Question about Canon imageRUNNER 5000 Copier
I want to change my counter reading from 15000 to 20000 how i can do this in ir5000imagerunner copier machine i can do it or not need any software or i can do my self
    Problem Solver:
  • 8 Answers
You cannot change the counter,its set from the factory, but i believe someone can crack the firmware/sotware,but not me
Posted on Feb 04, 2009
    Scholar:
  • 62 Answers
Sorry to say u cant do that.
Posted on Jan 22, 2009
Reset counter brother printer hl-6180dw
By 'Counter' do you mean Toner Counter or Drum Counter?
For Toner Counter - This is done by the gear on the side of the cartridge. The gear when looking at it travels counter clockwise lifting outwards as it passes over a mount in the fill cap. Starter Cartridges do not have the gear in place and this needs to be put in when refilling the cartridge.
For Drum Counter - Have the front of the machine open (As if changing the cartridge) and press the Go button on the machine till the display reads Drum Changed or Drum Accepted.
If it requires you to press the back button then it will have a message "Change Drum" with an up arrow and down arrow for yes and no.
Feb 04, 2013 | Brother International HL-6180DW hl6180dw...
Show that ink is finished , but it's not .
Printer "read" ink level counter, not ink level actually. Refillable ink tank read as empty ink. Two methods to resolve this. Reset ink level counter using software. Or disable ink level counter reading.
Jan 26, 2013 | Canon PIXMA MP495 InkJet Printer
Error 990
sc990 is a general software error and could be caused by a number of things.
Is the copier very dirty, or are the PM (preventive maintenance) parts past their recommended counters? The copier may just need some new process parts (drum, charge roller, developer, etc.) and a good cleaning.
Does the 990 happen when you are printing or scanning? It could be an error with how the machine interfaces with your network.
Or, it may be a system firmware issue and the firmware needs to be updated or flashed.
Jul 05, 2010 | Ricoh Aficio 2035 Copier
I changed the drum but it still reads drum error and i am not receiving faxes. There is a ring so the connections are working. I cant get in to the area where it reads drum set.
Need to know Make and model to be sure.
However, many new machines reset the drum counter by blowing a fuse in the drum cartridge or by recoginition of a new chip in the cartridge. Some require a "Service code" access to reset counter after the drum has been replaced. Need specifics to be more help.
May 11, 2010 | Office Equipment & Supplies
Ir 3300
E247 The software counter memory PCB and the software counter
value stored in SRAM are found inconsistent are you try to adjust the machine counter reading? That is Canon security features you cannot adjust counter by replacing soft counter board
Jul 21, 2009 | Xerox C2424 Copier
How to change counter reading in ir8500
You can not. The chip needs to be reflashed by Canon in order to be reset to zero
Jun 18, 2009 | Canon Office Equipment & Supplies
Printer not printing. Error message reads see your documentation may need service
Counter reach its preconfigured limit it is just, you have to reset the counter back to zero count. This feature could be attributed not to overflow the waste bin.
In your web browser search bar, key in " epson reset software" the uppermost link is the one. Read the tutorial before doing so.
Hope you get it easily.
May 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
Jan 05, 2009 | Brother MFC-8460N All-In-One Printer
How to read the meter on Cannon Copier
Yes, that is the correct counter of the copier. If you are doubting it, you can look at the bottom right of that display and confirm that the serial number is the same as on the back cover of the copier and also, it well tell you the model of the copier aswell. It is kind of hard to fake the meter or change it to a lower amount. To do it you need to change 3 PCB's from another copier & it is more work to bother with.
Nov 06, 2008 | Canon NP 6050 Copier
The mfc9440cn i have is continuly saying that the belt unit and the drum need to be changed even though they have both been changed recently. Is this a problem with the printer or the belt unit/drum?
You probably need to reset the counter on the parts life. Depending on the machine you have - you can do a parts life check - but it will always read 0 part life left, if you haven't reset the counter...
Jun 18, 2008 | Brother Office Equipment & Supplies
Canon imageRUNNER 5000 Copier Logo
85 people viewed this question
old marine
old marine
