrong holes were used putting the base on it will be lop sided
Jun 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Base Detachment
Jun 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Televison & Video Logo
513 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
