How do i adjust tint on seiki 39 inch hdtv model #sc391ts
Tint control in menu is grayed out
RFICKES
  • 51 Answers
SOURCE: Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
Posted on Jan 02, 2009
  • 30 Answers
SOURCE: Vertical height adjustment on Magnavox 19 inch LCD HDTV
try to adjust at the vertical section.hope this will help
Posted on Feb 02, 2008
  • 10 Answers
SOURCE: philips LCD HDTV -- color problems
hi
try a reset
SOURCE: unlock Olevia remote control
Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***
Posted on Jan 28, 2009
  • 9 Answers
SOURCE: My Vizio 32 inch HDTV
Maybe if you are using component input wires, one is not inserted fully. Set color to max and put tint in the center, then flip channels and look for known solid colors items of red, blue and green. You can see when one is missing, as a mixed color will just look odd, but a true r,b or g will just not be there so to speak. Hopefully is might just be a feed wire in, but be careful, as too much pressure on insertion can crack a solder joint inside the set.
Posted on Nov 27, 2010
How to re-enable inaccessible TV menu options?
Go to thru the main menu until you reach the menu item that says "Reset all".
Jul 18, 2016 | Seiki 39" Class 1080p 60Hz LED HDTV...
My tv was on 1 minute and then the picture went out then the sound what could be a problem
Customer Reviews: Seiki 32" Class LCD 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/14978588
WalmartShop all · No-Contract Phones · Unlocked Phones · Prepaid Minutes & Data ..... Seiki 32" Class LCD 720p 60Hz HDTV, LC-32G82 ... 1-20 of 45 total reviews ... for an inexpensive 32" TV for our guest bedroom and came across this one and ... Walmart is sending me a replacement and if it works well, I will update my review.
Customer Reviews: Seiki 32" Class LED 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/19717659
WalmartSeiki 32" Class LED 720p 60Hz HDTV, (2" ultra-slim) SE321FB .... I bought this as a gift for my girl friends home bar...we were booth very happy with the tv.
SEIKI TV SETUP - YouTube
? 1:42
https://www.youtube.com/watch?v=OZlNRxBe1fg
Feb 28, 2014 - Uploaded by Kevin Davidson
+Kevin Davidson Uhm how do I manually set my dns settings? ....Can u help me can u go on amazon and type in seiki 32 inch tv if its the same one as yours ... Can you help me purchase SEIKI LED SMART TV and would like to change .... Seiki SE50UY04 50-Inch 4K UHD 120Hz LED HDTV Initial Setup ...
25385173 My 32" seiki TV has no picture but sound
Dec 29, 2015 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
SEIKI TV Is not getting any power
Power supply regulator fault. Check all the diodes and capacitors.
May 28, 2013 | Seiki Televison & Video
Seiki 39" LCD SC391TS manual
No, I don't and I don't think Seiki does either. The two I purchased last night didn't have books, batteries for the remotes or screws for the bases. I have called support twice today and received two answers. I sent an email and a tweet. If I don't get an answer, I am taking them back.
Feb 13, 2013 | Seiki Televison & Video
Green tint
Go to a channel that is in black and white and turn color all the way off.
Screen should be a black and white or gray color.
If green there is a fairly easy way to adjust--let me know what you find and I will tell you how to attempt the adjustments.
Feb 18, 2012 | Hitachi 57S700 57" Rear Projection HDTV
ATT Uverse code for seiki
The code that worked for my Seiki 39 inch (SC391TS) with my AT&T U-Verse service was 1004. Worked the 1st time.
Jan 23, 2012 | Televison & Video
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Pink tint
your va and vs on power supply need to be adjusted but you have to know what your doing to set it right and requirs a volt meter
Jan 16, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
382 people viewed this question
Top Televison & Video Experts
Electro Med Services...
