Will a dh145 wick work in a rmc95c6b - Heating & Cooling
Please enter your heater brand and model number below to determine the corresponding wick to use:
http://www.yourheater.com/wickfinder.htm
Posted on Jan 22, 2013
Adjust the wick on a dyno glo kerosene heater
Robin, without knowing which model Dyna-Glo, I can only generalize. But, if you are not getting an even burn with the wick turned all the way up, then upon dis-assembly, if the wick is NOT pinned (pins in the wick engaging the lifter system) then remove the wick and raise it about 1/2". Lower the wick down into the wick lands and check for level. Trim as necessary to get a level top. Reassemble.
If the wick IS pinned, then no adjustment is possible. Remove and discard and install a new wick.
Dec 20, 2014 | Heating & Cooling
How do you replace just the top part of the wick on a comfort glow GR9B kerosene heater?
    • Remove the base plate from your Comfort Glow heater and expose the fuel tank. Lift the fuel tank out of the heater and set it to one side, well away from the heater. Note that the fuel tank is not connected to anything and will slide out easily.
    • 2 Run the heater until all the fuel in the lines is used, a process called "dry burnicon1.png," which usually only takes a few minutes. The fire will go out when the lines are empty. Turn the heater switch off and allow it to cool.
    • 3 Take the batteries out of the battery compartment on the back of the heater. This is an important safetyicon1.png step that keeps the heater from accidentally coming on while you are working on it.
    • 4 Lift the wick ring up and off, then remove the two nuts that secure the wick. The wick ring fits around the wick and the draft pipe -- the hollow tube that holds the wick -- and serves to hold the wick firmly in place.
    • 5 Slide the wick up as far as possible to reveal the positioning pin -- the small metal pin near the bottom of the wick. This pin is part of the wick and helpsicon1.png to ensure it is installed correctly. Push it out through the positioning hole in the draft pipe and lift the wick out of the heater.
    • 6 Fit the new wick onto the draft pipe and engage the positioning pin in the hole by pushing it in until it clicks into place. Move the wick down into the heater and replace the two nuts to secure it.
    • 7 Measure the distance between the wick and the draft pipe with the clearance gauge. The distance between the wick and the draft pipe should be the same all the way around, to ensure an even burn. Adjust the set screws as necessary to create even spacing. These are the small screws spaced evenly around the draft pipe that, when turned, move the pipe slightly so you can correct the spacing between the draft pipe and the wick.
    • 8 Replace the wick ring over the wick. Return the batteries to the battery compartment and the fuel tank to its compartment. The fuel tank will slide securely into its compartment in only one way. Replace the fuel compartment cover to complete the project.
Tips & Warnings
  • Keep the heater set on medium to medium-high for best results. Setting it too low or too high may cause soot to accumulate on the wick.
  • When operating a kerosene heater indoors, always have a working carbon monoxide alarm and a smoke alarm. These heaters are generally safe when in use, but an alarm will provide a safety backup in case the heater malfunctions
Oct 14, 2013 | Northern Tool 10,600 BTU Radiant Kerosene...
My dynaglo kerosene heater will not continue to burn. It is full of fuel and will light but will not burn. what could be the problem?
Many things can cause this to happen and here are a few of the most common. The wick could be dirty, wicks should be brownish black in color, soft to the touch and flexible. Wicks will get hard and full of soot, my solution is to clean the wick with an old tooth brush gently brush it and I do this with the wick up about half way so I do not damage it. Then I take a shop vac and **** out all the stuff from the wick, make sure it still moves from high to low easily. Now soak the wick for roughly a half an hour and then light it. If the cleaning does not work you will have to change out the wick and remember that soaking the wick is the most important thing to getting good life out of it. Another practice is to burn out your heater each four to five tanks of fuel, this does stink bad so when you do this do it outside. Once you notice that you are about out of fuel take the heater out side and just let it burn out, this does clean the wicks on these heaters. Fill with K1 kerosene soak for the half hour with the wick completely turned down, then set to high and light it up. This cuts down on smell, helps it burn hotter,and in turn burns more efficiently.
Dec 26, 2010 | Heating & Cooling
Need a wick and battery pack for a TOYOSTOVE KSA-105, where can i find these?
Hardware stores usually carry wicks. One brand is Kero World. Wick #503K works for the KSA-105. I have one that I bought and the person never brought their heater by so I could replace the wick. The battery pack could be ordered through a Toyostove dealer.
