Question about Acer Aspire 3000 Notebook
Screen saver freezing
I deleted some programs trying to increase the memory on my hard drive, and i deleted some programs that i shouldnt have. everything works okay, but when the screen saver kicks in after 5 minutes, the computer freezes. i tried going into my computer display options and changing the screen saver/power options and it still freezes. i've already installed some updates from windows (i have windows xp) and it hasnt helped.
    Problem Solver:
  • 10 Answers
Do you still have your xp install disc?
If so, there are two things you can do.
1: go to start menu and click 'run' and type "sfc /scannow" (no quotes and note the space after sfc)
This is windows System File Check. It will check your computer to make sure the original windows files are on your system. If it does find any problems it will ask you to insert you xp install disc.
You may have to run updates after.
2: Do an in place reinstall of xp. Here is a link explaining:
http://www.michaelstevenstech.com/XPrepairinstall.htm
read from under the first horizontal red line. READ VERY CAREFULLY.
after the in place reinstall you will have to download and install all updates and patches sp's, etc
Good luck
Posted on Jan 18, 2009
    Novelist:
  • 176 Answers
  1. Boot normally and do a System Restore to a date before you deleted some programs
Or
  1. Select a different screensaver
Or
  1. Reboot and keep tapping on F8 to go to Safe Mode.
  2. Once in Safe Mode select "Last known good configuration" and press Enter.
Or
  2. Continue to Safe Mode and do a System Restore to a date before you deleted some programs
My Acer Aspire One D257-1679 Laptop Constantly Freezes. Maybe Windows 7 Drivers out of Date and is not compatable.Should I do factory Reset?. Thank you
I just fixed a laptop with windows 7 freezes
windows 7 support has ended
all you need ot do is reduce the number of programs the computer is running
C drive needs lots of free space
if you want to keep the computer ..these things help
first store what you want to keep on to usb sticks
documents ,pictures ,files ,
not on the hard drive
delete all the unwanted items off the c drive
look into the users ..remove "Temp "
go through all the programs on c drive and uninstall
as many non windows 7 and unused microsoft programs and also unwanted computer games and printer drivers
clear all the downloads
clear the memory cache
defrag the c drive
scan for virus and troguns
if using versions of office above 2000 will slow /freeze the pc
windows 7 when released was based as a 32 bit and some x64
window 10 can be uploaded only if window 7 has upgraded to stage 3 but it will be slow
stuff that is X 86 will slow windows 7
Jun 29, 2016 | Acer Aspire Computers & Internet
I deleted some programs from my computer trying to increase my hard drive space, and i deleted something i shouldnt have. everything works fine, but when my screen saver kicks in, the computer freezes. i...
try going to Start>All Programs>Accessories>System Tools> Restore and do a restore to the day before you closer to when you deleted the files and that should clear you up. if that doesn't Work come back here and I'll see what else you can do to get it fixed. Mike
Jan 18, 2009 | Computers & Internet
Laptop stops at the screen saver and does not allow me to click on any icons. Laptop is a compaq ev0 n620c
the laptop is short on memories or short on hard drive space.
trun off the laptop.
unplug the AC and remove the battery.
press and hold the power button for 30 sec.
reinstall the battery and plug in the AC.
turn on the laptop.
go to start>>programs>>accessories>>system tools>>disk cleaner.
delete all of the junk and unwanted files.
go to control panel>>display>>screen saver
select a different screen save or use WIndows screen saver.
Dec 15, 2008 | Computers & Internet
Slow
Hi Whose,
Me again :-)
Yes m8, there is something you can do.
Perform the steps given below to increase your system performance.
Uninstall all unwanted software:
To uninstall software
Click on Start
à Settings à Control Panel à Add/Remove Programs
Select the software (one at the time) from the list and click on the Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temp folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag.
You should defrag every hard disk on your system.
This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Dec 11, 2008 | HP Compaq nx6110 PC Laptop
Computer is slowing down
Hi Big Bad Bob, and welcome to FixYa,
you computer is "dirty", clean, and feel the difference:
Click on Start
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
regards
Yeis the Wiz -> vote :-)
Dec 06, 2008 | Computers & Internet
Toshiba Satellite laptop takes over 20 minutes to start up
Hi Marshall, and welcome to FixYa,
Have you tried everything?
Click on Start
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Now, antivirus program? Have you got one?
http://free.avg.com/download-avg-anti-virus-free-edition
Dec 06, 2008 | Toshiba Satellite M45-S2652 Notebook
My C:\drive is full and i have removed files to make space but it stil says there is not enough space on drive. What can i do?
Copy this text into a word document, print it and have it next to you when you ferform this:
Perform the steps given below to increase you system performance and clear space.
Click on Start -> Settings -> Control Panel -> Add/Remove Programs
Select the software (one at the time) from the list and click on Add/Remove button and follow the online screen instructions.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Nov 30, 2008 | Acer Computers & Internet
My computer needs a clean out.
Perform the steps given below to increase you system performance.
Uninstall all unwanted software.
To uninstall software:
Erase unnecessary files in the windows temporary folder.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag. You should defrag every hard disk on your system. This process can take quite some time.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Nov 29, 2008 | Computers & Internet
Gateway mx6930 laptop freezes up every 10 minutes - keyboard and mouse become inoperable
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Click Ok.
Click Start
Select Run
Click Properties
Click Performance
Click OK.
Click Yes.
Click Yes
Zune software freeezing
Try changing your screen saver to a basic windows screen saver and see if that helps.
Nov 20, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Acer Aspire 3000 Notebook Logo
102 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
