Question about Gemmy Life-Sized Animated Santa
Well you said you need more details. I apparently plugged in a transformer that had too much voltage. Now the santa does not work properly. He is a item no. 15433 gemmy holiday santa?
I was told the santa took a 9 volt transformer. When I plugged it in. It worked good. Better and more stronger than it ever did. Then it got to the point that he would go off by himself. And then we smelled electric burning. I took him all apart and at the very bottom where he stands there is a printed circuil board. This is the only place where the buring could have come from. When you put your nose right up to it you can smell a very slight electric burn. But visual there is no evidence. When you plug him in he does work. But not very good. And no movement at all.
  • charles Dec 30, 2012
    again I ask. There has got to be somebody out there that I can pay to fix this holiday santa. I mean it only has one printed circuit board. If they can
    fix a complete computer surely they can fix this little holiday santa?
    Sergeant:
  • 475 Answers
I think you might have burn some wires in it and I don't think you'll get it to work any more.
Posted on Dec 30, 2012
SOURCE: Gemmy Santa Bear mouth does not move
The repair listed is just the start. You can, with a lot of careful work, remove the bottom of the mouth, but your work has just started. You will then have to remove the rod that holds the mouth rod to the mouth slide lever "spine". It has a small spring at the top and I found it easier to disconnect the spring prior to repairing the unit. It is glued in quite well so I suggest a Dremel tool to cut the sides off which you will enable you to remove the rod. Then you can remove the head from the spine without difficulty. Now you will see that the problem is as stated, the string that pulls the mouth open has separated from the motor shaft. The cause of this problem is that the grease that the mouth slide lever rides on has migrated to the string, and then, softened the glue, which allows the string to separate from the motor shaft. Now, clean the shaft and replace the string. The original string is nylon. You should use similar material, NOT cotton string or a rubber band. You can't use the old string as it is soaked with lubricant. Use a good super glue to bond the new string to the motor shaft. Next, test the unit to make sure that the mouth slide lever operates properly. Reassembly of the unit would be: remount the head to the neck, then reattach the mouth rod to the mouth and then reattach the mouth and rod to the mouth slide lever.
Posted on Aug 29, 2009
  • 4 Answers
SOURCE: Gemmy inflatable band light show 10ft
inside the box is a fuse it blew so you have to change it
Posted on Dec 03, 2009
  • 4 Answers
SOURCE: Today we put up out Gemmy (Santa, penquin and
there is a fuse inside the bow you need to change that fuse
  • 5 Answers
SOURCE: i need instructions on how to pop up my gemmy
It is suposed to pop up once you press on its shoulders. Once you press them both down you will hear two clicks and release and it will pop up. Mine was jammed and when I pressed it down on the shoulders only one side would click, the other side would not click so Santa did not pop up to full size.
It was jammed on the white area of the stocking, the material got tucked inside the click mechinism prevent it from making proper contact. To fix it I simply pulled the white stocking material up (as if you are going to roll the pant leg up) and then when I pushed the shoulders down after that it opened up just like it should!
Posted on Dec 06, 2011
startrek701
SOURCE: gemmy 5 ft animated singing dancing santa claus christmas life size and it as stoped working, can you help, please :(
Where did u finds a plug
Posted on Dec 03, 2012
How do I fix the fan?
The fan's power comes from a multi output transformer.
Either the fan is burned out or the transformer is burned out or the fans moles plug is not plugged in properly.A simple voltage spike or brownout can take out the transformers.
Feb 27, 2015 | Rinnai Toyostove Direct Vent Heater:...
Sunbeam SBMW1109W/BL - suddenly I am getting no heat from any of the settings
Possible causes - door switch failure or not being activated, high voltage rectifier failure, magnetron failure, high voltage capacitor shorted, high voltage transformer failure, or high voltage transformer not receiving 120 v from controlling component. If unit emitted odor before failing, high voltage rectifier or transformer are most likely. These units operate on 4000 v, or more, and can have this voltage present on the capacitor (even when not plugged in or running) . If you are unfamiliar with proper test procedures, best to find someone who is. Pople can, and have been, electrocuted working on these!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 17, 2014 | Microwave Ovens
Some power but not operating
Check out with a multitester whether the control panel switch on the power towards the high voltage transformer NNB disconnect the high voltage transformer for this test. if not the relay on the electronic controlle device is broken and the panel needs replacement. check also the 3 safety switches on the door for proper operation. mind the power it is dangerous.
