Question about Garmin APPROACH G6 GPS
I can't find the power button on the Garmin G6
My brand new Garmin Approach G6 will not acquire a GPS signal. Is there some way to correct the problem?
All gps units need a clear view of the sky to collect enough data for a proper "fix". The less obstructions there are, the faster & more accurate the fix will be.
Initially, the first fix may take up to 20 minutes. Long acquisition times typically occur when the unit is powered up after being moved hundreds or miles or more since its last fix. This would be the case from manufacturing location in China where it was shut off to where ever you are now when you turned it on.
Acquisition times after this should be significantly less (10 - 60 seconds)
I hope this helps and good luck.
Jan 15, 2013 | Garmin Approach G5 Handheld GPS Receiver
Garmin approach g6 screen frozen
do a hard reset...look in yr user manual for more clarification on how to do that.
Aug 25, 2012 | Garmin APPROACH G6 GPS
My nuvi 1450 won't turn on and the garmin website updater won't reconize it hooked up to my computer even my computer won't reconize it.
I had the same problem with mine and got it working by doing the following while on the phone to Garmin. Plug your charger cord into the device and your computer (do not use a laptop, you need the higher current from a desktop for this). Hold the power button down for as long as it takes for the Garmin logo to display, this could be as much as 1 minute. As soon as the image shows on the screen, release the power button. If your Garmin isn't completely shot you will see it boot up.
If you have the Garmin Web Updater program on your computer, run it and update the operating system software to insure you have the latest greatest from Garmin. Once that is done, update your XML data files - they'll be on the list of updates if you need them. Once those are done you can update any voice or language files you'd like.
Lastly, leave your GPS plugged in at least an hour or two to give it a charge. Overnight would be better to insure your battery is really well powered up.
At this point your Garmin should function normally. The Garmin tech I spoke with told me some units start acting funky when the battery runs down too low and if it's REALLY dead it won't even take a charge or power up when you hook up your charger cord. Try holding the power button for as long as it takes to get a spark & you should be on your way. If not, call Garmin's support number for your locale & they're do their best to get you back up & running again.
Cheers, Jeff
Sep 01, 2011 | Garmin nuvi 1450 GPS Receiver
My garmin nuva 1300 takes a really long time to load points of interest that i search for. For example, I typed in "Ocean City" to determine how to get to the beach, but it took a good ten...
I have a Garmin Dezl - which gets slower with less available memory. I can simulate slow behavior by planning a very long route - reducing available memory to the extreme. Unfortunately the Nuvi & Dezl (based on the Nuvi) doesn't have a function to clear up memory space.
In my situation I had to master reset the Garmin to get memory back. This clears all user data (including all POI's, favourites) and restores the factory state. A master reset works by holding the right bottom corner of the screen while pressing the power on button once.
Jul 08, 2011 | Garmin nuvi 1300 Car GPS Receiver
I have a Garmin Nuvi 660. Serial # 12P414268. I turn on my GPS and I can't key in my PIN number. Nothing is working. I recently returned from a trip to Kansas. The unit worked great until we were...
Power off your Garmin 660 unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
To back up your Garmin.
  • From the garmin drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  • After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Garmin, but be sure to rename it 'temp.gpx'.
  • On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Garmin where they are actually stored
  • You can also try powering off the unit and hitting the reset button under the antenna, or try the information above but pressing firmly the lower right side of the screen.
    This should reset your Garmin then I would suggest updating your device at the Garmin site. I will attach a link.
    Thanks for using FixYa
    https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
    May 23, 2011 | Garmin Nuvi 660 GPS Receiver
    It boots to the screen where you agree to not use it in motion you press agree and it wont acknowledge the touch on the screen
  • This should reset your Garmin then I would suggest updating your device at the Garmin site. I will attach a link.
    May 20, 2011 | Garmin Nuvi 660 GPS Receiver
    I have a Garmin Nuvi 650 with an unresponsive screen...can anything be done? Thanks
    I have garmin nuvi 680 not responde el touch escring
    May 15, 2011 | Garmin Nuvi 660 GPS Receiver
    Garmin won't power on
    My unit had the same problem. So I tried this first. With the display unit facing you, the aluminum cover plate has the the word GARMIN on it. Use you fingernail under the word Garmin and the cover plate comes off. The left part of the cover stays attached to GPS and the right side lifts up exposing the RESET button. I pressed RESET and POWER together and it works now. Hope this works for you also.
    sunfun960@yahoo.com
    May 12, 2009 | Garmin StreetPilot c340 GPS Receiver
    Garmin APPROACH G6 GPS Logo
    41 people viewed this question
    Top Garmin GPS Experts
    SHARCNET-USA
    SHARCNET-USA
    TO Lady
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
