Question about Dell Inspiron 15R 5520 Core i5-3210M 2.5GHz 8GB 1TB 15.6" Laptop
After capturing the image it will show like a mirror image
I bought new laptop but there is 2 problems are here 1)the image show like a mirror image 2)the disk drive is stucking some times when enter to F2 then it will be work other wise it will not work. plese solve the above problems
  • Dell Master
  • 7,627 Answers
"the image show like a mirror image"? What image? In what? Why are you entering F2? I'm not clear what the problems are?
Posted on Dec 30, 2012
  • 30 Answers
SOURCE: i have Dell inspiron 1525
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
Posted on May 17, 2011
Testimonial: "thanks for your reply its very helpful"
  • 3940 Answers
SOURCE: I haev a Dell 1501 Insprion and when it boots up
Try these:
http://www.fixya.com/support/r3728860-troubleshoot_system_will_not_boot_hard
Posted on Dec 30, 2009
Pyrhyc
  • 2028 Answers
SOURCE: stand by and hang problem
This is going to be a simple software glitch. Start by doing a system restore. You may have to go back two or three restore points before it corrects itself. The restore should fix it, but if it doesn't, then you will need to run a system repair with your recovery or operating system disc.
Posted on Aug 06, 2008
frcs68
  • 1605 Answers
SOURCE: laptop stuck
sound like you are running low on memories, or runing low on hard drive space.
if yo are runing WIndows Xp/Vista. go to
start>>programs>>accessories>>system tools>disk cleaner.
select all that apply and press enter.
Posted on Dec 12, 2008
SOURCE: Dell XPS w/Mirrored drives. No C drive when using boot disk.
As RAID uses block for block copy, a re-sync when adding in a new mirror on RAID 1 will take some time, and system performance will be affected during that time period. There is no indication in windows if the rebuild is complete as this is being done on a hardware level by the controller. Both Raid 5 and RAID 10 have added benefits , but alos require more storage (a lot more in case of RAID 10 as you will have effectivly 3 spares for 1 data.) Raid 5 has the best space/protection pay off, but will be slightly slower than both RAID 1 and RAID 0 as parity has to be calculated for each write. As caffineshark states your best option is to use a combination of the methods we have described:
1) Use the two SATA disks as RAID 0 for performance and reliability.
2) Make backup images of the boot volume using Drive Image / Ghost and store on external USB IDE drive, and then offsite.
If you make an image in the USB drive, make sure you run a verfiy of the image after creation to make sure it's valid.
This should allow you to restore in a DR sutuation, but also give you some decent HDD crash protection.
Posted on Jan 29, 2010
My lenovo easycapture has changed my image to the opposite way round how do i change it back
WEBcam image problem Most WEBcams have a setting to mirror or turn the image upside down etc. Go to your WEBcam setting to set your image back to normal.
Apr 26, 2013 | Lenovo G550-29583AU Notebook
Laptop image is opposite when you capture images
Look at the settings of your camera Application and look for Mirror Image and put a check on it to get the exact image captured instead of having the image as the opposite when taking pictures or recording a video.
If not Mirro Image there should be an option for flip image horozontal and flip vertical, you just need to put a check on the Flip horizontal image or Mirro Image this depends on the Brand and the application as well of the Laptop this should correct the camera settings.
Most laptop cameras are now using a different format and needs to be set up on the application to get the mirror image of the snap shot or recorder video as what you are expecting.
I hope this helps.
Oct 03, 2011 | Computers & Internet
The webcam installed in the notebook, which I use to Skype, shows my image upside down. How can I make it show it right side up?
In skype options; go to video settings. Click the webcam settings button, this will open a "capture properties" window. in this window, test checking the "mirror horizontal" check box.
Hope this helps ;)
Jan 27, 2011 | Lenovo IdeaPad Y510 Notebook
How to do print screen in Compaq nx6120 laptop ?
The same as on most PC's, by pressing the Prt Sc button on the laptop OR the FUNCTION key then the Prt Sc then go into Paint and click on "edit" / paste then your screen shot will show.
Nov 01, 2010 | HP 378248-001 keyboard for Compaq nc6110,...
Scanning problems. Could not scan into old Dell Laptop anymore. (Motherboard bad on Dell). Now, new computer Apple, and tried to scan. Says it is scanning into HP Photo program, which is not on this new...
Try these. 1 in applications find image capture, make sure printer is conected and on, launch image capture and see if it finds the scanner. 2 go to the HP website and see if there is software to download.
Mar 17, 2010 | HP PSC 2210 All-In-One InkJet Printer
N97 photo processing delay
Go to Nokia website and update/re-install your phone software to the latest version.
Sep 03, 2009 | Nokia N97 Cell Phone
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Sep 09, 2008 | Fuji FinePix J10 Digital Camera
Sony DCR-HC38E Exporting miniDV video to computer
I had a similar problem with my Sharp camorder.
The preview window on XP simply displays corrupted images.
At the end, I bought a different firewire card and it worked for me.
Good luck.
Alex
New Zealand
Jan 15, 2008 | Cameras
Pictures captured by my camera are not complete
your cmos sensor might be dead. try taking it into canon for repair.
Sep 04, 2006 | Canon Digital Rebel / EOS-300D Body only...
Dell Inspiron 15R 5520 Core i5-3210M 2.5GHz 8GB 1TB 15.6" Laptop Logo
62 people viewed this question
Alun Cox