May 10, 2013 | Sanyo Microwave Ovens
AC Power Failure
Providing that you the outlet is putting out proper voltage, check the voltage output of the plug in transformer. Used a voltmeter set to AC and attach the leads under the plug in transformer (where the wire normally go) and plug back into the outlet. The voltmeter should be reading around 9 volts AC. If there is no a low or no reading, you have a bad plug in transformer. It can be replaced with a 9 volt AC 25 volt amp transformer. Battery may also have to be replaced, if it is depleted. If this does not fix the problem, you have a bad panel and it will need to be replaced.
Jul 26, 2012 | GE Security Simon Xt Wireless Control...
How to test for bad transformer
  1. To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
  2. You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
  3. Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
  4. To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
Dec 16, 2011 | Emerson LC320EM8 32 in. LCD TV
I have a LG LRE30453SW Electric Range and the relay pcb keeps going bad. I get an F7 error when starting the oven. The first time I noticed the black line in, from the power terminal, to the relay pcb was...
First, check the 220v line and breakers are properly grounded and that you are getting a constant 220v at the plug. Then you will need to check the transformer on the unit.To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
If all that looks good, then you will need to replace the control board. Here is a link to the parts for your range.
Regards,Richard
Dec 08, 2011 | Ovens
Audio video control centre. digatal delayed surronds,model no str-d350z was plugged into wrong voltage,part burned out,can you help
You have not specified the make/model. But if you set is having the transformer as the case may be, and you have plugged into the 220volt with the 120 volt settting, then the transformer would have burned off. If so identify the secondary voltage of the DC cicuit and use a 220volt transformer to replace. If you are not able to identify multiple tappings then you must get the primary of the burned tranformer wound for 220volts. If at all this is aSMPS unit then you will need to replace the full unit as the ratings inthe power will be different.Since you have not specified details of voltage and ratings,I am not able to advice more. Hope you decide. Good day
Jul 23, 2010 | Sony Electronics - Others
Will not adjust weight
Plug the indicated end of the Transformer into the Rear Mech Cover . Plug the other end of the Transformer into a 120-volt outlet. All indicators and displays on the console will flash once; the console will then be ready for use. The motor may be heard while the resistance system calibrates itself. Important: Always plug in the transformer when using the resistance system.
Then, press and hold the NEXT button and the motorize resistance + button for five seconds. When the buttons are released, a number will appear in the REPS display. Press the NEXT button again, and then press the MOTORIZED RESISTANCE + button; this will start the recalibration process. This may take a few seconds as the motor moves between the lowest and highest resistance settings. When the motor finishes, unplug the transformer from the 120-volt outlet.
If you cannot hear the motor reset it self or cannot see display then with multi meter check DC voltage if not replace transformer , if you have DC voltage you will need to remove the cover locate the motor assembly disconnect the assembly from the upper electronics. Then apply a 12v DC voltage to the motor and see if it engages easily if not then replace motor. If motor functions properly replace connector back on the motor and use a multi meter connect it to motor and plug in the transformer and you should see DC voltage going to motor if not replace upper console.
Jun 01, 2010 | WEIDERFITNESS.COM Weider Platinum Plus
HP Scanjet 3970 has no power
What is the temperature at the plug/transformer? If it is cool to the touch after being in the live outlet for a while, that is the source of your problem and it needs to be replaced. You will need to match the plug size and shape as well the voltage for an AC/DC transformer. The voltage is usually on the transformer but can be hard to read (highlight it by rubbing chalk over the lettering if the letters are molded into the case).
I hope this helps.
(I do not know if HP sells replacement transformers; Radio Shack often has suitable ones but you do need to match the details.)
Feb 12, 2010 | HP ScanJet 3970 Flatbed Scanner
My hard drive has stopped working! I checked power supply and it is working fine, when plugged into drive and turned on, the blue light flashes briefly on the drive then goes off again as does the light on...
Could be a bad transformer on the power supply or a bad drive. You could check the voltage coming from the transformer and verify that it is the proper voltage using a fluke meter. You could also dis-assemble the hard drive housing and try installing it in the computer and check if it is working. If you install it in the computer and the drive is not found then the drive is probably bad. If the drive works in the computer then get a new transformer.
Sep 24, 2009 | Western Digital Computers & Internet
Gemmy Life-Sized Animated Santa Logo
196 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
