Question about GE WSXH208A Front Load Washer
GE FRONT LOAD WASHER WILL NOT FILL WITH WATER
fanny
  • 146 Answers
SOURCE: G.E front load washer Mo# wbvh6240fww
The door interlock may be faulty. Try closing the door firmly or hit the door handle when the door is closed.
Posted on Oct 31, 2007
SOURCE: GE Front Load Washer
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Posted on Sep 22, 2008
SOURCE: My GE front load washer
We believe a shirt sleeve was not fully in our GE GCVH6260 front loading washer. With the twisting and turning the shirt pulled our rubber door seal into the washer, stretching the seal. The rubber door seal is formally called a; "front door boot gasket". (image of washer type linked below)
http://di1.shopping.com/images1/pi/e8/78/fb/28130826-177x150-0-0.jpg
We contacted our local GE store and picked up the replacement boot gasket (part# WH08X10036), which cost about $155 plus tax CDN.
Please Note; I did not remove the front face of the washer..
1. I cut away the old rubber ring as I did not have the "carny hands" needed to loosen the inner ring nut and bolt.
2. I then used a mini hack saw to cut the screw in half (careful not to cut anything else).
3. Once the old rings were removed, I filled the bath tub / laundry tub up with very hot water and submierged the new boot gasket into the water for five minutes.
4. Once heated, I quickly lined up the ring to the proper positioning and was able to put the ring on the washer with little effort.
5. As the ring cooled in place, I put the inner metal ring back into the appropriate groove. As I could not reach in an put a proper nut and bolt into place, I opted to use two thick zip ties to hold the ring in place, pulling it tighter with my pliers on the end and snipping the excess legging off after.
6. The outer ring was relatively easy to put on afterwards.
Special thanks to my pops, Warren McDonald for his great advise on heating the ring to put it in place!
Posted on Feb 14, 2009
SOURCE: GE WSSH300G0WW front load washer
Had same problem with GE wssh300 front load washer. Removed two screws from front bottom panel (under washer front). Pulled off panel, loosened screw from a seal ring on the rubber flex hose going to a 4" square plastic housing. Reached down inside and found a ton of lint (probaby a 2" balls worth) jamming outlet. Removed lint an works geat. Very easy to do by tilting front of washer up and putting supports under front to keep elevated. Be careful to make sure supports are sturdy washer can't dop when servicing.
Posted on Aug 25, 2009
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
My GE front load washer won't dispense water. Model # is WCVH6260FWW. I've checked the water hoses and the trap in front of my washer. When i turn it on it just turns and hums and locks the door like its...
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 04, 2011 | GE WSXH208A Front Load Washer
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Why does it take so long to run a load of laundry in my GE Profile front loading washer?
Check the water supply, if the water supply is restricted in some way it will take a long time to fill, the m/c may need to fill 4 or 5 times in a complete wash.
Nov 19, 2009 | GE Energy Star WCVH6260F Front Load Washer
My GE front load washer will not fill with water unless I put it on the tap cold setting. What could be the problem?
more than likely your water mixing valve is bad or at least the hot water side
you can check to ensure that the screen is not clogged but that is rare for hot water
Oct 22, 2009 | GE WSXH208A Front Load Washer
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not fill
I had a problem almost like yours. The hose attached to the load size switch had a clog in it, and the washer wouldn't fill with water or spin. Will need to take the front panal off to check the whole line.
Jun 06, 2008 | GE WBSE2090A Top Load Washer
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Apr 28, 2008 | GE WSXH208A Front Load Washer
Oct 30, 2007 | GE WBVH6240F Front Load Washer
GE WSXH208A Front Load Washer Logo
15 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
