Question about Sony BDP-S350 Blu-Ray Player
Can the Sony BDP-S350 play MP4 Videos?
I have a Sony BDP-S350 and it plays Blu Ray discs and regular DVD discs fine. But it will not play a MP4 video file. Does anyone know if this player accepts MP4 videos and what can I do to allow this. I have the latest (026) software loaded.
4 Suggested Answers
SOURCE: SONY BDP-S300 WON'T PLAY BLU RAY DVD OF 2012, HAVE
I think sony should reiemburse you and me for this piese o !@!@
Posted on Apr 01, 2010
  • 10 Answers
SOURCE: our blu-ray disc player bdp-s300 won't play newest blu-ray
You will need the following:
1) Internet connection
2) Wired router
3) long enough ethernet cable to reach from your blue ray player to the router.
Step 1:
Eject any disks and turn off the blu-ray player by unplugging it.
Step 2:
Attach the ethernet cable to the router and the other end to the ethernet port on the back of the blu-ray player.
Step 3:
Turn on the blu-ray player and wait for it to load all the way.
Step 4:
Using the remote, arrow over to the left to "Setup", the up to "Network Update".
Step 5:
After the unit updates and restarts, repeat until it tells you "Already Updated".
That should help you play the newer movies, and even some of the older ones.
Posted on Apr 03, 2010
  • 1548 Answers
SOURCE: My Sony Blu Ray player BDP BX1 won't play any
I assume you tried the software update after the unit failed. If it quit working because of the firmware update, you may have received a corrupted file. In that case, try downloading a new copy on a different computer or to different media, and repeat the update.
If (assuming hardware problems and not bad firmware) it cannot play any optical disk, not even audio or photo CDs, I would suspect the laser in the optical drive has gone bad. Replacement is not a lot of work, but the part is probably about $50. I think it's likely this is the same part used in the Sony Playstation 3, which had some problems with lasers dying too soon when it first came out.
Here's a way to check: first, insert a DVD in the player. Unplug it and remove the top cover. Caution: do not tip the player with the DVD inside. CAUTION. Directly viewing the laser can cause severe damage to your vision. DO NOT put your face over the DVD drive - ever - while it is plugged in. Observe it from the front, a little off to one side. Before plugging in, check the ceiling overhead and make sure there are no mirror-finish or glassy reflecting objects above the player. The DVD must be in first for safety reasons; it covers the laser. The rest is additional precaution.
Now, plug in and turn on the player. In normal operation, the laser comes on, and the lens moves up and down to focus on the disk. You may see a blue glow in the center of the disk (especially in a dark room). If the laser is working and the laser/lens assembly is able to obtain a focus, the disk will start spinning. If the disk does not spin, the laser/lens assembly is the first suspect. It is also possible that the spindle motor drive is bad, but given the history of PS3 Blu-Ray drives...
If there is no movement of the lens assembly, check the power supply. If it is good, there is (by elimination) another problem with the lens assembly (controller problems, to the best of my knowledge, are rare). Because it has very tight assembly tolerances, the lens assembly is usually replaced as a unit rather than repaired in the field.
Posted on Oct 17, 2010
Why won't it stream or play disk?
Call Kurtis: Why Your Samsung Blu-ray Player May Not Play ...
sacramento.cbslocal.com/.../call-kurtis-why-your-samsung-blu-ray...
KOVRSep 26, 2013 - Blu-ray players aren't the same as DVD players. ... disc compatibility issues arise and firmware updates for our Blu-ray players are ... My BD-C6500 is apparently one of those old blu rays that won't play blu rays. ... If you are viewing netflix streaming thru your samsung bluray then YES it definitely can. Its not ...
play mp4 files on a blu-ray player - MP4 - Streaming Video ...
www.tomsguide.com/answers/id.../play-mp4-files-blu-ray-player.html
Jan 9, 2014 - I see a lot of Bluray players will play mp4 files. ... If it won't do it via the USB port, will it do it if the mp4 files are on a DVD? ... player has a menu, items likeDisc Tray, Netflix (I use this menu choice to watch streaming Netflix), ...
