Question about Magic Chef CTF1826AR Top Freezer Refrigerator
Water leaking into floor
Every few days I have water in the floor in front of my refrigerator. It looks like it is coming from under the bottom drawers. I assume this is a stopped up hose or something like that but I am not sure where to find the hose (or how to get to it may be more accurate). Any suggestions?
  • dato454 Jul 05, 2008
    I have water leaking out in front of the refrid. Don't really know where its coming from. Pulled the refrid. out, but i don't really know where or what to look for. I can't seem to find where the freezer would drain. I do see a pan in the back but thats no where near where the water is.
  • 3 Answers
There is usually a thin pipe, yes, that runs the condensation that forms on the inside radiator, and drops it out to a thin tray overtop of the compressor,where it evaporates. If you look below the inside radiator there should be a small gutter- follow this to whatever end it is at its lowest point(or the middle where the other gutter meets it in some cases) here will be the stasrt of the pipe. It is likely the start will be full of gunk. Use a wire or the best option i used in my appliance repair days was the old curtain wire(bendy looking about 3mm across,dont remember what its called) and feed this down. Failing this hot water poured into it might be enough to clear it. The other option for the excessive water is too much room air getting inside- wither by an obstruction stopping the door closing or that the seal is buggered- sheck that...
Posted on Jun 23, 2007
Ice accumulates at bottom of refrigerator, water leaks onto floor if not removed.
sounds like a blocked drain, either by debris or failed drain heater?
Oct 07, 2015 | Refrigerators
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
Feb 01, 2014 | Whirlpool ET1MHKXM Top Freezer...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
My kenmore is leaking water once a day .
You didn't say from where. Usually twice a day your de-ice heating coils come on and melt any ice that has accumulated. this water usually runs down the back of the ref. and collects in a small pan under the ref. Someime ice form around the hole that the water drains down through to go into the small pan. so then when the deicer comes on the water just runs down the bottom of the ref and onto the floor. My Kenmore does the same thing. Remove everything from the bottom of the Freezer look in the back at the bottom see if hole is clogged with ice. Remove ice then pour hot water down hole check occasionally.
Aug 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
Water Leaks from front door
My tenants informed me that water was showing up on the floor in front of the refrigerator. I checked the back where the evaporator tray is and it was dry. When i looked inside the refrigerator I notices water pooled inside, under the plastic bottom drawer. Anybody have any idea what i should do? thanks.
May 29, 2008 | Refrigerators
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Magic Chef CTF1826AR Top Freezer Refrigerator Logo
162 people viewed this question
Top Magic Chef Refrigerators Experts
Level 1 Expert
John Tripp
John Tripp
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
