Question about Microsoft EXCEL 2004 for Mac
Dues must show automatically
Pls let me know the formula for this there is a one column contains total amount and another column which contains not equal to that amount it have dues in another column (for eg) 25,000- 5000=15000,like this there is a list of candidates they paying ther fees in intallment. so i need the formula for it shows the dues automaatically. pls help me
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is the dues a fixed amount or a variable amount?
  • 407 Answers
Can you not show as such
Dues= Column A
Paid = Column B
Outstanding Column C
A-B=C
total Column C = Total Outstanding
Posted on May 22, 2009
I have a spreadsheet set up with columns which have dollar amounts which need to be added or subtracted. How can I set up a formula to do this automatically without me manually doing it on each line.
Best bet would be to utilize the "Help" function for formulas. You will need to set up a formula for each column you would like to format. Or simply add a Function (123-456) or (123+123) That way the cell will know the math. Good Luck
Feb 10, 2015 | Microsoft Office 2010 Home And Student...
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
Apr 02, 2008 | Computers & Internet
How to calculate the percentage using the excel
Hide All
Percentages are calculated by using the following equation:
amount/total = percentage
Where percentage is in decimal format.
What do you want to do?
Calculate the amount if you know the total and percentage For example, if you purchase a computer for $800 and there is an 8.9% sales tax, how much do you have to pay for the sales tax? In this example, you want to find 8.9% of 800.
Example The example may be easier to understand if you copy it to a blank worksheet.
  1. Create a blank workbook or worksheet.
  2. Select the example in the Help topic. Note Do not select the row or column headers.
    Selecting an example from Help
  3. Press CTRL+C.
  4. In the worksheet, select cell A1, and press CTRL+V.
  5. To switch between viewing the results and viewing the formulas that return the results, press CTRL+` (grave accent), or on the Formulas tab, in the Formula Auditing group, click the Show Formulas button.
1 2 A B Purchase price Sales tax (in decimal form) 800 0.089 Formula Description (Result) =A2*B2 Multiplies 800 by 0.089 to find the amount of sales tax to pay ($71.20) Note To convert a number in percentage format to a decimal, divide it by 100. For example, the sales tax in this example (8.9) divided by 100 is .089.
Calculate the percentage if you know the total and amount For example, if you score 42 points correctly out of 50, what is the percentage of correct answers?
  3. Press CTRL+C.
Simple way Amount/Total*100
Apr 30, 2011 | Computers & Internet
I am trying to figure out a payroll formula. I
Here is how you could do the formula with two one column having the hours of each day in it and the overtime being in another cell:
Example:
Column A Column B
8
8
8
8
0
Total 40 OverTime 2
Formula in this cell where 40 is at:
=IF(SUM(A1:A7)>40,40,SUM(A1:A7))
Formula in cell where 2 is at:
=IF(A8>40,0,SUM(A1:A7)-A8)
Let me know if this helps.
Jan 01, 2010 | Microsoft Excel 2007 Home and Student...
Writing a formula for a sumif problem
Brenda,
Your problem is not so much the formula but the cells that contain the hours for each call. Since they contain the text “hrs” (for example “2.25hrs”) this turns the whole cell to text, not numeric, which will always add up to zero in Excel. So do two things:
- Change the cells in column H (Time Spent) to numeric (2.25 instead of 2.25hrs) – you might want to change the column header to Time Spent In Hrs just to b clear
- Use this formula =SUMIF(E8:E26, 1, H8:H26)
For the formula change the middle number to correspond to the operator ID – for example for operator 2 change the formula to =SUMIF(E8:E26, 2, H8:H26)
This should do it.
BTW, sent you a similar email about this.
May 07, 2009 | Microsoft Excel 2007 Home and Student...
How to add % (Percentage column ) in the excel
The formula is 200/700 equals the percentage;if you're in columns a, b, and c, the formula in c1 will look like:
=b1/a1.
Then you can format the cell to show the number (.2857) as a percentage (28.57%).
Jan 03, 2009 | Microsoft Computers & Internet
Count how many times a value appears in a column, based on anothe
Go to the cell you want this total in.
Type this formula:
=SUM(IF(Sheet2!C1:C10="EME",IF(Sheet2!N1:N10=1,1,0)))
make sure you end the formula with CTRL - SHIFT - ENTER which makes it an array formula. If you forget, go back to the cell with this formula and press F2 (to edit the cell) and press CTRL - SHIFT - ENTER to convert it to an array formula (Excel will show a little {...} around the formula).
Dec 21, 2008 | Microsoft Excel for PC
Microsoft excel Formula
create a dummy column (columnC) containing columnA&columnB
use countif at columnD to count the number of observations per combination of columnA and columnB (in particular those with blank entries in columnB).
Sep 15, 2008 | Computers & Internet
Sum of Alternative Columns
Alternative Formula? please explain it.
Jul 31, 2008 | Microsoft Excel for PC
Microsoft EXCEL 2004 for Mac Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
