Question about Sharp LC-19SK24U TV
How do I add external speakers?
I want to add two external speakers to this TV. The manual doesn't show a way to do this. I have two small two way speakers with the traditional red and white wires with plugs for the terminals. Can anyone help? Thanks
2 Suggested Answers
donitarenzo7
  • 27 Answers
SOURCE: I'm trying to connect external speakers to a Sharp Aquos LC-C3234U TV but not having any success. Can anyone help?
Apperently this tv has a history of sound board related problems. So if you are trying to connect external speakers because you have no sound from the set then you still will be sound-less. On the other habd if you just want more sound then I would suggest using a surround sound system which will readily connect to your set.
Posted on Oct 31, 2012
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
I would like to buy ex ternal speakers for it
The audio out sockets at the back of the TV can be used to connect it with any external audio amps.
Jan 05, 2014 | Toshiba 19SLV411U 19 in. LCD TV/DVD Combo
I want to connect external speakers to tv
If this unit has audio output jacks then these would be connected through an amplifier to provide your external speakers. Caution: Do not open the tv and connect additional speakers to installed speakers because you'll blow the small audio amp in the tv. I have seen this attempted many times
Dec 24, 2013 | Philips Magnavox 27MS343S 27" TV
How to connect external speakers
Hello....I took a close look at your tv and. it doesn't seem to have an output for external speakers BUT...it does have line level outputs so it easily connected to amplified speaker systems or home theatre systems..If you want to expand your system...I would suggest a 5.1 channel surround sound system.....They are priced quite reasonably and will maximize your tv experience.....I hope this was helpful....PEACE...
Feb 08, 2012 | Sceptre X400BV-FHD 40 in. LCD TV
External Speakers Won't Work on Daenyx TV
1st off that is a sound input jack and what you want is what is called Headphone for that and that should solve that problem
Jan 01, 2012 | Televison & Video
Can't get sound to come from speakers with tv only the radio
You didn't give the brand and model of your TV, and I can't try to find a manual and see what kind of AV connections it has available. So here's some general information.
Many TV sets only have input jacks for external sources like DVD players or cable boxes. When you select an external source, or use the set's internal tuner for TV programming, the video and audio play through the TV. The trouble is that if the set has no audio output jacks, there's no way to get a sound signal out. The TV accepts only inputs
When the TV is part of a home theater system, most people use it just as a video monitor. All AV sources connect to the receiver, and audio is sent from there to the speakers. A video output from the receiver goes to the TV so you can see the picture, and the TV's speakers aren't used. If you have a cable box, FiOS set-top box or satellite receiver for your TV channels, they connect to the receiver too, since they're just another external source.
This doesn't work if you rely on the TV's internal tuner for TV channels, though. This might be the case, for instance, if you have a cable system where a converter box isn't required and your cable connects right to the TV. When you're watching regular TV, then, the sound comes through the set's internal speakers. If there's no audio output available on your TV, that's your only option.
As I said earlier, many TV's have only audio inputs. But some have audio output jacks as well, so the sound has a way out. If yours does, you can connect them to one of the inputs on the home theater receiver. Then when you select that input you'll get the TV sound through the speakers connected to the receiver. Depending on the design of the TV, you may need to leave the TV volume turned up. Some sets have outputs that are follow the TV's volume setting. On others, the output is an independent fixed level. Then you can turn the TV volume down and use just the receiver's speakers if you want.
Check the connections available on your TV and look for a set of "audio out" jacks. Your TV's owner's manual should have a section explaining how to connect it in different ways. If you need a copy, most manufacturers have manuals for download on their website.
Good luck with your sound, and thanks for using Fixya!
Jun 17, 2011 | RCA Audio Players & Recorders
How can i make the tv play through the speakers
Source the TV-related sound (probably from the cable box, huh?) as if it is an external audio device, which it IS. The TV need not be a part of the audio path. Some of us have monitors without speakers. It doesn't seem to be a show-stopper.
Apr 17, 2011 | JVC TH-C3 System
Auxilliary audio connection
I don't expect a 2 channel amp would have a digital input such as optical. More likely you would be able to pull analog stereo (red and white RCAs) off the Panasonic and run to the JVC.
Dec 29, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sharp LC-19SK24U TV Logo
23 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
