Question about ASUS EXTERNAL USB FLOPPY DRIVE (ASUUSBFDD) Media
I have windows XP svpk3 OS,when i insert my 1GB moserbaer pendrive its not detected,windows showing error USB device not recognige,in divice mannager its showing UNKNOWN DEVICE whats the solution for it.....
    Habit-Forming:
    New Friend:
  • 18 Answers
Most likely the pendrive is no longer working. The simplest way to check that, is to try it in another computer and see if it's recognized. If this is the case then the USB ports on your computer are not working which I doubt.
If it is seen as unknown device that means that the electronics in the flash drive got bad and it is unrecoverable.
Posted on May 06, 2017
  • 1019 Answers
SOURCE: usb 2.0
this is a common error with operating systems and devices.
If you go into my Computer/system/device manager. And remove the installed USB devices. shutdown the computer, and reboot it. then try putting your USB device in.
What general happens, is that if you have had an older device in the USB port at any time, the port configures itself to this setting. options are to try another port on the computer ( some older ports only support usb1.1 )
ensure you have up to date drivers on the connecting device and on the connecting computer.
Hope this helps Mike @ Compurepair.
Posted on Feb 22, 2008
mrsno
  • 166 Answers
SOURCE: USB ONBOARD NOT WORKING
Hello there.
It sounds like you do not have the additinal USB patch which you can download and install from here http://dlcdnet.asus.com/pub/ASUS/misc/utils/S3USB.zip
The article for the patch is here, which addresses the problem with USB failing to work.
Please run this fix and your USB should be working, if not then please get back to us and we can try additional steps.
Hope this helps.
Posted on Jun 28, 2008
SOURCE: transcend 4gb pendrive not being detected in Win XP
my 4gb pendrive is not detecting in my win xp operating system,before 2,3days i repaired my operating system,after that it is not detecting..pls help me
Posted on Oct 29, 2008
ziraffa
  • 827 Answers
SOURCE: onboard USB prrs malfuntion
Try re-installing the motherboard drivers. Here's a link:
http://drivers.softpedia.com/get/BIOS/Asus/Asus-M2V-MX-SE-Bios-0502.shtml
Hope this helps
Chris (ziraffa)
Posted on Dec 22, 2008
  • 298 Answers
SOURCE: USB device malfunction
Did you reboot the PC after SP install?
If not... shutdown, restart without USB device installed, reinstall SP, reboot, Try USB device again.
Fixed!
Posted on Jan 18, 2009
2gb kingston pendrive not working
change the pendriver claim warranty
it somthing wrong with the hardware
May 20, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Driver for moserbaer pendrive for os win 98
On the official website there is nothing to be found about drivers.
However I was able to dig this out for you:
You get get their contact info here: http://www.moserbaer.in/writereaddat...eripherals.pdf
USB drives are listed under IT Peripherals here: http://www.moserbaer.in/peripherals_electronics_pro.asp
Hope it helped.
Nov 19, 2009 | Microsoft Windows 98 for PC
Pen drive not working
format the drive using linux operating system .. and then format it in windows operating sys...
done...
Sep 20, 2009 | Electronics - Others
Kingston DT1000 pendrive was not detected in computer
hi there.
this is what i have just found on the internet it might help you out but not sure.
After plugging in the device. Go to device manager (In run type "devmgmt.msc") In Device manager go to "Universal serial bus controllers" It should list the storage devices that you have connected to your PC. Right click and then click "Uninstall. Remove the USB drive and restart your system.
Try connecting the device again, I think this should solve the problem.
for windows xp
first you need to go to Device Manager by double-clicking on the System icon in Control Panel, choosing the Hardware tab, and clicking Device Manager.
go to divice manager
usb hub controler it will be at last of the list then
right click on usb hub controler open it go to usb root hub right click & go to properties
then go to device and click ok
do it 4 to 5 time it will work 100%
i have tried it and it worked
Best of luck :)
hi do one thing go to my computer right device manager ther u to o universal serial bus right click on tht option go to update driver select yes this time only give automatic k . before doing this step plz insert mother board driver cd after tht u do all this procedure thn c ur pendriv vl be dedected k
if none of the above works try this link out.
Kingston DT 1000 pendrive was not detected in computer Google Search
Nov 20, 2017 | Transcend (589307) Media
Pen drive is not detected
Check your pendrive in other PC, if same problem is seen, then your pendrive is over. & if it is detected in other PC then, your PC needs to install new OS. This will fix error for your pendrvive
Apr 21, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
MY USB(2.0) PORT NOT WORKING
hi,
welcome to fixya.com,sir if u have already uninstalled and reinstalled the drivers and if u have already reinstalled the operating system and if it is still not working then simply replace the system motherboard.
Feb 14, 2009 | Microsoft Windows XP Professional With...
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Pen Drive Driver
You must install a "Driver" for it to work under Win98, go to the manufacturers web site and download the driver and install.
Feb 07, 2008 | SanDisk 8GB microSDHC Memory Card with...
Electronics - Others Logo
609 people viewed this question
Top ASUS Electronics - Others Experts
Jax Planet
Jax Planet
andrewcahoon
ovidiu oprea
ovidiu oprea
Level 1 Expert
Are you an ASUS Electronics - Other Expert? Answer questions, earn points and help others
