Question about Quest 13 Trampoline and Enclosure Combo
How to assemble a quest trampoline
How to assemble
I have an 8ft trampoline but where they r telling us screw it n at it doesn't fit the t hole is round n the leg is like oval
is there a youtube video on this trampoline on how to assemble it ?
what make and model type is the trampoline. try searching for it in youtube.
Maybe that is a bolt with a nut rather than a screw type hole.
the oval shape may be designed to hold the bolt in place without turning it when turning the nut on the other side
Dec 27, 2014 | Sport & Outdoor - Others
Tip
Trampoline safety tips
According to the American Association of Orthopedic Surgeons
there are over 300,000 trampoline related injuries every year in the United
States. Many of these accidents are
caused by carelessness and a large percentage can be avoided with a few simple
precautions.
Buy padding to cover the springs, hooks and
frame of the trampoline; look for pads that are of a contrasting color to the
mat of the trampoline
Use something to cushion the surrounding area of
the trampoline - as well as underneath
Do not allow any children under the age of 6 to
jump on the trampoline
Institute a "one-at-a-time" rule for jumping
Ensure children are supervised at all times
Set up your trampoline away from structures,
trees or other play areas
Take a moment to inspect the trampoline prior to
every use
Remember, you can never be too safe when dealing with a
trampoline. Use these basic prevention
methods and talk with your children about exercising caution when jumping on
the trampoline.
on Aug 28, 2012 | Sport & Outdoor - Others
Parts for 6.5 Ft Funtek USA trampoline
Hi ,
We require a new net for this 12-14ft trampoline?
How much and can you supply these for the funtek trampoline?
Kinda regards
Cian
0416559159
Sep 03, 2014 | Funtek USA Funtek Trampoline and Enclosure...
Is it hard to assemble a trampoline? Can I do it myself?
You can assemble your own trampoline but if you are not confident with DIY maybe get someone to help you. In any case, it's much easier with two people doing it. This video on YouTube shows in great detail how you put a round trampoline together. I watched it before I put our one up.
Aug 20, 2012 | Sport & Outdoor - Others
How big a trampoline should I buy?
What trampoline to buy depends on lots of variables. The , age and weight of the users are the main factors along with the amount of space you have to put the trampoline. But my advice is also to think to the future a bit. We bought a trampoline for our younger kids and they grew out of it really fast and we had to sell it. I came across a great breakdown of trampoline s that you should take a look at on the trampoline web and warehouse site. http://www.trampolinewebandwarehouse.com/what--trampoline
Where can I buy a springless trampoline?
Springless trampolines are growing in popularity and you can find them almost everywhere. I have found a few great sites with a variety of springless trampolines for you to search through; but you may want to do some extra searching of your own as well.
http://www.amazon.com/s?ie=UTF8&x=16&ref_=nb_sb_noss&y=19&field-keywords=springless%20trampoline&url=search-alias%3Daps
http://www.premiertrampolines.com.au/springless-trampoline
http://www.ebay.com.au/sch/Trampolines-/145999/i.html?_nkw=springless+trampoline
Jul 30, 2012 | Sport & Outdoor - Others
I just bought a trampoline for our backyard. One problem, I have no idea how to put it together. Can someone please help me?
Don't worry - it seems more difficult than it is. I just recently put together a trampoline for our family and found an amazingly useful how-to guide (with pictures) that really helped me when it came time for me to assemble our *****. I would be more than happy to pass it along to you.
http://www.wikihow.com/Build-a-Trampoline
How to take a household trampoline apart
When I assembled my 14ft trampoline a few weeks ago the instruction were to attach springs at the 12 and 6 oclock positions then 3 and 9, then symetrically around the perimeter. Disassembly would be the reverse. Start by removing the spring at 12 then 6 oclock, then 3 then 9 oclock. You will always remove the spring 180 degrees away from the last spring removed. This means you'll be running around the trampoline many times but I think the idea is to remove tension evenly so that the mat isn't damaged. Once the springs and mat are removed I expect the frame will easily disassemble. My framo was like curved piping that fit together and is only held in place by spring tension. Hope this helps.
Jun 13, 2010 | Trampolines BQC1620
How to you assemble it together
put one on then go to the other side and put another on if you put one on next to the other one you will need to go around to other side and put one on there and so on
Apr 04, 2010 | Trampolines BQC1620
Quest 13 Trampoline and Enclosure Combo Logo
126 people viewed this question
Top Quest Sport & Outdoor - Others Experts
Bill Eager
Are you a Quest Sport and Outdoor - Other Expert? Answer questions, earn points and help others
