I have toshiba tecra a9 leptop it takes long time to charge minimum 3 hour what is the error please help me
My leptop take minimum 3 hour to charge what is the error please help me
  • 7,627 Answers
How old is the battery? Do you use on battery alot? The battery will charge until it is full, times will differ? If you use on AC most of the time remove the battery.
Posted on Dec 30, 2012
5 Suggested Answers
vincent721
  • 240 Answers
SOURCE: FN key not working on Toshiba Tecra A2
You can enable/Disable Fn key in System Setup.
to access system setup press F2 when you see the Toshiba logo
Posted on Mar 15, 2009
Geekman
  • 32281 Answers
SOURCE: toshiba notbook tecra s1 model no 831l-1104l -- No Display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 27, 2009
  • 1170 Answers
SOURCE: No Sound on my Toshiba Tecra a9-s9015X
Good day.
Download the driver from this website :
http://www.drivershq.com/Drivers/Toshiba/Tecra/A9-S9015X/4183/11021/28196/Drivers.aspx
Your respose is highly appreciated.
Regards,
Arjun
Posted on Jun 13, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: My Toshiba Tecra A9 overheats and shuts down
Check to see if the cooling fan is working properly. You should hear it running if you put your ears close when the computer is on. If the fan is working and the cause of overheating is not the fan, then you may have a deffective battery, check to see that the battery can take up charge. If the battery is fine, then you may have a chip inside the computer that is overheating because of internal defect. This job would be best left for experts.
Posted on Aug 06, 2009
RESET POWER ON PASSWORD
The BIOS pwd last time I checked could not be reset. You would have to contact the Toshiba Support and they may have another work around for the BIOS password. This is used commonly as an anti theft measure.
Dec 20, 2013 | Toshiba Tecra A9-S9012X Notebook
Toshiba Tecra A9 Model: PTS52A-0EW03F. Can i upgrade the graphics card, if i want to install dedicated card there is option or not. I also want to upgrade hard disk and Ram please advise me i can upgrade...
Laptops have built-in graphics card on the motherboard and cannot be replaced with a different graphic card.
You can upgrade the RAM to 4 Gb and install a larger SATA hard drive.
This WEB site gives the specs of this laptop.
http://www.cnet.com/laptops/toshiba-tecra-a9-s9021v/4507-3121_7-32906197.html
Dec 26, 2012 | Toshiba Tecra A9 Notebook
ARE ALL TOSHIBA TECRA A9 MOTHER BOARD COMPATIBLE AND I NEED A MOTHER BOARD FOR TOSHIBA TECRA A9 MODEL NO. PTS52E-012033ZA
Just buy another PTS52E it will be ok, but replacing a MoBo in a laptop means taking the whole thing to bits, if you dont know what your doing, let a shop do it for you.
Jul 09, 2012 | Toshiba Satellite P105-S6197 Laptop
I NED REMOVE BIOS PASWORD IN MAIN TOSHIBA TECRA A9
first you can remove lap top battery and cmos battery and keep your laptop 24 hours after you can reinsert your bios battery and main battery after switch on it. if still having the same issue?? " You call tech support. give PROOF OF OWNERSHIP. You then tell them your service tag/serial number, they enter it in a equation which parses the number and tey will give you a one time use password "
Sep 16, 2011 | Toshiba Tecra A9-S9013 Notebook
Reset bios pts52u-07q01m motherboard
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Mar 09, 2010 | Toshiba Tecra A9-S9012X Notebook
How do I change the RAM in my Tecra A9 laptop
you need to unscrew a screw from it´s bottom. The memory is pretty good accessible.
http://www.notebookcheck.net/Toshiba-Tecra-A9.5643.0.html#
Vladimir
Oct 15, 2009 | Toshiba Tecra A9-S9021V Notebook
Aug 06, 2009 | Toshiba Tecra A9-S9021V Notebook
Help me with my forgotten password on startup a9 toshiba tecra
you forgot your pass word try logging on through safe mode just regular safe mode if it asks for a password try putting administrator as the name with no password if you get in go to control panel create new account with or with out a password just write it down this time cheers mate
Jun 23, 2009 | Toshiba TECRA A9 PC Notebook
Driver dc
Select your model on one of the web pages below depending on your location:
Toshiba Support - Homepage
Toshiba - Download drivers
Feb 16, 2009 | Toshiba Tecra A9-S9013 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