Oct 07, 2010 | Rinnai Toyostove Direct Vent Heater:...
The wick will not raise
If you allowed the fuel to run out then the wick is probably ruined, you will have to replace it.
Feb 26, 2010 | Corona 23-DK Compact Heater
How do i change the wick?
You need a pair of Pliers, a flat-tip screwdriver and a plastic bag (for old wick)
ALSO - make sure the tank is empty (or as close as possible)
1. Turn the control knob to OFF.
2. On the left and right side (bottom, just under the wire cage are two cabinet screws. Remove these.
3. Using the handle, lift straight up to remove the cabinet (entire upper assembly)
4. Gently pull off the wick adjustment knob (you will need to push in the little square button.
5. Remove the "dressing plate" (the ring about 3" high) that the "Off" "Low" and "High" markings. The chain attaches this the fuel cap, but you don't have to remove the cap. Just set the "dress plate" ring aside as far as the chain lets you.
6. Either trip the manual shut-off or push against the wobbly pendulum to the left of the control knob shaft to drop the wick all the way down.
7. Remove the four wing nuts that holds the heater on the wick assembly and carefilly lift teh sick assembly from the heater.
8. Reset the automatic shut-off, put the know back on temporarily and raise the wick all the way.
9. Turn the Wick Assembly upside down. Place the white plastic strip, packed with the new Wick, on the Wick Cover to protect your fingers.
10. While holding the Wick Assembly upside down, pull off the Wick Cover with a sharp tug.
11. Remove the Wick while folding it to the inside. (Remove the Wick Sleeve together with the Wick).
12. Take the new wick and insert the Wick pins into the three holes of the Wick Sleeve. (Make sure the short portion of the Wick is UP.)
13. Attach the Wick wo the retainer teeth of the Wick Sleeve stick into it, making sure the Wick fits evenly arount the inside with no wrinkles or bunching.
14. Fit the Wick and Wick Sleeve back onto the Wick Guide, making sure you fit the pins through the slanted grooves of the Wick Guide and Press on each of the three pins from the back, making sure they are inserted securely through the holes on the Wick Guide. (This is where most people screw up Wick Replacement, so make sure you get this right)
15. Turn the Wick Adjustment Knob to make sure the Wick slides up and down freely. (Note, the wick should automatically be set to 3/8 of an inch when fully raised.)
16. Turn the Wick Assembly upside down and replace the Wick Cover by: Align the four tabs on teh Wick Cover with the four screw holes on the bottom of teh assembly and snap it into place.
17. Hold the Set Lever to down position with your finger.
18. Remove the protective strips from the Wick Cover. Turn the Wick Adjustment Knob to the fully raised position and light pull on the "skirt" of the Wick to remove any slack. Then press the skirt lightly onto the teeth on the Wick Cover to hold it in place.
19. Replace the Wick Assembly on the heater WITH THE WICK RAISED. Replace the wing nuts, tightening gradually, tightening opposites sides first(If counting clockwise, tighten screw 1, 3, 4, 2 - go through several rounds, tightening gradually so it seats evenly
20. Before further reassembly, trip the Auto shut-off and reset it to make sure it works properly. Test the Wick adjustment knob to make sure Wick slides up AND down freely.
21. Remove the knob and replace the "dressing plate ring.
22. Replace the entire upper assembly "Heater Cabinet" and repalce the two screws. Replace the Wick Adjustment Knob.
Oct 11, 2009 | Corona 23-DK Compact Heater
DynaGlo RMC-95-c6
did you soak the new wick a good hour in clean kerosine before you installded it???is your wick in the correct position? it needs to be 5/8" showing when installed in the up most position.very important to soak the wick or it won't wick up fluid as it is suppose to.
Feb 24, 2009 | Corona 23-DK Compact Heater
Change wick corona dkc22
u need to start at top . remove cage from top. there should be a few screws on the side of the upper case (the round upper part of the heater) once that is removed u will see the shaft the wick is attached to,the heater control are mounted here too. there should be some screws or wing nuts remove them. now lift the shaft out the wick will come with it (carefull wick wiill be wet with kerosene) remove old wick. when replacing new wick make sure to allign the top of the colored band with the top of the wick holder(the piece with the pins that adjusts the wick up & down) lower shaft & wick back onto heater and reasemble heater .be sure all controls and shut off work smoothly and correctly.
Jan 10, 2009 | Corona 23-DK Compact Heater
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
