Question about Samsung Galaxy Tab Tablet PC
Home key on Samsung 2 tablet not working
The home button originally worked, but after recharging the 1st time it did not work anymore.
    New Friend:
    Problem Solver:
  • 11 Answers
This sometimes happens Buy a new Charger it might be stuffing up the system if not go and see the place where u bought it from they can help u!
Posted on Feb 11, 2013
2 Suggested Answers
Ezrahite
  • 2632 Answers
SOURCE: I was trying to upgrade
Welcome to Fixya. It seems that you already did the hard reset and still wont work. Can you try to do a safe mode and incase you will be able to access the safe mode you can do a master reset. However if still won't work the issue is that the upgrade makes the Andriod system corrupted.
1. If the device is on, turn it off.
2. Power on the device. Press and hold the Menu button when the Samsung logo appears on the screen.
3. Continue to hold down the Menu button until the Home screen loads. You should see the words Safe Mode appear in the lower left corner of the screen.
If this still wont work then you need to bring the device to a service center so that they can bring it back the original andriod os.
Thanks
Posted on May 10, 2011
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
Why did it shut off and doesn't restart?
Is it recharging properly, might not be charged and is auto shutting down to save data.
Check your charger is working and the connection to the tab is good.
Bad fitting USB can cause failed charge.
Apr 04, 2016 | Samsung Galaxy Tab Tablet PC
Frozen tab2 10.1 samsung
Try this lol,
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
NOTE: You'll not only lose the apps on your internal memory and the data associated with it. All the device updates will also be lost and you'll have the version of Android your tablet came with.
If you want see the video, you can visit my blog
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Dec 13, 2012 | Samsung Galaxy Tab 2
I just bought Samsung Galaxy Tab GT-P100 last month, but now somehow Camera feature is not working. There's message says: "Warning: Camera failed" pops up on screen whenever I want to use camera...
do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
Apr 03, 2011 | Samsung Galaxy Tab Tablet PC
Tablet wont power on. Holding power and touching screen for 30 seconds does not work.
Apr 02, 2011 | Samsung Galaxy Tab Tablet PC
My galaxy tab screen has blanked out and i cannot get it to do anything
option 1. Plugin in Power Cable Then Hold Volume down + Power button for 10 to 20 secs Your tab will Turn OFF. now turn it on using simple power button it shd work perfectly option 2. do one thing Turn Off Your Tablet
Mar 31, 2011 | Samsung Galaxy Tab Tablet PC
Screen will not rotate only displays horizontal
Option1check if your tablets orientation is locked or what Option 2: do one thing Turn Off Your Tablet
Password
Mar 28, 2011 | Samsung Galaxy Tab Tablet PC
My samsung galaxy tablet won't turn on. Please help.
  • my tablet did the same thing, all you have to do is make sure it is fully off, then you hold the power button for a short period of time, then you hold the volume button at the same time either up or down, (depending on which tablet you have) and wait until the android logo comes up. Then there are options, you are to choose ''wipe data factory reset button'' (you choose your options using the volume up/down button) wait maybe 30 seconds and then more options come up you choose ''reboot'' wait another 30 seconds, then turn it on it should work but if it doesn't work, take it back (if you still have the warrantee) and you could get a new one or the professional's fix it anyway hope this helps everyone. ;)
Jan 20, 2011 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy Tab Tablet PC Logo
297 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