Sony BDP-S590 3D Blu-ray Disc Player with Wi-Fi (Black)
www.amazon.com/...Blu-ray-Player.../B006U1YUZE
Amazon.com, Inc.Sony BDPS790 4K Upscaling 3D Wi-Fi Blu-ray Disc Player. 4.0 out of 5 stars 334 ยท Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player .... With the Sony BDP-S590, you can wirelessly stream music throughout the home to .... at internet.sony.tv as in the past some Sony products won't connect to certain services ...
Amazon.com: Sony BDP-S5100 3D Blu-ray Disc Player with ...
Jan 07, 2016 | Televison & Video
My sony bdp-s350 can not play netflix steaming
I'm sorry to inform you that the Blu-ray player does not have the feature to stream videos from Netflix. The network connection on the player is used for watching BD Live content from the playing disc and network update.
Thanks for understanding.
Please let me know if you require any clarifications.
Mar 27, 2011 | Sony BDP-S350 Blu-Ray Player
Uxpendables blu ray won't play on my bdp s350. It says Unknown Disc. update not needed I already checked.
is that the only disc that wont play? have you tried inserting memory stick on bd player. format memory stick (atleast 2gb) first to fat 32 using computer. insert to usb slot of bd player. then try to play the disc again...
Dec 24, 2010 | Sony BDP-S350 Blu-Ray Player
My sony blue ray player is only playing DVD's but will not play blue ray disks. i have tried multiple disks
I'm having the same problem. My BDP-S350 Blu-Ray Player used to play blu-ray DVD's but suddenly is unable to. Regular DVD's I can play. Please help!
Nov 25, 2010 | Sony BDP-S350 Blu-Ray Player
I have upgraded the firmware of my BDP-S350, but still will not play any blu-ray discs. It plays dvds just fine. The error is "unsupported disc".
has it ever played blu-ray's properly any odd issues leading to this problem and it could be a weakened laser these are just more expensive dvd players that are just as prone to wearing out hope this helps you:)
Nov 17, 2010 | Sony BDP-S350 Blu-Ray Player
It freezes when playing a blueray movie. it seems
The most likely cause of your frustration with the BDP-S350 is that your player's firmware is not the most current. Most often, the firmware problem is JAVA related and will not let the menus load at all, but freezing during playback has also been reportedly fixed with the firmware upgrade.
The solution is to go to sony's website, download the firmware upgrade, burn it to a disc and then load the disc into the player to fix it.
I hope that helps.
Dec 19, 2009 | Sony BDP-S350 Blu-Ray Player
Crank 2 will not play in Sony S350
The software updates for your Sony BDP-S350 can be found at their website here. You will need to download the file, burn it to a disc and then load the disc into your player to upgrade its software to play your new blu-ray movie.
I hope that helps.
Oct 03, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Can a sony blu ray s350 accept movies with netflix
I just had a chat session with Sony and the BDP-350 Blu Ray can not stream video from Netflix or Amazon.
Julie_> Welcome to Sony Online Support. I'm Julie. Please allow me a moment to review your concern.
Julie_> Thanks for waiting, xxxx. I'll be glad to assist you with the information about the compatibility of the Blu-ray Player to stream the videos.
Julie_> I'm very sorry to inform you that the Blu-ray Player is not compatible to stream the videos from netflix.
Julie_> Only the BD-Live feature of the Blu-ray discs played in the Blu-ray Player can be streamed.
Julie_> At this point of time there are no Firmware updates available to make it compatible to stream the videos through Netflix. 12/2/2009
Aug 17, 2009 | Sony BDP-S350 Blu-Ray Player
SONY BDP-S300 unlock region code
DVD PLAYER SAYS CANNOT PLAY THIS DISC
Apr 22, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Sony BDP-S350 Blu-Ray Player Logo
350 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
